Old 24-10-2006, 06:26 PM   #1
OZFORDAU
OZFORDAU's Avatar
Talking Extractors & Dev4 Cam to go in!
Ok im looking at putting extractors on and a Dev4 cam both are JMM! Will i need a tune or a chip or something like that if i stick the cam in!
Also i have an issue as to where im going to re-locate the gas converter (And no im not removing the gas converter lol) so will i be able to sit the converter sideways???
I don't know where to put it! As the extraors are most likely going to touch/be very close to the converter!
Let me know your thoughts people!
Simon : :eclipsee_
OZFORDAU is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2006, 06:35 PM   #2
HLC
Audi S3
Mechan1k/Simon was going to put Extractors on his ute, and move the gas converter. i believe he started to do it, so have a chat to him about it.
Old 24-10-2006, 08:52 PM   #3
Stav
Smile
Stav's Avatar
I think you may need a chip depending on how your car reacts.I would say that the dev 4 cam will be much happier with a tune for sure.Do yourself a favour and get the car dynoed before you do it .Then when it is done dyno it again same dyno.. If done properly the dev 4 cam will go well.The best test will be the track.Dynos tend to lie but if you get a good independant shop it will reflect increases somewhat.Good luck with it.
Old 24-10-2006, 10:02 PM   #4
Baboon_AU
Baboon_AU's Avatar
dpends what headers you get.. i didn't have to touch mine. i got pacemaker 4499's./. but of course u want JMM
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2006, 11:12 PM   #5
FRDGAL
GT-P #0336
FRDGAL's Avatar
Stav, he's taking my old setup. He has the exhaust. He's now taking the streetfighter prototype's and the cam. I've told him that I had issues with vacuum so he is aware of that. His car may react differently though. My opinion (which I gave him) was that he should have it fitted and tuned up. I suggested the Unichip because I know Simon's budget.
You're right though, in regards to dyno's. The best test will be the track but it will also depend on the right tuner won't it. Get that cam tuned in right and it will hammer. As I said, he may have the vacuum issue or he may not. And I'm pretty sure Simon is planning on getting a hi-stall fitted aswell some time in the future so low down bog won't be an issue for him.
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST
~Tuned By Bluepower Racing~
FRDGAL is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2006, 07:32 PM   #6
Stav
Smile
Stav's Avatar
Hmm he should be fine .Despite unichips claims that idle cannot be adjusted I do know that they can adjust the stepper motor if the tuner really wants to. I hope he finds a good tuner to do the job as it makes a world of difference to making it all work well. Dynos are ok but not that much.I am going to get on a dyno soon in shootout 8 mode to see how it affects the figures.I think that just because its a six that it should all be in the same mode for fair comparison.I mean what the heck is the difference?Fudges v8 figures?Distorted six figures?
Old 25-10-2006, 08:00 PM   #7
jonbays
TL40 Wagon?
Type c Unichip can only adjust air fuel ratio and ign advance thats it nothing else. i have connected it up i know what its wired to. the only idle adjustment is really air fuel ratio. It works fine in my car with the dev3HL and Dev5 cams and was OK even with the Crow 2232549 cam at idle with just the basic A/F ratio adjustment.
The Dev4 will idle like a baby with the Unichip easy as pie
Old 26-10-2006, 12:55 AM   #8
OZFORDAU
OZFORDAU's Avatar
Default Hmmm
Well i spoke to G&D today and JMM and im preety sure they said not to get an Unichip as it wont effect the areas that we want to cocerntrate on with the Cam!
Matt @ G&D said that we'll have to get a flash tune done and that'll cost roughly about $1,400-
JMM said that the'll install it with the parts and a dyno for roughly $700-
Im wondering now if i can just chuck the cam in and leave it and then put the extractors on!
Thats all i want to dooooo!
Helpppppppppp!
Simon
Old 26-10-2006, 01:04 AM   #9
EFFalcon
Last warning
EFFalcon's Avatar
just install the stuff, see how it goes then decide.
always take what a shop tells you as advice and ONLY advice.
a unichip/edit will help but it by no means NEEDED.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 26-10-2006, 07:54 AM   #10
Stav
Smile
Stav's Avatar
If you just chuck the cam in the car will run well as long as you do not reset the computer by disconnecting the battery.I think the edit is alot better for the dev 4 .I like G&D and think Mocky is great.Seeing that they made the cam I think they would have the most probability to get it spot on.
Old 26-10-2006, 11:07 AM   #11
superroo
You can't stop the signal
superroo's Avatar
As far a i know with tunning, of course if you just put it all in it will work fine. However, if you want to get the best from the cam and the headers then a tune will be needed. Personally, i wouldn't bother with a unichip, just go get it tuned/flashed. Sure it costs more, but they'll be able to tune the car to the cam more.
PS. is this another dream like the TS50 kit simon, or will it go ahead
Old 26-10-2006, 11:28 AM   #12
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
If the JMM headers are anything like the Pacemaker 4480 headers, you will need to move the converter. I had the converter moved in mine forward so it lines up with the number 1 & 2 pipes. Messy as, but it has enough clearance.
Carless
Old 26-10-2006, 08:29 PM   #13
OZFORDAU
OZFORDAU's Avatar
Talking Woot Woot!
Yeah ok well i'll chuck them in for the time been if the cam fits straight in that is!
And later on down the track i'll get in flashed tuned!
And yes it will be going ahead! The TS50 kit was didn't go ahead cause...
A) Costed too much
B) The car looks good as it sits now!
Simon :sm_headba
Old 26-10-2006, 10:11 PM   #14
Ruger
Bseries Moderator
Ruger's Avatar
About the vacuum issue. if you have problems with vacum, Crane cams has a vacuum canistor that you can use designed especially for this. My brother has one working with a clevo which has a very large bump stick in it and it pulls up well and vacuum is good for what it is.
Long Live the Rugerspeed Primer Destroyer!
Only those that attempt the absurd achieve the impossible.
Serviced and maintained by Mascot Auto Repairs
Ruger is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 07:33 AM   #15
jonbays
TL40 Wagon?
You won't have vacum problems because of a dev4 cam. I have run dev3hl and dev5 and seen useless dev4 and none of these cams is that much of a problem at idle that the vacum is below 16" odd. with a unichip or flash tune all will be 100% fine.
Old 28-10-2006, 03:02 PM   #16
superroo
superroo's Avatar
I not sure, but jim might recomend that for a dev 4 that the valve srings be replaced, possible even new valves.
I got an article on it at home that details what he recommends to change for each dev kit. I'll have a look when i get home next and let you know.
By the way, i reckomend that you tune it when you fit it all, minimses the chance of damage, and the car will be better for it.
cheers
Old 28-10-2006, 03:42 PM   #17
jonbays
TL40 Wagon?
cheers
The Dev4 is not BIG lift. You can and useless does run stock springs and get away with it. Coil bind isn;t the problem valve float is and then only a maybe over 5000rpm which you will want to do with a dev4. JMM or crow single will sell springs to suit.
the valves themselves are fine no need to touch them just make sure the valve collets and retainers all suit the valve stem and springs you are using.
Old 28-10-2006, 05:57 PM   #18
OZFORDAU
OZFORDAU's Avatar
Talking Ok...
So am i still just chucking them straight in and seeing hows it goes?
Do i need new valve springs etc?
JMM said i do as i called them up! But if i don't need to then i don't wont to be spending extra money!
Simon :
Old 28-10-2006, 08:26 PM   #19
jonbays
TL40 Wagon?
Simon :
Brenden and I diagree on a few things and he is usually proved right but I say yes you can GET AWAY with stock AU valve springs with a Dev4 cam.
If its a manual and you like hanging off the rev limiter well thsi would 't be a good choice. It is cutting corners and this can be expensive if something goes wrong.
Old 28-10-2006, 08:33 PM   #20
Stav
Smile
Stav's Avatar
Hang on guys let me clear this up ok? I have the dev 4 cam only with standard valve springs.The car goes well.The pb is testament to this.
However when it sees 6000 rpm cutoff it idles a little lumpier for a little while.That is a big reason why I am looking for valve springs now.I think the standard springs are too weak for 6000 rpm revs and I my be getting slight valve float and lifter pump up.If the springs were a bit tighter the valvetrain would follow the cam better and rev out better.Also I do believe that more power would be coming out the back.
Be aware that the AU valve springs are alot stronger than the e series and are ok to use if you dont want to rev it all the time.
Old 28-10-2006, 08:46 PM   #21
Damo
hmm that is interesting, i'm using standard valve springs with a DEV 4 in my EF XR6. When I get to the end of the 1/4 the last time I raced the car would be ticking it's nuts off and oil pressure would drop. It would all be back to normal by the time I get to the end of the return lane.
Old 28-10-2006, 08:57 PM   #22
Stav
Smile
Stav's Avatar
Exactly like mine when I fang it.I mean really fang it.I think it is the reason why my shimms got chewed out in the begining,but my fettish is for revving its guts out again as it goes like a bullet.I am trying to learn driving it manually.For performance use it needs better springs..maybe 100 lbs on the the seat and god knows what opened spring pressures.
Old 28-10-2006, 09:32 PM   #23
xr8ute
Back on the road
xr8ute's Avatar
Stav, I reckon you would want more than 100lb's on the seat. I think the XR6 had 90lb on the seat?
Crow recommends the 7333 on their larger hydraulic lifter AU I6 cams.
125lb on the seat (1.82" installed height), and a spring rate of 330lb/in i.e. 290lbs open at 0.500" lift.
I am using these valve springs on my ute with the Crane 2030. About 132lbs at 1.80" installed height, and about 310lbs open (0.544" lift).
I am not sure how much valvetrain weight compares in the I6 OHC to the Windsor V8, would almost certainly be less, but I dont know by how much...?
Might be worth looking at some of the comp cams "beehive" springs. Would be killer with a set of titanium retainers....would certainly help the I6 rpm a bit higher.
Old 28-10-2006, 09:36 PM   #24
Stav
Smile
Stav's Avatar
Dave the six installed height is 1.625. The crow spring part number 7333-12 has 130 lbs on the seat and 300 at 500 lift This should do the trick .
Old 28-10-2006, 09:44 PM   #25
xr8ute
Back on the road
xr8ute's Avatar
Serious....only 1.625"? Bugger.
The 7333's at 1.625" install height would have a closed pressure of almost 190lbs, and 355lbs at 0.500" lift !!
Old 28-10-2006, 09:59 PM   #26
jonbays
TL40 Wagon?
Crow 7739 would be fine with a dev4 they are single spring with damper not dual but good for .600 lift and 90 to 245lb installed pressure. The 7333 are dual spring 125 to 290lb pressure and are better for say a manual and big cam bigger than dev4 really.
Old 28-10-2006, 09:59 PM   #27
FRDGAL
GT-P #0336
FRDGAL's Avatar
You don't need them. If you did, JMM would promote the Dev4 as needing them just as they do with the 3HL. Yeah it's a good idea to change them, but not absolutely necessary with that cam.
I drive mine manually all the time. It's become 2nd nature
Old 29-10-2006, 11:31 PM   #28
Smoked
Burnin Rubber
Smoked's Avatar
Im not sure I want to take you on at the Drag strip if you do it, unless I mod mine. DO IT! Gives me anexcellent reason to mod my car.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 30-10-2006, 12:19 AM   #29
OZFORDAU
OZFORDAU's Avatar
Talking Confusing??????????
Bahaha could you guys get anymore confusing then you are now lol!
Nahh its cool, everyone has been very helpfull!
Ok so this is the plan, im going to be buying the Dev4 Cam and just sticking it straight it...No tuning, no valve springs just drop it straight in!
Is this our final decision, yes or no?
And with the extractors i'll just re-locate the gas converter and we'll be all merry!
Simon out:
Old 30-10-2006, 08:09 PM   #30
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Our Decision ?
Its your car simon , Personally if it was our suggestion i would be taking your money and bolting on a Cheap Vortech Blower and Putting a Shaker on your car ,
But thats just me ,
Daniel
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
