Old 26-02-2007, 11:27 PM   #1
Captmarv
TTBOSS - 465+ RWKW!!
Default AU Flat Battery syndrome
Has anybody had a flat battery effect when the car gets to running temperature? The engine appears to charge perfectly when its cold and then tapers off and on when at proper running temperature. I ahve changed the alternator, starter motor, battery and have increased the number of earth straps etc. The problem won't go away and I am stumped at what it could be.
Any help would be appreciated. :eclipsee_
TTBOSS - 465+ RWKW 10.901sec @ 132.7mph :eclipsee_
Captmarv is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2007, 11:30 PM   #2
philstoj
philstoj's Avatar
Ive only noticed that with the AC running, the volt guage drops off a bit, but then goes up to normal when AC is off.
Still running original alternator, have changed battery over a year ago.
Old 26-02-2007, 11:38 PM   #3
Captmarv
Thanks for that. I seem to still have the problem even when the AC is off (but not as often).
Old 27-02-2007, 09:28 AM   #4
Mechan1k
Mechan1k's Avatar
Can't say I have had this issue with mine .... but with no voltmeter to check things I can't say. Although I do run a lot of electrics in the work ute ... I did get one flat battery (as it is factory LPG ... starting can take a lot out of it).
But I fixed that problem and am running a Optima Yellow Top deep cycle battery.
Old 10-03-2007, 04:36 AM   #5
302XLS
302XLS's Avatar
had a similar problem, alternator would over-charge the battery and killed it. battery would then not hold a charge. took it to an auto electrician. He changed some circuit in the alternator or to do with the charge (not to sure) for $130.00 and problem solved.
SEE MY CAR HERE
AND MAKE SURE TO VOTE!!!
302XLS is offline   Reply With Quote Multi-Quote with this Post
