16-04-2007, 09:38 PM | #1 | ||
I'm having another problem with my 2000 au falcon AUTO. When doing a right turn from stationary, the car will initially pull away, attempt to change gear as the speed increases and just start revving as if it were in neutral. All power is lost. After ~2secs the transmission seems to 'engage' and the car pulls away normally. I'm guessing the transmission sometimes fails to reengage going from 1st to 2nd.
This only seems to happen on right hand turns and only occasionally. I'm guessing this is a sign of the inevitably impending doom - a failing transmission, correct? The car's almost done 200k km and has been regularly serviced. If it is the transmission, how much would I be up for, and would it be worth it (consider the cars got some paint damage and the interior is looking worse for wear). Thanks in advance for your suggestions |
16-04-2007, 09:52 PM | #2 | ||
how long ago was the trans serviced?
16-04-2007, 10:41 PM | #3 | ||
SS Grunt
Sounds a bit like it needs a service, but my first thought would be LOW trans fluid.
Shaun
The Beast has gone to a new home Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW I will also enter any part of the Forum I wish to enter. : |
17-04-2007, 07:37 AM | #4 | ||
Sorry to sort of high-jack the thread, but my 2000 AU Forte has never had a transmission service and its gone just under 300,000 all up. Its been there since the beginning. I do give it the occasional (maybe more the then occasional actually :P) thrash and its still acting like normal. Its unbelievable. Although, I am thinking of getting it serviced just to make sure it will last me a little longer or to see if it actually can be improved. Wish I could get it converted to a 5 sp. Manual!
On your troubles, yeah check the trans fluid, but if it turns out you just need to get a new box after closer inspection and maybe a service, I think its worth it. |
17-04-2007, 08:01 AM | #5 | ||
Either low fluid ... or one of the solenoids is playing up ... or check the elctrical connectors on the outside of the box ... uplug it ... and clean the connecters with WD40/RP7 or the like ... that can be another cause too.
17-04-2007, 08:55 AM | #6 | ||
The ford received a 200k km service a few weeks ago. Transmission gaskets, pans and hoses were replaced for leaks (as was the fluid).
Thus I'd be surprised if the problem anything to do with transmission fluid. Whats a solenoid? |
17-04-2007, 10:38 AM | #7 | ||
Definitely sounds like transmission oil level is slightly low. More pronounced when cold? When the car is turned the oil 'sloshes' away from the pickup momentarily - no oil, no drive. Chances are that the service was done with the transmission 'hot', so when refilling not quite enough was put in. The only other likely culprit is a dead auto - so I'd be checked the level as per specs first.
Ford Technician: AU wagon XF ute |
17-04-2007, 01:26 PM | #8 | ||
Irregular member
That's due to low auto trans oil. I had the same problem. Had it topped up and it was all fixed. The mechanic's excuse for it happening was "because we ran out of oil."
2000 AU II FAIRLANE 75th ANNIVERSARY - big and shiny My hovercraft is full of eels! Movie Car Chase of the Week: Gene Hackman driving a 1971 Pontiac LeMans to chase an elevated train in The French Connection (1971). |
17-04-2007, 07:16 PM | #9 | |||
Blown 5L coming
yup, had the same prob when i first got my wagon with only 85,000k's on it. seemed like it was slipping into neutral between 1st and 2nd. got the autotrans shop to look at it, low fluid and badly needed servicing. so take it to a specialist auto trans mechanic shop, ask them to check it out. they will have the neccessary equipment to check the trans computer and will also check the fluid levels properly. Ford have a tendancy to let their apprentices do the services, so a lot of the time they dont get done properly. well, thats my experiance anyway, maybe its just around here?
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
17-04-2007, 07:48 PM | #10 | ||
TL40 Wagon?
having had a rear servo leak in my trans I am pretty sure its low fluid. Mine would do exactly the same on a right hand uphill turn evry morning till i fixed the leak. It only took a litre of trans fluid too so all those big stains never amount to much loss but it does make a difference. save some cash buy a litre of ATF fluid a plastic hose and a 16mm thats right a god awful awkard size just to make it hard ring spanner.
