Old 07-01-2007, 06:07 PM   #1
PeterAU
Default Sound from rear of car when 80-100kmh
I'm getting a hum from the back of the car ( sounds like bearings ?)
when reaching around 80kmh and up only when accelerating
I have changed the oil in the diff
has anyone else had this problem?
PeterAU is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2007, 06:17 PM   #2
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Get the Diff Oil Checked
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2007, 06:19 PM   #3
Slick
Slick's Avatar
eliminate the wheel bearings by replacing them first.
It also could be a small crack/hole on the rear muffler, I've encounter the sound your describing only at 80+ km when theres pressure & on 3rd gear.
Slick is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2007, 06:49 PM   #4
PeterAU
I have replaced the Diff oil today to fords standards but no change in noise,
I did have the old owner say there could be some problems with the ball joint
Old 07-01-2007, 08:33 PM   #5
au2sw
Blown 5L coming
au2sw's Avatar
check the bearings. jack the rear up, place a stand under it so as to steady it. roll ur wheels and listen for any noise coming from the wheel. if its ok, there should be little or no noise. also grab the wheel in both hands at opposite sides and rock the tyre from side to side, there should be no movement. if there is, change ur bearings.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2007, 09:54 AM   #6
Mechan1k
Mechan1k's Avatar
Tailshaft might be a fraction out of balance as well ... also tread depth on tyres can cause a rough sound ... if tread depth is low you can get a hum/roar from them. Depends on the type of tyres you have as well.
Old 08-01-2007, 12:54 PM   #7
Stav
Smile
Stav's Avatar
You may want to check that your rear brake discs arent slightly warped.
Old 08-01-2007, 02:29 PM   #8
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
could be something in the diff, Falcons are known for diff howl/whine.
