Old 30-12-2006, 06:40 PM   #1
Maxim
Default Tyre pressure
If its not raining this wednesday I am off to WSID.
I will be running 235/60/14 street tyres. Would I benefit from lowering my tyre pressure? If so what pressure would be the best?
Maxim is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2006, 07:35 PM   #2
F6BF
I dropped my factory dunlops 245/35/19 down to 28 psi......was good for 11.9 :
FG F6 sedan
Stock 12.29 @ 113mph on mt et street tyres
XR6T Sprint winter white
XR8 Sprint winter white
GTF Octane manual
FS: ZF 6 sp trans & converter out of stock BF mk2 typhoon
F6BF is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2006, 11:14 PM   #3
FS5
i run 225/50 /16's on my au i6.i let my tyre pressure down to 22 psi and launch it @ 3800rpm and it snaps away from the line no wheelspin at all.its 60ty footers range from 1.9's /2.0's .
when i first went out to the drags i used to run the same tyres at 36psi and couldn't get it off the line without bagging it up.dropping tyre pressures definatley helps launching a car off the line heaps.
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17.
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2007, 09:06 PM   #4
ebxr8240
Performance moderator
ebxr8240's Avatar
I have run Nixons 245 X 17's at 18 Lb..
12 to 14Lb on radial slicks 245X 15's
Daily driver GTE FG..
