Old 29-10-2006, 05:58 PM   #1
RG
Back to Le Frenchy
RG's Avatar
Angry AU XR8 engine oil milky white/brown.
WTF Not happy, just wen't out to check the oil level in the XR and found the oil a milky horrible white/brown colour. I changed the oil on Thursday and all was fine and now this, and it only has 87k on it. I've spoken to where I bought it from and they are saying they will fix it, they will or they'll die, so that's ok but now i'm stuck at work with no car. So what should I be trying to get them to fix? is it just a gasket thats let go or something more sinister, reckon I could hit em up for a full rebuild.
Old 29-10-2006, 06:10 PM   #2
xr8man83
Grunt Files
xr8man83's Avatar
i would hit them up to check your heads sounds like there is water comin in
xr8man83 is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2006, 06:31 PM   #3
blackers10
blackers10's Avatar
definatly sounds like a head gasket or a water jacket has gone kaput
Old 29-10-2006, 07:46 PM   #4
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
i wouldnt put a bet on the head gaskets yet, it may be the lower manifold leaking into the engine from the water passing through the manifold and are leaking into the valley. Very uncommon for a head gasket to blow on a 5L unless its been hot. They heads may be cracked also.
But if your saying that one min it was fine and then milky i would say inlet manifold gaskets.
Shaun.
The Beast has gone to a new home
Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW
I will also enter any part of the Forum I wish to enter. :
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2006, 08:43 PM   #5
RG
Back to Le Frenchy
RG's Avatar
Started it up before I left work to see how she ran. Took longer than usual to get up oil pressure, it didn't get all the way up to where it usually sits and then it slowly started dropping so I killed it quick smart. So now I have a water in oil problem and an oil pressure problem.
Old 29-10-2006, 11:51 PM   #6
JC
JC's Avatar
The problem will just be one thing - the pressure won't get up to what it should be because it's no longer just oil.
Yours is the car that had the unichip that didn't work,isn't it? I reckon that may have caused some localised heat issues and you may have a blown head gasket. My bet is on cylinder number 4 or 7.
Ford Performance Club ACT
Old 30-10-2006, 07:58 AM   #7
NeishaXR8_347
SS Grunt
I thought these oil pressure guages were fake anyways? if your oil pressure was getting lower then the light would have came on first then the guage would drop after the light came on, unless i missed something.
Shaun.
Old 30-10-2006, 03:27 PM   #8
JC
JC's Avatar
Shaun.
I have an AU1 XR8 - the oil pressure gauge shows oil pressure (ie it works poroperly). Not sure whether Ford changed it to a warning gauge as a cost cutting measure in the AU2/3.
Old 30-10-2006, 03:36 PM   #9
jmack
hi there just had the heads off on my s3xr8 due to pressurizing of cooling system and found blown on 7 and 8 but luckily not in the oil only had 70k but what i did notice was the pass gasket on back to front .does make you wander if its the same name on the rocker or **** gaskets
jmack is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2006, 03:51 PM   #10
james22
With da Warlords
james22's Avatar
**** dude, doesn't sound good at all. Always wondered how 'healthy' my engine really is... maybe I don't want to know
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 30-10-2006, 04:30 PM   #11
RG
Back to Le Frenchy
RG's Avatar
Well it's on the back of a tow truck, off to see just what has gone wrong.
Old 30-10-2006, 04:37 PM   #12
The Mighty Red
The Mighty Red's Avatar
Good luck with it , I hope you are covered , thats one nice XR8 you have there.
The Mighty Red is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2006, 04:48 PM   #13
RG
Back to Le Frenchy
RG's Avatar
Thanks, it seems at the moment I am covered, the place I bought it from is getting it fixed, but until I get her back and she is fine without me having to spend anything is when i'll believe it.
Old 30-10-2006, 05:09 PM   #14
2002auxr6
Drunk!
2002auxr6's Avatar
hey mate how long ago did you bu your car, is it in stat warranty or do you have a aftermarket warranty?
2003 xr6 turbo
2002auxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2006, 05:11 PM   #15
RG
Back to Le Frenchy
RG's Avatar
Both, altough i've done 10k since buying it.
Old 30-10-2006, 06:32 PM   #16
NeishaXR8_347
SS Grunt
Yeh the AU2/3 are just a oil light switch and the when the light is on the gauge reads 0 and when the oil light is off it reads about 3/4's on the gauge,
Cheap *** FORD.
Old 30-10-2006, 06:50 PM   #17
NeishaXR8_347
SS Grunt
The only way to have a working gauge is to put in after market or put in a S1 cluster.
Old 30-10-2006, 08:01 PM   #18
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Hope its nothing Seriously Wrong , that thing was mint when you came Karting , strange it happend when you did the Oil //
Daniel
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 31-10-2006, 08:13 PM   #19
RG
Back to Le Frenchy
RG's Avatar
Well it's been sorted and I pick it up tomorrow. Turned out to be a leaking inlet manifold gasket so Shaun I thank you as without that knowledge, the mechanic hadn't thought of it and tried to put it down to the PCV that was stuck closed, this may not have been fixed.
Old 31-10-2006, 08:57 PM   #20
philstoj
philstoj's Avatar
Has anyone tryed this mod to a later series XR?
Id be interested to findout, as the crappy non working ones on mine give me the shits, what were ford thinking!
Old 31-10-2006, 11:35 PM   #21
XEESP_351
when i saw this thread i started to sweat..Mine has over 120k on it. Glad to hear only manifold gasket not a head problem. Any idea on wot caused the gasket to leak?
XEESP_351 is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2006, 06:53 PM   #22
NeishaXR8_347
SS Grunt
No worries mate i wasnt convinced it was a headgasket as it was all of a suddon thing, the leaky intake manifold gasket is a very common one, i work on windsors all the time at work and its common. Glad it wasnt a big fix and she is gonna be on the road so soon.
Shaun.
Old 01-11-2006, 08:31 PM   #23
RG
Back to Le Frenchy
RG's Avatar
Apparantly it's a fairly common issue with them.
Shaun.
Well it's back with me as it should but the bastards wouldn't cover the costs of changing the coolant, cheap bastards. They must be the dodgiest and tightest car yard about and yes I did tell them that. So to anyone that reads this it is probably a good idea to stay away from Stik Performance Cars in Heidelberg road Ivanhoe, Vic.
Old 01-11-2006, 08:45 PM   #24
Mechan1k
Mechan1k's Avatar
I guess you can thank Christ it was your headgaskets.
Old 05-11-2006, 09:24 AM   #25
RG
Back to Le Frenchy
RG's Avatar
Is it the cluster or just the switch/sender that would need to be replaced? I would have thought that the cluster would just be recieving the signal and if the oil pressure switch was replaced with an E series or SI pressure sender it would work.
Old 05-11-2006, 10:34 AM   #26
GK
Walking with God
GK's Avatar
I thought all you needed to do was add the sender, the guage in the cluster should be ok.
I'm sure I'll be corrected if wrong though. Pretty sure Casper knows about this!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 05-11-2006, 06:31 PM   #27
NeishaXR8_347
SS Grunt
Nah you cant just change the sended its basically the way the cluster was designed, ive spoken to vdo and have been told that it can be done but is very costly as it will basically have to be re-designed. I wish it was that simple tho it would be good.
Shaun.
Old 05-11-2006, 11:43 PM   #28
GK
Walking with God
GK's Avatar
Shaun.
No worries!
GK
Now gone!
On LPG
Old 06-11-2006, 10:40 AM   #29
NeishaXR8_347
SS Grunt
It really does suck tho you buy a xr s2 and all you get is a guage that sits in the same damn spot. you buy a ea spac and you get a fully functional one. it sucks i say.
Old 06-11-2006, 11:41 AM   #30
GK
Walking with God
GK's Avatar
True. Ford deleted some things from S1 to S2 to justify the added expense of the larger brakes, wheels and cosmetics.
I know the oil pressure guage was one, and the low radiator sensor was another. From memory, Casper had a bit of a list of what was deleted to compensate for the other upgrades.
GK
Now gone!
On LPG
