Old 07-01-2007, 09:53 PM   #1
JoesAu
JoesAu's Avatar
Thumbs up I used Motul Engine cleaner today!
Well i serviced my car today, new oil Nulon 10w40, filter. I also tried out this stuff made by Motul called engine cleaner, it cleans sludge out, deposits, and varnishes in the motor. U put it in the motor before u dump the old oil let the motor Idle for 15minutes then dump the whole lot out the bottom. Alot of black crap came out so it worked. The car is alot smoother to drive, revs smooth. the motor sounds less noisey very surprised i'll use it all the time now, i was sceptical at the start but the guy at autobarn said my car would run smoother and it wouldnt damage my motor. Pretty happy. It was 30 buks for a little bottle 300ml's. Just posting it up cos ive never heard of anyone doing it new to me.
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2007, 10:52 PM   #2
peterban
AULTD
peterban's Avatar
I would be worried that the stuff being cleaned out could block up oil galleries etc.
Sounds as if you didn't have any problems though.
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2007, 11:40 PM   #3
mattp
mattp's Avatar
Sounds like a good result. If you want to get your car running smoother still, here's a couple of tips I got from my new mechanic, who is EXCELLENT. Get a can of AC Delco Combustion Chamber Cleaner and whilst your car is running at idle spray the entire can into your throttle body (don't get it on you if you can help it, or breathe it in, it's carcinogenic), then once you've sprayed the entire can in turn the car off and let it sit for half an hour. Then turn it back on and it will belch black smoke everywhere for 10 minutes. Voila, all the crap that was in your combustion chambers is now polluting the atmosphere instead of your engine! ;)
Also, get a 10mm spanner and check all the bolts holding your inlet manifold on, apparently it's a thick gasket and the AU's all tend to get loose bolts after a while. Mine all had at least half a turn or more to be tightened. You can't really get to one of the back ones, but tighten up all that you can. I thought I needed a new gasket a while back, but this seems to be all it was, and no other so-called mechanics thought to check. My car runs smooth as now.
Tragically, the only place you can get the AC Delco stuff is from Holden spare parts. It's about $7 a can from memory.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2007, 11:54 PM   #4
JoesAu
JoesAu's Avatar
thanks for that. might give it a go.
Old 08-01-2007, 01:00 PM   #5
Stav
Smile
Stav's Avatar
Good going Joe..just keep an eye out for rear main seal leaks as some of these eat the rubber.
Old 08-01-2007, 05:46 PM   #6
xr8 007
xr8 007's Avatar
Great thanks for that MATTP, will have to make a trip to dark terriorty to get some of this AC delco cleaner!!
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 08:02 PM   #7
walker
walker's Avatar
Yeah I have been told that the engine flush can be as good as it is bad, bad In the way of new oil leaks just appearing out of the blue.....
Its not peer presure..........Its just your turn!
XE project underway
walker is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 09:14 PM   #8
Sleeperau
Highway Taxi
It is great stuff my mechanic put me onto it as well! The warnings on the outside about being carcinogenic are pretty severe though I suppose that is why it works so well. Give "Top end clean" a go another great product made by GMC unfortunately only avaliable at holden dealers
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 10:35 PM   #9
mattp
mattp's Avatar
Hey sleeperau I suspect the reason our mechanic's both put us onto it is that we have the same mechanic, if it's Redland Bay Garage you go to. You recommended him to me ages ago, I just never got around to seeing him until recently. He's great, I have to drive over an hour to get to him but it's worth it since he knows his stuff and doesn't rip me off. So thanks!
Old 08-01-2007, 11:58 PM   #10
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
My mechanic has been put the oil cleaner treatment in the XR8 since it was new. I've never had a problem with it in the XR8. But when i brough my old Lazer he started put in the the Lazer motor it clean out alot of junk but now uses bit of oil. I guess it good to use if the motor is fairly new.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2007, 12:48 AM   #11
Sleeperau
Highway Taxi
Thumbs up
Yeah that is the one. No probs mattp good honest mechanics are hard to come by. He also uses a commercial grade engine flush as well which works well. I believe it is only supplied to retailers & not the public. I will find out what it is called but the garage is closed until the 15th.
Old 09-01-2007, 12:59 AM   #12
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
I have used the Motul Engine Cleaner and haven't had any problems with my 260,000klm EF NA 6 Cyl.
In respect of oil leaks after you use it I always think that this happens as it cleans the built up sludge which is actually stopping the oil leak in the first place.
Apparenly the Motul Oil is very good stuff as well and awesome for Turbo Cars.
$30 for a bottle, oh my god, lol, I got it free as I know the importer of the Motul Products.
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
