Old 08-05-2007, 07:04 AM   #1
Soundwarp
Blue to the bone!
Soundwarp's Avatar
Default 220 sticker removal
I know there are threads dealing with remocal of stuff but none asking exactly this so sorry mods if i upset.
I want to remove my 22o sticker from the back now that it isn't a 220 anymorem has anyone done this nad if so how and are you satisfied?
Thanks!
BA GT-P in the garage
http://img.photobucket.com/albums/v7...dwarp/fbar.jpg
Soundwarp is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2007, 07:07 AM   #2
5L
[ 5L ]
5L's Avatar
id leave it there, the motor is still a 220kw version. which is better than a 200kw one. the motor will still make around the 220kw mark an engine dyno and this is where the figures are from.
www.ignitionimages.com
Old 08-05-2007, 10:08 AM   #3
RG
Back to Le Frenchy
RG's Avatar
Thanks!
You got to leave it there if not for anything else but the **** factor. I left mine there long enough for it to come into use again since now I have 220 at the wheels.
Old 08-05-2007, 01:12 PM   #4
Andy XR8
AU3 Winged Windsor
Andy XR8's Avatar
yep leave it on, as you may have 220 at the rears some day too. thats what i'm aiming for.
Andy XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2007, 03:27 PM   #5
FTE217
T3/Sprint8
FTE217's Avatar
I'd leave it on because it's factory but easy to get off anyway....
Heat it up with the blowdryer, softens it up and the adhesive at the same time then just pull off !
Polish gets off any other residue left.
Done it plenty of times.
As a thought can replace with a Tickford badge.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2007, 03:31 PM   #6
RG
Back to Le Frenchy
RG's Avatar
Tickford badge belongs on the other side of the bootlid. Also be careful if you use the hairdryer because you will most likely heat the XR8 badge too and if you slip that'll come off too. Easiest way I've found to get a badge off is to use some fishing line behind it and work it through the tape, then clean up with some wax & grease remover.
Old 08-05-2007, 03:39 PM   #7
FTE217
T3/Sprint8
FTE217's Avatar
Thats right re the Ticky badge my mistake.
Only a woodduck would stuff up the XR badge above, hairdryer blowing down wouldn't case an issue. Used the fishing line as well, does the job but I don't like scraping behind the sticker/label and dragging small particles at the same time.
Just my opinion.
Daily Macan GTS
Old 08-05-2007, 06:31 PM   #8
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
I certainly don't want to hi-jack a thread here, but i removed my badges (with hairdryer) when i purchased my car and now would like to put badges back on, what is the best adhesive to use for this purpose? Thanks.
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2007, 06:33 PM   #9
RG
Back to Le Frenchy
RG's Avatar
You'll need new badges.
Old 08-05-2007, 06:58 PM   #10
Umineko
Karasu
Umineko's Avatar
you can get double sided body moulding tape at most auto paint and accessory stores, you'll need to trim it very carefully to the edges of the badge then just stick it back on, given that the badges are not expensive I'd save the stuffing around and just get new ones
Umineko is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2007, 07:06 PM   #11
crakrz
T3 TE50 Blueprint
Thanks, i will take your advice.
Old 08-05-2007, 08:10 PM   #12
b2tf
not here much anymore
b2tf's Avatar
New badges are definitely the way to go, keep in mind though Tickford badges have gone up to about $40, and the "XR" badge is around $25, then you need the 6 or the 8 on top of that.
2024 F150 XLT
Old 08-05-2007, 09:03 PM   #13
5 FTR 5
Made the 300 :0)
5 FTR 5's Avatar
As said before leave the badges on. The look on the face of the h---en or other that you have blown away is priceless
New Owner of a fiesta ST
5 FTR 5 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2007, 10:53 PM   #14
Soundwarp
Blue to the bone!
Soundwarp's Avatar
Thanks guys, i will be leaving them on......
220 at the rears eh :
