Old 12-05-2007, 02:18 PM   #1
DaveTE
Back in black
DaveTE's Avatar
Default Any torque settings?
Rear suspension top mounts/stut mounts or what ever you call this faulty bit. Does the top centre nut attached to the shock arm have to be torqued up to a certain setting? Can anynone help please?
Black Mac TE50 S3 NO: 106
Little Mac AU S2 XR8
Bite the snake before it bites you!
______________
_.__ /________...\
_.._(___\\___//___)
.._..(O...\____/...O)
DaveTE is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2007, 03:54 PM   #2
Bosman
T Series Club Member No24
Bosman's Avatar
Mate , mine were torsion nut anyway. Just do up tight and make sure strut is seated or mount will rip itself to shreds again. If it bottoms out like alot do before fully tightening , use a heavy duty washer to take up slack. Cheers
"IRS Top Shock Mount"
1967 XR Falcon Mountain Blue Worked 250 2v , Kitted C4 , LSD , 10x14 Rear 9x14 front (LOW and FAT) had for 26 years....magnificent!
FTe Venom T3TE50 No229 5.6L Manual Don't drive one! Because like so many others , including ME , you will become TOTALLY addicted.
2016 Harley Davidson Softail Heritage customized.
Dead set gorgeous!
Bosman is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2007, 11:05 PM   #3
FTE217
T3/Sprint8
FTE217's Avatar
As bosman says torsion nut known as a Nylock nut. Do up till firmly down, won't come loose.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2007, 11:19 PM   #4
DaveTE
Back in black
DaveTE's Avatar
Talking
Cheers fellas
______________
_.__ /________...\
_.._(___\\___//___)
