Old 02-02-2007, 09:22 PM   #1
Auuteage
Default broken rear axel seal, extra damaged caused?
At some stage today, my ute did the one of the rear axel seals and the diff lost all its oil! Im told Ill have to replace the bearing as well, fair enough. Its going in tomorrow.
I was in a situation where I had to keep driving it a long long way to get home. Could I have caused any further damage?
If the mechanic comes back and says you caused this this and this by continuing to drive it, I wouldnt know enough to argue with him.
So, I turn to the knowledgable folk here...
Auuteage is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2007, 11:35 PM   #2
AU1XLS
AU1XLS's Avatar
Oil is in there for a reason quite possible you could have caused more damage
Keep your fingers & toes crossed
AU1XLS is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2007, 06:13 AM   #3
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
Unlikely. You must change the bearing, mainly because it is damaged when you remove it to fit the seal behind. If you were to drain the oil completely (unlikely) from the diff, driving could damage it. Not likely over even a couple of hundred k's.
Old 03-02-2007, 11:02 AM   #4
Auuteage
Well....
the damage was more than I expected. Dont know if it was the extra driving though.
The axel is shot, havent seen one damaged as bad they reckon, and it did look chewed out, gone completely.
Which in turn has wrecked the calipers.
Throw in braked bads and disc machining that needed doing, the bearing, the labour, a service that was due etc.$654.00 !! That hurts, but I guess thats life.
Old 03-02-2007, 11:38 AM   #5
GK
Walking with God
GK's Avatar
Originally Posted by Auuteage
Well....
So what exactly have they replaced?
It appears that they have:
Replaced: the axle, diff bearings, brake pads.
Machined the discs.
Not sure how the axle could have stuffed the calipers. If they were stuffed, wouldn't they have replaced them also?
Was it that the discs were already warped and needed machining and they threw in the new pads, or perhaps the pads were low?
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 05-02-2007, 11:06 AM   #6
Mechan1k
Mechan1k's Avatar
I had a busted axle seal ... and it did bugger all.
bearing had to be replaced at the same time as it is meant to anyway.
But my axle was fine.
I had a dirty rim from the oil ... but nothing major ... diff still had plenty of oil in it too.
Bloody hell it stank when removing the axle. Diff oil is nasty stuff indeed.
Old 05-02-2007, 11:21 AM   #7
GRNKPR
DPC PERFORMANCE Race prep
GRNKPR's Avatar
Blown a seal sure its not ice cream???????????????????????????????????
: : i will excell with the knowledge i get on here : :
FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria
Ford Performance Car ClubFord Performance Car ClubFord Performance Car ClubFord Performance Car Club
GRNKPR is offline   Reply With Quote Multi-Quote with this Post
