Old 22-01-2007, 12:25 AM   #1
ten[A]cio[U]s
ten[A]cio[U]s's Avatar
Default Brake Upgrade?
Hey all,
I currently am throwing around some options for brake upgrades in my AU1 fairmont as the brake's it has now are utter crap..
I have noticed that all good brake packages are for AUII onwards.. none for the series I owners. I have the option of upgrading to the series II setup which would probably be my best option..
From what i have been told around $1000.. but that is a grand before i am any closer to stopping better..
If i am going to focus to make the car go fast, i should also consider making it stop too.
So far i am considering on just upgrading the front to the series II setup and slapping on some brembo's or premo's then some RDA rotors on the rear and some better pads.. Hoping for an overall cost of around $3500 max.
Bbuuuttt, what other options would there be? All input welcome.
Cheers, Matt.
Daily: AU Forte Wagon
Project: AU Fairmont - Wants to be turbo
The Family Car: 2009 G6E Turbo
Future fun: 1968 Ford Galaxie 500
ten[A]cio[U]s is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2007, 12:28 AM   #2
blackers10
blackers10's Avatar
there is a BIG brake option from cebco of which we get 10% discount on from memory??
its $2500 for the front..then another $2500 for the rear.. set of brembos
(this is all from memory may be more)
there is also the upgrade option available from FTG that was written about a while back from memory.. that IS for the AU1s
good luck!
Old 22-01-2007, 12:31 AM   #3
ten[A]cio[U]s
I like the sound of that.. $2500 is far better then i expected.
So its just a simple bring your car in the fit a set of brembo's you drive away for $2500!?
Is there any more information on the company?
Old 22-01-2007, 12:32 AM   #4
ten[A]cio[U]s
Btw thanks for the quick reply mate.
Old 22-01-2007, 12:38 AM   #5
LindsayGT
http://www.cebcobrakes.com.au/html/s...op_id=59&dsa=1
LindsayGT is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2007, 12:43 AM   #6
blackers10
blackers10's Avatar
dont say we dont help ya crazy-au hehehe
Old 22-01-2007, 12:55 AM   #7
mattp
mattp's Avatar
Chuck some Territory brakes on the front. Bigger still than the BA brakes, and probably cheaper than premo's. I know guy who is doing this, don't know much about it though, but it does still require series II stub axles and sway bar etc.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2007, 01:21 AM   #8
blackers10
blackers10's Avatar
mattp that = 1000 + the brake parts itself
he was more chasing the AU1 upgrades that didnt require the AU2 retro fit items
Old 22-01-2007, 09:34 AM   #9
xr8ute
Back on the road
xr8ute's Avatar
I would just bite the bullet and do the AUII front end upgrade so you can take advantage of all the brake options for that configuration...
In fact that is what I am doing. Should have some nice 329mm rotors and Tickford "Premium" calipers once its done.
The AUII setup as it is will brake better than than the AUI, so the $1000 is not a complete waste. But there is no reason to do the upgrade with the std rotor and caliper.....go straight to a BA/BF, or Territory, or Tickford premium rotor and caliper.
That should take a bit out of that ($1000) cost and put it towards the better brakes.
Old 22-01-2007, 09:37 AM   #10
xr8ute
Back on the road
xr8ute's Avatar
Ouch, that sounds a bit steep then if its not including any of the brake hardware. Get another quote...
Old 22-01-2007, 09:56 AM   #11
KOUPE76
OLD SKOOL BABY
KOUPE76's Avatar
Damn guys where are you getting your prices from :
Tickfords premiums sell for less than $1000 for the fronts and the rears aren't that much either.
Chec k out these Tickford Premiums and you can see what I mean.
Mick
Old 22-01-2007, 01:34 PM   #12
blackers10
blackers10's Avatar
BLUPRNT its because he has an AU1 and doesnt wanna spend a truckload upgrading to
AU2 THEN getting upgraded brakes..
Old 22-01-2007, 02:37 PM   #13
xr8ute
Back on the road
xr8ute's Avatar
Thats not with Brembo's....thats basically the Tickford Premium brake setup for the AU range.
Thats the 2 piston PBR caliper and 13"/330mm rotor as fitted OEM to SVT Cobra Mustangs, EL GT, and I suppose others (I think C4 Corvettes?).
That kit includes modified spindles, so you are basically paying for an AUI-AUII/III conversion there anyway.
Old 22-01-2007, 02:43 PM   #14
JC
JC's Avatar
As I understand it, the AU1 to AU2 brake upgrade does come with standard AU2 discs and callipers, and is fron only. So, yes you could ask for the kit to be made up using Terry brakes, and still com in at around the $1000 mark (maybe a tad more).
As the rears don't do a lot of braking, there's not much point upgrading them anyway - even the Brembo packages etc pretty much use the same disc/calliper on the rear, just with a brembo trademark on it.
Best bet is to ring FTG and ask them how much - much better option than all this speculation.
Ford Performance Club ACT
