Old 17-04-2007, 11:40 PM   #1
Lukeyson
Right out sideways
Lukeyson's Avatar
Default Knocking sound in steering
Hi
in my AU2 XR8 sedan, of late i noticed a knocking sound sometimes when steering, especially when turning at low speeds or parking.
I am sure i saw a thread on this a while back, but cant seem to find it.
Anyone able to give me an idea on what it is ?
Luke
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2007, 12:48 AM   #2
Chippar
The Ancient Warrior
Chippar's Avatar
I think this is the post you're referring to.
http://www.fordforums.com.au/showthread.php?t=66587
Chippar is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2007, 01:29 AM   #3
Lukeyson
Right out sideways
Lukeyson's Avatar
yeah i think thats the one i was thinking of.
but yeah its not in the brakes as that thread went into, its a knock sounds that happens as you turn the wheel and you feel it in the wheel.
i will probably just get Jax to check it out
Old 18-04-2007, 12:53 PM   #4
MYEBII
MYEB
Steering rack?? out:
MYEBII is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2007, 03:37 PM   #5
RG
Back to Le Frenchy
RG's Avatar
Yep, that happened to mine when I test drove it. Replaced the rack and the problem went away.
Old 18-04-2007, 04:14 PM   #6
Cam
Stroking it...
Cam's Avatar
I have the same problem, i assumed it was the rack, so that's going to be changed as i also have a shocking vibration when turning right which i was informed is no great deal (caused by air in the lines i think?), but the knocking is rather scary!
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2007, 04:16 PM   #7
MYEBII
MYEB
the vibration sounds like the rack or power steer pump
Old 18-04-2007, 04:16 PM   #8
atec77
Originally Posted by XR8fella
Hi
Luke
rack ends or ball joints
Old 18-04-2007, 08:15 PM   #9
maestrobmw
This is the Ford fix. It is depending on whether you are feeling a shudder at low speeds (air in the power steering pump) or a 'cracking' sound at parking/low speed turning (movement of the rack housing against the crossmember). The first instance is rectified by bleeding the power steering pump. (Make sure you don't have a leaking hose or fittings or this won't work). To do this you release the serpentine belt, with the engine cold preferably, then turn the pump by hand in the direction it normally rotates for at least two minutes. If you put a torch or lamp near the reservoir whilst you do this (with the cap off) you will be likely to see air bubbles irregularly rising in the oil. When the bubbles cease, refit the belt and start the engine then switch it off within a few seconds. Let it sit for a few minutes then restart/stop again. Wait again, then take the car into a vacant car park (if possible) and do 6-8 'figure 8' manouvres. GET THIS: If it still shudders 5-7 days later - you'll need a replacement high-pressure hose.
If its the second situation: needs Never-Seize grease between the rack and crossmember, making sure the alloy of the rack and crossmember are free of burrs and the nuts retensioned to 80Nm. Never fails to fix.
Sorry about the long answer.
Cheers.
maestrobmw is offline   Reply With Quote Multi-Quote with this Post
