Old 14-09-2006, 02:20 PM   #1
BlackLS
Default Aldi Arc Welder
Just a heads up, Aldi this week are selling little arc welder for $99
55-130A, can take 2 to 3.2mm electrodes. I just bought it, gonna try it out on the weekend. Practicing on a few bits of scrap metal laying around the house.
I've never arc welded before before, although I've read up on the technique of how to arc weld ( http://www.aussieweld.com.au/arcwelding/ ) I done oxy welding though.
Eventually I'd like to be able to do my own intakes without a piece of silicone joiner after every pipe bend and straight.
Anyone have any tips they'd like to share
Chris
Old 14-09-2006, 03:15 PM   #2
Kryton
Kryton's Avatar
let us know how the welder goes.
i seen them in the cataloge but wasnt really sure about how good they would be.
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2006, 04:26 PM   #3
BlackLS
Will do.
I know its not going to be the ducks guts and everyone says buy the best tools money can buy, but if you were only to use them a few times a year a cheapie would be the better buy.
Old 14-09-2006, 05:25 PM   #4
3Toed
The Smoking Sloth™
3Toed's Avatar
I agree. I'm thinking of getting one also. It's cheap and if it does the job a few times a year then great. It'll make up for the cost of hiring one if you need it.
Originally Posted by Sloth
Filthy cars are awesome.
Amen Brother.
3Toed is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2006, 09:12 PM   #5
MO
MO's Avatar
OK yes you get what you pay for....but might I suggest you do a welding course at TAFE...the hobby one will give all the basic prac...etc.
FORD RULES OK
The more I know ppl the more I love my DOGS.
2011 SY Territory Limited Edition TS
2000 AUII SE ute IL6
MO is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2006, 09:21 PM   #6
Qwikcorty
V8 Turbo Hoon
Qwikcorty's Avatar
intakes welded out of mild exhaust tubing?
the best way ive found to arc weld them up for piping is with many small runs, or tacks. So it wont heat up the steel and blow through. it wont need much more than a sanding disc afterwards once you have had some practice.
Qwikcorty is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2006, 09:42 PM   #7
rushing on acid
rushing on acid's Avatar
just wear a bloody weldng mask and it will save you alot of pain when you dont get flash burn! i stress this because i did some arc welding a couple of years ago and it bloody hurts and it is very uncomfortable! so please wear a mask and dont try the look away trick because thats how i got flash burn.
rushing on acid is offline   Reply With Quote Multi-Quote with this Post
Old 14-09-2006, 11:49 PM   #8
BlackLS
The welder comes with a mask, with protective glass and actual welding filter glass. Also plan for gloves, and a mechanics 1 piece suit.
Also has a ghey wire brush and slag hammer in one.
Thanks of the tip.
Old 14-09-2006, 11:55 PM   #9
fmc351
let it burn
Get an auto darkening helmet. Its hard to strike the arc without sticking if you cant see it. You can do it, Ive done it many times, but if youve never arc welded before, you will be sticking the stick welder endlessly, or welding places you dont want to weld.
Biggest drama with the cheapo welders is not simply durability and poor duty times, but the amps fluctuate alot during welding. They are OK for the purpose, but watch for the amps.
Old 15-09-2006, 03:45 AM   #10
normxb
normxb's Avatar
Location: Sitting on the Dunny , Contemplating "What to do Next".
1/ "Long Pants" I used to wear shorts occasionally in summer , it's worse than sunburn on the shins.
2/ Pants "outside boots/shoes" , Dads cousin was welding one winter in "Wellies" , a piece of slag went down the boot and the harder he tried to pull off his boot the more he got burnt , sounds silly , but it happens .
3/ Ahhh , no bare feet , because you always stand on what you've just welded or on the "splatter" . (learnt that early when I was 12-13 welding my billycart ? ? ?)
4/ NEVER in a small shed , outside if you can , a few sheds have been burnt down around here because of welding & Angle Grinding
XB Futura 302 , Wife ED Fairmont ,1994 Polynesian Green.
Daughter No 1 KJ Laser , Daughter No 2 KH Laser
Keeping FORDS in the family
(Embarressment :yeees: , Son now has a "Camira" : )
"Look Right , Look Left , Look Right , BEFORE crossing Roads"
normxb is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 10:40 AM   #11
knighto42
knighto42's Avatar
I agree with both the comments above - an auto darkening helmet for the inexperienced welder is gold. Coming down in price too. (http://www.discountwelding.com.au/pr...oducts_id=3792) I bought one of these a couple of weeks back and it seems pretty good.
knighto42 is offline   Reply With Quote Multi-Quote with this Post
Old 15-09-2006, 11:13 AM   #12
XR Martin
XR Martin's Avatar
Id be more worried about the fumes you're breathing in when welding in a small shed.
2004 BA wagon RTV project.
Old 15-09-2006, 10:43 PM   #13
normxb
normxb's Avatar
It's mainly single car garages , guys pull the car out & start welding in the shed , they don't think about the mower fuel and any other combustable material lying about . A spark can start smouldering , then 1/2 hour later the sheds on fire. :
If I ever weld in the shed (3 car size), the back & front doors are always open , BUT if I'm welding anything that's "galvanised" it's always out side . The fumes that come off that are a killer.. :
Old 16-09-2006, 08:05 AM   #14
rag top
rag top's Avatar
Don't forget to make sure the kids aren't watching you weld either...
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 16-09-2006, 10:12 AM   #15
Jason[98.EL]
Jason[98.EL]'s Avatar
im a boilermaker welder by trade and all those tips that were given are 99% right
just get yourself some welding gauntlets that go half way up your arms this will help with the spatter that gets you on the arm
as for the welder i had a look at them the other day and they are actually a neat little welder you cant go wrong with it for small to medium welding jobs
blackls if you have anymore questions pm me
jason
[SIGPIC][/SIGPIC]
