Old 14-11-2006, 08:43 PM   #1
Auuteage
Default MIDAS and mandrel bends?
Do they do it? Might vary from shop to shop seeing they are franchised,but anyone got any experience? thanks
Auuteage is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 08:46 PM   #2
cArSiK
my local one does not. They buy pre-made bends and weld them in,
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 08:48 PM   #3
Auuteage
hmm thats a worry. Im booked in for saturday, but ill be cancelling if they use crappy crushing of pipe!
Old 14-11-2006, 09:25 PM   #4
Auuteage
Which state you in ?
Old 14-11-2006, 09:34 PM   #5
ratter
ratter's Avatar
Exhaust shops normally buy there mandrel bends in, their bending machines will normally slightly crush the pipe when bending it
Pit Lane Performance
Old 14-11-2006, 09:38 PM   #6
Auuteage
So what do I need to ask not knowing which way they do it? I dont want to compromise anything. thanks !
Old 14-11-2006, 09:44 PM   #7
Auuteage
another question:
Do exhaust places generally do one or the other? Or offer press bent or mandrel ?
Old 14-11-2006, 09:52 PM   #8
ratter
ratter's Avatar
if you have just asked for a sports system, they will probably get in a pressed bent system, especially if you have crunched the on price.
They may have ordered in a redback which comes as a mandrel bent system
If they are customising a system a mandrel system would be a lot dearer as it takes a long time to make it compared to bending pipe as they need to.
Old 14-11-2006, 11:29 PM   #9
Baboon_AU
Baboon_AU's Avatar
mandrel benders are rare and very dear, they are bigger than a 4wd. the boily's at work have one for making handrails, they dont bend the pipe like a press bender, they pull the pipe and then while its stretched it gets bent a little by little
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2006, 12:17 AM   #10
mr_xr8
Capri GT/TS50/GTR
mr_xr8's Avatar
liverpool exhaust has one
R32 GTR Rebuild
TS50 Build
mr_xr8 is offline   Reply With Quote Multi-Quote with this Post
