Old 03-05-2007, 09:07 PM   #1
chrispie123
Default dash cluster modes
just wondering if you can change modes in cluster like an ef in an au series 2 if so how?
chrispie123 is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2007, 09:32 PM   #2
Hords
Treasure your balls?
Hords's Avatar
You may want to elaborate on what you mean...
Hords is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2007, 05:21 PM   #3
chrispie123
on the ef you can do digital speed etc
Old 04-05-2007, 05:23 PM   #4
bodes-sh
yes you can do that on an au, there is a write u[ for it on fordmods, i can't remember how to get to it tho, someone may be able to help
Old 04-05-2007, 05:29 PM   #5
Mechan1k
Mechan1k's Avatar
I just revisited it myself as I wanted to test my fuel sender resistance on the move ... and also my coolant temp sensor as well ... a mutlitude of features available.
I tried looking for my thread with the search function but it couldn't find it ... I will get the details for you though.
It is something along the lines of:
Turn ignition key to ON only
(Now you need a watch for this)
Press/depress odometer button 5 times in 10 seconds (hold each time for one second).
Then release for 5 seconds
Hold for 7 seconds
Release for 5 seconds
Hold for 7 seconds.
To get out of it ... Hold for 11 seconds.
I will get the proper link though with the full details.
Old 04-05-2007, 05:29 PM   #6
5 FTR 5
Made the 300 :0)
5 FTR 5's Avatar
Ford AU Series 1 to AU Series 3 Falcon, XR, Fairmont, Fairlane, LTD and Ute Instrument Cluster Diagnostic Mode
A big thankyou goes to AU2SR - Aka Jeff for Finding this bit of hideen information, and for allowing Fordmods to host this document ! This document describes the Falcon AU Dash Diagnostic Information that is provided when the Dash is placed in Diagnostic mode
The information that is returned is displayed using the Odometer display area, and includes the information that is transferred on the ECU bus
This includes Fuel level, Fuel consumption, oil pressure, Coolant Temperature, RPM, Vehicle speed, Gear lever position, Door Ajar, and many others
Entering Diagnostic mode
The diagnostic mode can be entered by using the following method
1) With the ignition key in the off position, turn the Ignition Key to the On Position.
2) Using the Odometer Button, Press the Odometer Button Down, then release 5 Times within 10 Seconds (Note : You must be very accurate with the timing. Depress the Button for 1 second, then release for 1 second. Do this 5 Times in 10 seconds)
3) Release the Odometer Button for 5 seconds.
4) Depress the Odometer Button for 7 Seconds.
5) Release the Odometer Button for 5 Seconds.
6) Depress the Odometer Button for 7 Seconds.
You should now be within the AU Instrument Cluster Diagnostic Mode
Within Diagnostic mode, there are 19 Diagnostic Screens that are available.
At the moment we do not have enough information as to what all the screens actually are.
To Exit the Diagnostic mode, Depress the Odometer Button for 11 seconds.
More Information will be made available as to what diagnostic sections display what type of information soon !
Diagnostic Codes
Mode Top Line Bottom Line
1 Petrol in Litres (No Level Buffering) Petrol Sender Resistance (Unbuffered)
2 Coolant Temperature (Degrees C)
3 Engine RPM Vehicle Speed (KM/H)
4 Oil Pressure (Bar, 1 decimal Point) Battery Voltage (Volts)
5 Instant Fuel Consumption (L/100Km) Instant Fuel Consumption (x 0.1 Litres)
6 Fuel used since Trip Avg L/100 Reset (x 0.1L)
This Value is used to calculate the Trip computer Average Fuel consumption L/100Km Kms Travelled since Trip Avg L/100 Reset
7 Buffered Fuel Tank Level (In Litres)
Value used for Petrol Gauge Buffered Fuel Tank Lever Sender Resistance
8 Gear Position (PNRD321)
9 Unknown - 0000 Unknown - 1111 Changes on AC Clutch Engage
10 Unknown - 0000 Unknown - 1111
11 Unknown - 0000 Unknown - 1111
12 Unknown - 0
13 Unknown - 0
14 Unknown - 0000 118
15 Unknown - 0000 255
16 98 112
17 Unknown - 0 0
18 -o-d ----
Police - (Ex Chaser) Instrument Clusters
In addition to the above diagnostic modes, the Police (Chaser) Instrument clusters also have a Speedo Calibration mode.
The Police (Ex-Chaser) instrument cluster allows re-programming of the Speedo Reading, (and consequently the Odometer), so as a Precise Speedo Reading can be made.
This also means that the Speedo can be re-calibrated, when making changes to the Factory fitted wheels, Tyre Profiles, as well as altering differential Ratios.
To determine if you have a Police (Ex Chaser) Instrument Cluster fitted, try the following Routine, to enter the calibration mode.
To Calculate Calibration figures for the Police Instrument cluster, when making the above modifications, please check the Diff and Tyre Calculator Page.
Warning : Playing with the Instrument Calibration feature will modify your Speedo, and Odometer readings.
Please be sure of the consequences of changing these settings, and also Make note of your Original Calibration Setting
This will ensure that you can return the Speedo Calibration Back to its original condition, if modified.
Entering the Police Instruments Calibration Mode - (Police AU Series I models)
1) With the ignition key in the On position, press and hold the Odometer reset knob for 5 seconds, then release.
2) The Odometer will then display "SPEEDO #.#" - where #.# is the Speedo calibration Percentage, and is set to "0.0" Percent from the factory.
3) To increase the Percentage adjustment, Press the Odometer reset shaft for a short period of time (0.2 to 0.7 seconds). This will increase the adjustment by 0.5%
4) To decrease the Percentage adjustment, Press the Odometer reset shaft for a long period of time (0.8 to 4.9 seconds). This will decrease the adjustment by 0.5%
5) To exit the Speedo calibration mode, press and hold the Odometer Reset shaft for a period longer than 5 seconds.
Entering the Police Instruments Calibration Mode - (Police AU Series II - AUIII Models)
1) With the ignition key in the Off position, press and hold the Odometer reset knob
2) Turn the Ignition Switch On, and continue to hold the Reset shaft in for 5 seconds, until the cluster enters calibration mode, (Typically 5 seconds)
HOPE THIS HELPS
New Owner of a fiesta ST
5 FTR 5 is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2007, 05:30 PM   #7
Mechan1k
Mechan1k's Avatar
Woo hoo ... I was correct.
Also Mode 2 on the right hand side is DTE I found out as well.
I think there is one missing in there as there is 19 modes as well.
Will get a full listing of mine soon.
I think Mode 17 or 18 changes as well when a door is opened ... I remember one of them changed due to this.
Old 04-05-2007, 06:13 PM   #8
bodes-sh
the gear position one is a bit dodgy, lol, either that or my car is, because it doesn't change on mine
Old 04-05-2007, 06:20 PM   #9
phibza_XR6
drive it like u stole it
phibza_XR6's Avatar
yeh mine doesnt change either, could this be because mine is a manual? or should it work for both auto and manual cars
www.aufalcon.com/phibza
phibza_XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2007, 06:52 PM   #10
Mechan1k
Mechan1k's Avatar
Gear position only work on auto (this shows the highe series cluster what to show as it comes up with PRND321 in one section of the cluster)
