Old 27-01-2007, 09:37 PM   #1
au_rocket
Default My crazy yet maybe do-able plan (with a little help)
Hey all,
This is the dumbest plan possibly but i will like to see if anyone has any ideas...
The plan is a wire a switch into the car which will essentially override the TPS. Then from my new in car controls, I can manually make the car kickdown / Upshift and do other funky things...
Here is a list of what I know and what I dont know...
KNOW...
1. Kickdown operates when a voltage is sent via the TPS. (If i place a resistor in the line to slightly reduce the voltage, it will stop kickdown)
2. I can wire up a line to send the kickdown voltage from the TPS (hence forcing a downshift).
3. I can possibly hook up a switch so I can make upshifts at the reqired voltages.
DONT KNOW...
1. What is the wiring diagram for the TPS (3 pins, what do they do ?)
2. No idea what damage can be caused to the tranny
3. What the exact voltages are / what signals are sent.
If anyone has any idea, it would be much apprciated.
Cheers, Aaron.
FORD FALCON AU1 FUTURA WAGON
BMC HI-FLOW AIR FILTER, 2.5" CAT BACK REDBACK EXHAUST, 17" BA FAIRMONT GHIA WHEELS.
au_rocket is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 09:41 PM   #2
Casper
Contributing Member
Casper's Avatar
So basically you want to make something like the ESS system on the T series or the SSS on the BA/BF.. thats already in existence.. and has been done a number of times????
Older, wiser, poorer.
Old 27-01-2007, 09:45 PM   #3
Orbit
Resident Nyctophobic!!
Orbit's Avatar
retrofit some paddle shifters while your at it for that ubercool ferrari look!
Orbits secret to life: Eat less, move more!
Orbit is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 09:48 PM   #4
Mark One
A humorous statement
Mark One's Avatar
Rofl at your sig quote Orbit!
Black manual AU1 S.
S
Originally Posted by HLC
not using the search button makes the baby jesus cry.
Mark One is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 10:14 PM   #5
EvilChief
Boost Addict
Originally Posted by au_rocket
DONT KNOW...
Cheers, Aaron.
1: Pin 1: Earth
Pin 2: Signal
Pin 3: V5+
2: NFI
3: the TPS operates between V0.5+ (FCT) to V4.9+ (WOT)
there are 5 solonoids controling the transmission, 1 for each gear and 1 for line pressure. i can get u all the pin outs if u need, however i would recommend some more research into your idea, before damaging something
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
Old 27-01-2007, 10:59 PM   #6
au2sw
Blown 5L coming
au2sw's Avatar
would it not be easier to upgrade to a ba sportshift box? add a piggyback chip to tell ecu the box is ok and compatible?if doable would look better then a set of paddles and/or toggle switches.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 11:51 PM   #7
TwistedEL
TwistedEL's Avatar
Well you can do that but when I want to kick down in a hurry I just drop the shifter back to 2nd / 1st
Old 28-01-2007, 12:34 AM   #8
Jasinex
Jasinex's Avatar
ooh oohh... get the paddles and make the ferrari look.. that would be sweet and different..
EA Series 2
now with fast parts added...
Stage 1: Buy car. with money.
Stage 2: Put in Wade Custom Cam, Crow Double Valve springs, High Flow Head, 3.23 LSD, 2.5" mandrell bent with Mercury muffler and custom made CAT, iridium plugs, nolothane bushes, Koni suspension, CAI.. NOW WITH MPFI....OHHH YEAHHH!!
Stage 3: More engine mods.. and a fresh new look... can't wait.. :eclipsee_ : :Reverend:
15.43 @ 89 mph - Willowbank Raceway 07/03/2007
Jasinex is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2007, 08:07 AM   #9
Tech Trainer
Are you sure about that?
Tech Trainer's Avatar
If you are after paddles the new Mitsubishi Outlander had some alloy paddles fitted to it. They are fixed to the steering column. Could be a cool mod.
Tech Trainer is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2007, 11:37 AM   #10
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
Having a read through, i think the objective of this mod isn't so much the kickdown, what you really want to achieve is to be doing say 70km/h in 3rd gear and just boot it and it will hold the gear like a manual and not change by itself. BA's use this and i think the T3's.
The Beast has gone to a new home
Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW
I will also enter any part of the Forum I wish to enter. :
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2007, 08:35 PM   #11
au_rocket
This is exactly the point (I was a bit of the drunkies when I posted last night). The AU with the BA shifter doesnt seem to hold 1st gear anyway (I have spoken to JC about this issue). This is why im trying it a different way.
I was thinking either paddle shift (which will mean I will have a hack-manual style) or a pedal (like modding the manual pedal box) where the "clutch" will infact lock out the kickdown/upshift and therefore hold gear until i release it, ad when I release it, it will then pick the right gear. This is more the planned system as all im after is to hold gears rather than force changes.
I have run the car with the TPS and then disconnected it completly to see the effects.
If I cant figure it out now, I will go for a ESS system through the +/- volume control. Although the "pedal" system will be optimal outcome for holding gears.
Old 28-01-2007, 09:44 PM   #12
TwistedEL
TwistedEL's Avatar
The TPS controls kickdown yes but it does not keep the car from changing to the next gear at the appropriate speed, that is either speed or revs... I would suspect speed
i.e. if you put your foot to the floor it is still going to change gears just before redline
however to test your theory you could put in a clutch pedal and a cruise control clutch switch to switch a relay that d/c the TPS and runs it via a variable resistor - hook +5 to one of the outside terminals, 0v to the other outside terminal and the sensor line to the middle terminal, then adjust it until you get the effect you are after - but be aware that if you use it too much the ECU is going to learn what is happening and make the ride uncomfortable when you are just cruising
Old 29-01-2007, 12:29 PM   #13
nikos
mezzo forte
This is EXACTLY what I want to do... I'm sick to death of the car holding gears too long, and dropping down unnecessarily. I would love to use the volume buttons, but I don't know a thing about the trans electronics or how on earth to go about it.
If you get it working au_rocket, I'd love to hear how ya went
Cheers nic
nikos is offline   Reply With Quote Multi-Quote with this Post
