Old 27-01-2007, 12:39 AM   #1
josh_hartman
Default My first oil change
Ok i know what to do and everything but how much oil does the au 6 actually take. its a standard 6
josh_hartman is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 12:44 AM   #2
chief
FTF Club Moderator
chief's Avatar
It depends upon which series you have. 5 litres (AU1) or 5.5 litres (AU2-3) of the oil of your choice.
Albert Einstein:
Fords in the Park 2010
Old 27-01-2007, 08:51 AM   #3
GK
Walking with God
GK's Avatar
I'd stick in 4litres (AU1) 4.5 litres (AU2-3), run it for 1 minute, turn it off, wait another few minutes and then check the dipstick, adding as needed.
More time consuming, but at least this way your steed never gets overfilled.
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 27-01-2007, 08:58 AM   #4
nitroman
nitroman
nitroman's Avatar
Use 5 litres of 10w 30 oil with a new filter
AU1 XR8
E303 cam,Crane Rockers,Crane double valve springs,Rollmaster roller timing gears,Crow +80" pushrods,SS cold air induction, 2 1/2 inch custom exhaust,Capa flash tuner.KONI shocks.
EF fairmont wagon.
GASGAS 400 enduro.
Honda hr192 mower
nitroman is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 02:00 PM   #5
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Whats Oil ?
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 02:01 PM   #6
Casper
Contributing Member
Casper's Avatar
Originally Posted by AU2PWR
Whats Oil ?
The stuff you rub on the chick in your avatar! :evil3:
Older, wiser, poorer.
Old 27-01-2007, 03:50 PM   #7
4dlvr
4dlvr
just keep pouring in the oil until that little metal thing that u measure the oil says full, this is the most accourate and simple way
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 04:05 PM   #8
RIPGMH
RIPGMH's Avatar
I always pre-fill my oil filter, whats the concensus on this?
RIPGMH is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 04:07 PM   #9
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Ahh , Nah thats Vegemite Casper ,
AU2PWR
Old 27-01-2007, 04:14 PM   #10
poolkeeper
Its Resonating!
poolkeeper's Avatar
Vegemite??
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 04:38 PM   #11
GK
Walking with God
GK's Avatar
Never done it on any of my vehicles, but the Falcon filter and position would make it easy to do.
GK
Now gone!
On LPG
Old 27-01-2007, 05:34 PM   #12
Baboon_AU
Baboon_AU's Avatar
i have always prefilled filters unless they are upside down
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 05:41 PM   #13
RIPGMH
RIPGMH's Avatar
Its just that much longer your engine is potentially without oil pressure (depending on design of engine)
Old 27-01-2007, 05:59 PM   #14
au2sw
Blown 5L coming
au2sw's Avatar
honestly, all i do is fill to just over the full line on the dip stick, start and run the car in idle until the oil pressure light goes out plus 10 seconds, then switch it off, check the level again and top up un till full level is reached and all is good then. most acurate way of doing it. a 5.5L bottle of 10w30 should be more then enough to cover this. dont forget when doing your oil change, check ALL fluids at the same time, this includes power steer fluid, brake fluid, coolant, washer bottle, transmission oil, and diff oil. these are also important to prolonging the life of your car and avoids costly replacements.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2007, 07:31 PM   #15
GK
Walking with God
GK's Avatar
I'm not sure about that.
Doesn't the oil get pumped to the top of the engine from the sump? If the oil was pumped from the filter to the top of the engine then I would agree with you.
Perhaps someone with far more technical knowledge than myself can confirm this either way?
Cheers,
GK
Now gone!
On LPG
