Old 07-08-2006, 06:20 PM   #1
superpursuit83
KITTY Crew Member
superpursuit83's Avatar
Default Why Dyno's are only good for tuning.
Hi all, I thought I might show the different readings you can get from different dyno machines. I just had a bit more work done and a tune up. The dyno graph from the tune up shows 272rwkw and a max torque of 450nm, max.
Now the other dyno, which is my local one shows a completely different set of figures. I use my local dyno after every modification, and it is my guide only, to tell me if the mods have improved things or not. It does not really matter what the numbers say, just that they have improved since last time I went.
So again it goes to prove that the drag strip is the only real place to prove your strenght. But you can use your highest dyno reading for bragging :hihi:
Last run I did was a 13.53, I can't wait for Whoopass nights again.
Anyway, the 2 graphs below show the differences in dynos, with only 100 odd kays travelled inbetween runs.
This graph was Saturday
[IMG][/IMG]
This one was today
[IMG][/IMG]
FOR SALE
BAII Super Pursuit 0083
Awsome power by XTREME FORD TUNING 500rwkw New ALLOY Block
Awesome exhaust by THE EXHAUST CENTRE MIDLAND
Awesome Kenne Bell Supercharger setup by AGRO! and Bluepower Racing Developments
Now with full DOT approval and Permitted for road use
superpursuit83 is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2006, 06:32 PM   #2
Ruger
Bseries Moderator
Ruger's Avatar
dyno sheets make good toilet paper buddy
Long Live the Rugerspeed Primer Destroyer!
Only those that attempt the absurd achieve the impossible.
Serviced and maintained by Mascot Auto Repairs
Ruger is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2006, 07:26 PM   #3
T_Terror
The Guy You Love To Hate
Not true.
dynos will generally give a result thats within the ballpark of the real rwkw figure. Anyone hoping for exact numbers will want to be pulling their motor.
Dyno setup and location will obviously provide different results, blaming the dyno for giving a different result to another isnt much of a solution.
drag strips arent the final solution for bragging rights either. Theres more than a few people out there who cant drive very well. Getting a good launch and proper shifts dont come naturally to alot of people.
T_Terror is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2006, 07:33 PM   #4
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
Bah. every one who knows anything about Dyno's know that Dyno Dynamics and DynoJet read different by a massive amount... the DD's are a far better tuning and measurement tool than the DJ inertia dynos (which are renowned for having a fudge factor in them and reading 10-15% high)
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2006, 07:49 PM   #5
Da_Sheep
351 XC Cruise Beast
Da_Sheep's Avatar
yeah dyno figures can be way off, ive got a 351 cleveland with mild work and my dyno run showed 130Kw's and 780nm of torque to basically my engine suposedly went backwards from stock figures and the torque went through the roof, but i reckon it was the operator more than the dyno...
Da_Sheep is offline   Reply With Quote Multi-Quote with this Post
Old 07-08-2006, 08:48 PM   #6
ebxr8240
Performance moderator
ebxr8240's Avatar
You still need dyno's though!! I wouldn't give my engine too much curry until its "tuned properly"...You must know that two different brands are going to be different...Just like anything else you could have a quick 1/4 mile car and be a dog on the street....Horses for courses
Daily driver GTE FG..
Old 07-08-2006, 08:59 PM   #7
ratter
ratter's Avatar
Originally Posted by T_Terror
Not true.
So many things can affect ET, But MPH is a good indication of power to weight
Pit Lane Performance
Old 07-08-2006, 09:00 PM   #8
HLC
Audi S3
you will never get a true indication of a cars power. i can say i have 150 rwkw, and another AU Falcon has the same. but my Fairmont will be slower down the quarter cause of the extra weight. provided the cars are exactly the same. same tires, wheels, driver whatever.
there are an infinate amount of variables involved in both dyno runs and down at the strip. thats just my 2cents.
Old 08-08-2006, 07:25 AM   #9
LTDHO
The one and only
LTDHO's Avatar
That is only the case when you don't know anything about dyno's!
It takes time to find consistency amongst dynometers. It also it hard when you compare two different brands (like comparing Holden and Ford) also there are the individual settings set by the operator and to whether he wants it accurate or not.
The Dyno is an awesome machine when used correctly and can be the perfect tune.
If you want to use it as it is not designed for, then don’t expect accurate results.
Tuned by CVE Performance
Old 08-08-2006, 08:02 AM   #10
brenx
brenx's Avatar
Dyno'd also assist with car setup so when you get to the strip it's got the correct stall convertor, gears and tyre profile.
74 XB Fairmont (street car) 11.07@123.02mph. 08 LV Ford Focus XR5 (daily).
Tuned by Hallam Performance
brenx is offline   Reply With Quote Multi-Quote with this Post
