11-05-2007, 05:04 PM | #1 | ||
Tickford Tough
The climate control in my TE50 seems to have died. I have no fan control, and even when the car is turned off with keys out, the fans continue to run. I'm guessing a solenoid has given up the ghost and to prevent my battery from going flat I have removed the fuse 40amp fuse for it, but a local Ford dealer refuses to assist me unless I book it in for an inpspection for $90.
Seeing as the T1 was Fairmont based the climate control for both is exactly the same so I was hoping someone may have had a similar problem in the past and can give me an idea of what needs to be replaced and at what sort of cost. Hoping it's not the entire climate control cluster as I'm assuming they're not too cheap. Thanks guys. |
11-05-2007, 05:42 PM | #2 | ||
All Bran = Regular Member
http://www.geocities.com/liquidxtal/Price.html
Contact this guy. Lots of satisfied customers including me. edit: oh, you've got more than the usual cc probs. That guy may be of some assistance for a replacement unit if that is what the problem is otherwise an auto electrician may be the go. Last edited by ronwest; 11-05-2007 at 05:47 PM. |
11-05-2007, 05:54 PM | #3 | ||
Tickford Tough
Cheers mate. Got a strong feeling it may be replacement time. That was the solution when similar fault occured with my old EF.
11-05-2007, 08:36 PM | #4 | ||
there was a thread on here not too long ago with a resistor i think behind the glove box shorting out and causing this problem
11-05-2007, 08:51 PM | #5 | ||
well after much searching, here it is http://www.fordforums.com.au/showthread.php?t=73421
12-05-2007, 10:37 AM | #6 | ||
Tickford Tough
Awesome, thanks heaps for that. Hopefully mine's as easily fixed.
12-05-2007, 09:42 PM | #7 | |||
Karasu
