Old 13-03-2007, 05:11 PM   #1
XR Lita
XR Lita's Avatar
Default AUII XR6 Auto gearbox troubles
Ok. Latest problem is...
driving along in drive and for no reason, the car will just drop 4th gear completely, and be stuck in 3rd. Even coming to a complete stop, the car will take off in 3rd. If I drive it manually, it works ok (even though there is still no 4th gear)..
Anyone have any idea what is going on this time? I'm really over the number of problems with this car...and I've only had it for 2 months.... and 1 month of that it has been getting fixed...
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
XR Lita is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2007, 05:25 PM   #2
Hibbz
The Mod Bug Has Hit
Hibbz's Avatar
when was the last time the transmission was serviced? If more than 20,000k's i would book her in for a service to replace fluid, filter and what not should cost around the 100 mark i got it done the other day.
P.s Dont lose hope problems with cars normally happen in the first few months of you getting the car if the previous owner wasnt very good at looking after the car personally i had my car all of a month before the auto blew which cost about 2500 for a reco. I found out later my car was used to tow a big boat. So yeh dont lose hope she will come gewd.
Jake
www.aufalcon.com/jakesfalcon
Hibbz is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2007, 05:32 PM   #3
b2tf
not here much anymore
b2tf's Avatar
This is the same car that had the ECU troubles right?
Is that all 100% fixed, everything working? ECU controls the gearbox also, there is no seperate gearbox computer etc so Im wondering if youve still got lingering issues from all of that.
First port of call would be a transmission service because if there is anything wrong with the box itself, that will more than likely reveal it. Shouldnt cost any more than $100 for a full flush and inspection from a transmission joint.
If youre still having problems with that a trip to the WDS may be in order, because it sounds to me like there's still some sort of ECU bug in there.
2024 F150 XLT
Old 13-03-2007, 06:00 PM   #4
XR Lita
XR Lita's Avatar
Yes, it's the same car that had the major ECU worries. Had both the ecu module things replaced, so that part of my problem is ok...Or so I thought.
I'll have to save up some cash, and see about getting the box serviced. I'll be getting on to the car yard (AGAIN) and having another nasty chat about this car...
One day, we might actually be able to enjoy the car that we are spending money paying off each week...
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
Old 13-03-2007, 08:10 PM   #5
AUXRVIII
I'm assuming your speedo is still working ok, sounds like the ecu is putting the auto is in limp home mode, maybe the speedo signal from the instrument cluster is not reaching the ecu, or the signal to the ecu has been affected by electrical interference. Any accessories or mods done to the car? Has the cluster or ecu been removed? may have a backed out terminal in a connector.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2007, 08:55 PM   #6
XR Lita
XR Lita's Avatar
Yes speedo is working perfectly. The only accessory that has been added to the car is a new head unit, and driving lights. Both of which were on the car when we bought it. The cluster has been replaced (also before we bought it).
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
Old 13-03-2007, 08:57 PM   #7
accurate1
Before you waste any money on servicing and fluid changes get someone to scan for error codes, to tell you exactly why it's going into limp home mode. It is obviously a problem with a sensor or solenoid etc.
accurate1 is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2007, 09:05 PM   #8
Hibbz
The Mod Bug Has Hit
Hibbz's Avatar
if the car has done more than 20,000 i wouldnt call servicing it a waste of money.
my 2 cents
Jake
Old 13-03-2007, 09:11 PM   #9
accurate1
That depends on how you define servicing, if by servicing you mean fluid and filter change, that aint going to fix his problem.
Old 13-03-2007, 09:35 PM   #10
AUXRVIII
I second this.
Old 13-03-2007, 11:05 PM   #11
XR Lita
XR Lita's Avatar
I am not sure how vigilent the previous owner was in regards to servicing this car. It has only done about 90,000km and has been serviced at all the required intervals, so I would imagine that the fluid change has been done recently.
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
Old 13-03-2007, 11:34 PM   #12
Mechan1k
Mechan1k's Avatar
Sounds like one of the Solenoids is playing up.
If speedo is working it won't be the speed sensor in the auto (that should show up as P1358 from memory).
Oh ... just as a heads up for everyone else ... the cluster gets all of its information via a Serial Data Cable from the PCM (which gets all of it's information from sensors).
There's no harm in doing the auto service though.
Does the auto go back to normal after turning the vehicle off and on again???? I am presuming the auto will use other gear though if you shift it manually.
Definitely get a Scantool plugged in and look for error codes first ... the auto will report something at least.
Old 13-03-2007, 11:41 PM   #13
XR Lita
XR Lita's Avatar
Yes it goes back to normal after car is turned off..still shifts manually yes.
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
Old 13-03-2007, 11:44 PM   #14
Mechan1k
Mechan1k's Avatar
So it's an intermittant issue then ... i am still leaning towards Solenoid ... I think it's usually the S5 one that does fail.
If so ... you may as well do a service at the same time as the pan and I think the filter has to be dropped anyway to get to the solenoids in the auto.
Old 14-03-2007, 12:38 AM   #15
XR Lita
XR Lita's Avatar
Sounds like a mission....
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
Old 14-03-2007, 11:04 AM   #16
JC
JC's Avatar
In addition to all of the above, check the battery earth connection to the chassis/motor, and both battery terminals as well. If the earth is not good, the auto will go into limp home mode.
Ford Performance Club ACT
Old 14-03-2007, 06:08 PM   #17
AUXRVIII
This is totally incorrect.
This is from the workshop manual.
"Vehicle speed signal is transmitted from the vehicle speed (hall) sensor to the instrument cluster module (circuit 999-W to the cluster connector J2 pin 17). The signal is then sent from the cluster (via circuit 999 LB-W connector J2 pin 18) to the EEC (pin 58). The vehicle speed signal is also transmitted from the EEC to the BEM and the MDC via the DOL line (circuit 914). If the EEC does not receive a valid speed signal due to a fault in either the sensor, cluster or wiring then automatic transmission vehicles will default to a limp home mode as auto shift patterns require a speed input."
Also all of the clusters signals come from the individual sensors, not the PCM.
Old 14-03-2007, 06:15 PM   #18
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Totally agree with AUXRVIII.
I'd start with the connections first and then work up from there.
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 06:19 PM   #19
AUXRVIII
The fault may end up being a solenoid or something, but some testing with a multimeter and inspction of wiring costs nothing, some trans solenoids cost hundreds of dollars, but hey it's your money.
JC is also correct regarding the earths.
Old 14-03-2007, 07:08 PM   #20
XR Lita
XR Lita's Avatar
Ok. Just got home from work. Had no 4th at all today, not on the way to work, and not on the way home...
I'll have a check over the earth leads and the basic stuff...any more than that, and the car yard can pay someone to do it.
AU2 XR6 VCT...
Powered by Vortech
: T1 TE50 #094 :
Old 14-03-2007, 09:04 PM   #21
accurate1
[QUOTE=AUXRVIII]This is totally incorrect.
Good one AUXRVIII, I like information based on actual data, not on what someone believes to be correct.
Old 23-01-2013, 07:26 PM   #22
ENZ-05L
The Devil Within
ENZ-05L's Avatar
Default Re: AUII XR6 Auto gearbox troubles
so....did any of this get resolved? i am having same problem now...yeah i know, 2013...
have been in LHM for a few days now. sometimes works on restart, mostly not. my usual auto bloke i noticed, had all the wiring on the inhibitor switch stripped, melted and sitting on the passenger side cat...ffs. Went to a competitor to reinsulate wiring etc. Speed signal now good.
anyway, no idea on the problem, auto service had no bits in the tray, which is reassuring, and the servo seals were replaced and tightened. Today, i drove home without any revs or speed registering, and funnily enough, no LHM!!! it was beautiful to drive again
ENZ-05L is offline   Reply With Quote Multi-Quote with this Post
