Old 05-05-2007, 06:08 PM   #1
xr62nv
Technical Contributor: For members who share their technical expertise. - Issue reason: Without fail he is always replying to members audio queries (often answering the same questions multiple times) and his experience comes from working as an audio installer
Default how to spot oxygn sensor problems
i was reading somewhere that oxygen sensors need replacing every 50,000kms.
My car sometimes gives off a fuel smell, can miss off the line when i accelerate heavily at times and idle occasional seems a bit rough, nothing too major and fuel economy is around 300kms 55Litres city driving no traffic
The car is a 1999 xr6 auto with 180k's the following are brand new in the car so are not an issue
- Plugs (ngk xr6 plugs)
- leads (motor craft)
- coil pack (original bosh)
- fuel filter (replaced by local mechanic unsure of brand)
- Earthing kit (stinger)
Can the o2 sensor need replacing, how would i know for sure
xr62nv is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2007, 06:13 PM   #2
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
if you feel it needs replacing , then do it .. It will improve your cars Economy abit
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2007, 06:17 PM   #3
xr62nv
thanks mate, i wouldnt know how to feel if it does though... from what i said would you think it needs it?
Old 05-05-2007, 06:17 PM   #4
ratter
ratter's Avatar
Your engine does not read from the o2 sensor when accelerating hard
An o2 sensor can be tested with a scan tool or an ocilloscope, it is better to test than guess
Pit Lane Performance
Old 05-05-2007, 06:29 PM   #5
Umineko
Karasu
Umineko's Avatar
When mine went on my old DL LTD it started idling rough and the fuel consumption at cruise went nuts, jumped from an average of 8Lt/100Km to well over 15... honestly for what the things cost I'd just change it and be done with it... then it becomes one less variable in the equation
Umineko is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2007, 12:34 PM   #6
jonbays
TL40 Wagon?
Cheap enough and easy to replace but tnothing to do with your problem. Just pull the plug and see if it makes any difference without the oxy sensor at all. Bet it doesn't. I would have said its a coil pack prob but you've been dowm that track
Old 06-05-2007, 04:59 PM   #7
jonbays
TL40 Wagon?
wrong thread whops!
Old 06-05-2007, 08:14 PM   #8
Brisbane ghia
Brisbane ghia's Avatar
i bought my oxy sensor off ebay for $55, and am about to put a set of reco injectors in my auii to see if that helps with my fuel guzzling problem.
Brisbane ghia is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2007, 08:57 PM   #9
5 FTR 5
Made the 300 :0)
5 FTR 5's Avatar
At least 100,000 Kms depending on the fuel type for oxy sensors,if worried best to get them tested as told.Didn't change mine to around 110,000 from original,didnt make to much difference.
New Owner of a fiesta ST
5 FTR 5 is offline   Reply With Quote Multi-Quote with this Post
