18-10-2006, 04:59 PM | #1 | ||
The "TICK" "TICK" "TICK" coming from my I6 is driving me around the twist,I have been told that is is a crook lifter,now are these easy to replace by a nuff nuff like me who knows nuthin?
I know how to get the rocker cover off and thats it,would someone be nice enough to do a step by step write up/guide with some nice clear pics on replacing these or point we in the right direction as Im sure that I am not the only one with this annoying problem,I have tried many brands of oil but nothing seems to work. |
18-10-2006, 05:12 PM | #2 | ||
Barra Turbo > V8
Injecter pulse mayb?
-2011 XR6 Turbo Ute - Lux Pack - M6 -2022 Hyundai Tucson Highlander Diesel N Line |
18-10-2006, 05:13 PM | #3 | ||
how long has it been since you changed the oil? also when does it do it? all the time or just when it's cold?
if it's due for an oil change, run some nulon oil flush through it, then when you put the new oil in add a bottle of nulon lifter free and tune up, you can get both of these from repco, supercheap, etc...i had that similar problem with an ea i had, it did it really badly when cold, ran that stuff through it and it practically stopped |
18-10-2006, 05:22 PM | #4 | |||
Flairs - Truckers Delight
I know mine has a slight injector pulse. nothing to worry about.
18-10-2006, 05:32 PM | #5 | ||
happens between 1500rpm and 2ish especially when taking foor of accelerator,I do my oil every 5thou with filter,I have had it looked at by a local mechanic and he says lifter,just need to know how to replace them,take rocker cover off then what?
18-10-2006, 05:44 PM | #6 | |||
___________
What oil are you using at the moment? |
18-10-2006, 06:23 PM | #7 | |||
Mechanic said I may as well do all the lifters at once,I was too afraid to ask how much,not cheap I bet!! I want to do them myself but need some guidance,would someone be nice enough to do a sticky on it? |
18-10-2006, 07:59 PM | #8 | |||
as i said before...
18-10-2006, 09:08 PM | #9 | |||
18-10-2006, 09:13 PM | #10 | ||
more of an alternator
not to sure about the fuel but ive been told that a week before you do a oil change put a few litres of diesel oil in it has better cleaning properties
19-10-2006, 12:46 AM | #11 | ||
my I6 99 au lane does the same tack tack tack noise
it has done 120k kays it does it hot or cold and usually when you just lightly rev it to like 2000rpm.. and as it comes down the noise is made it also makes the noise under VERY LIGHT acclerator coasting along at say 10-20kmh in the work carpark.. ill give the lifter free a run and see what happens i just did my oil change the other day went from Castrol Edge 5w30 with pureone filter upto magnatec 10w40 with pureone filter just to see if it made a difference but it hasnt .. so will go back down to 5w30 next time
19-10-2006, 07:34 AM | #12 | |||
I might try the lifter free up when the oil is getting closer to being changed, as it says it works in about 500km |
19-10-2006, 03:41 PM | #13 | ||
im going to throw some lifter free in today and let yas know how it goes
19-10-2006, 06:37 PM | #14 | |||
19-10-2006, 06:42 PM | #15 | ||
Valve lash adjusters. My ef does it to. In the end of each rocker arm, there is a tiny little hydraulic lifter aka valve lash adjuster. $22 each retail from repco. But there is twelve of them and I've been told that dertermining which one is rooted is near impossible. $22 x 12 = lots
23-10-2006, 07:11 PM | #16 | |||
23-10-2006, 07:19 PM | #17 | ||
get the service manual from supercheap or repco etc!! only $30-$40
i reccomend the ellery manuals over haynes n gregorys
23-10-2006, 07:54 PM | #18 | ||
AULTD
I have used the nulon lifter free in my sons EF.
It certainly stopped the ticking within a couple of minutes of adding it to the oil. It used to tick on start up and was worse when cold. Now after 5000 km still nice and quiet. |
23-10-2006, 08:05 PM | #19 | ||
i think its working fine on mine.. will check again tommorow
25-10-2006, 03:30 AM | #20 | ||
yep no ticking any more
thank you Nulon Lifter free
25-10-2006, 12:13 PM | #21 | ||
I put some in mine yesterday, with a bit of luck it my lifter noise will go away too
