Old 22-11-2006, 09:36 PM   #1
frenzal56
Default au falcon steering wheel buttons
can anyone please tell me how to remove the steering wheel buttons on my au3 falcon, i have a problem with the cruise control it wont work i think it might be in the buttons on the steering wheel, trying to remoce the coast button i broke it, i dont want to break the others so any help would be good
frenzal56 is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2006, 09:40 PM   #2
EA2BA
PM me if you want
EA2BA's Avatar
First disconnect the battery for safety, you will be removing the air bag.
Look at either side of steering wheel behind at the back around the horn pad area, you will see 2 little covers, pop them out, now use a 10mm socket, although in AU i think they went to torx or security torx bits, in any event undo them.
now remove the airbag.
nect you can see the srews holding the cruise buttons on, remove them and take the switches out.
Old 22-11-2006, 09:51 PM   #3
frenzal56
so i gotta do all just to get to the circuit board that the buttons are mounted on? i was kinda hoping that i could pop the buttons out from the front......anyway is there anything i should know about removing the air bag and putting it back in....it wont inflate on me will it
Old 22-11-2006, 09:57 PM   #4
bodes-sh
it shouldn't as long as you be careful and take your time, there are quite few members on here who have done it multiple times without anything happening, just make sure you disconnect the battery
oh and by the way, welcome to the forums
Old 22-11-2006, 10:00 PM   #5
frenzal56
no worries thanks for the welcome, ill give it a go
Old 22-11-2006, 10:01 PM   #6
Casper
Contributing Member
Casper's Avatar
before you do it, check your brake lights. If the cruise stops working its usually because a brake light is out or the switch on the brake pedal is stuck on. Might save you a bit of hassles in the long run.
Older, wiser, poorer.
Old 22-11-2006, 10:02 PM   #7
bodes-sh
i guess i should add, they are 5 sided t30 torx bolts, which people have been having quite a bit of trouble getting hold of, so depending on where you are, you may be able to borrow/use one at someone's house...i'm pretty sure FTG auto salvage in melbourne let people use theirs...albeit in their carpark where they can keep an eye on you lol
Old 22-11-2006, 10:03 PM   #8
bodes-sh
just keep in mind, he said he broke one of the buttons...
Old 22-11-2006, 10:13 PM   #9
frenzal56
no worries thanks again i sould be able to get a torx ndriver to suit......also just on another note....has any one replaced the central locking remote on there au3 falcon...ive been looking for one as both of mine are broken. i cant seen to find them anywere but the ford dealer.
Old 22-11-2006, 10:20 PM   #10
EA2BA
PM me if you want
EA2BA's Avatar
ebay you can buy them cheap.
Old 22-11-2006, 10:22 PM   #11
frenzal56
thanks ill look on ebay
Old 25-11-2006, 10:09 PM   #12
fairmont au
fairmont ghia au 2 wagon
get the remote fixed its just one solder in it that breaks on or near the battery, good as new had to do both of mine works wonders now :eclipsee_
fairmont au is offline   Reply With Quote Multi-Quote with this Post
