Old 15-06-2006, 05:53 PM   #1
gflane
Default eb gt hp version engine specs
can someone give me the specifications for a EB GT engine and whats the differents between the normal GT engine and the hp version.. thanks
gflane is offline   Reply With Quote Multi-Quote with this Post
Old 15-06-2006, 06:00 PM   #2
svo347
AFF's 1st DM.......
svo347's Avatar
EBGT version was exactly the same as the EDXR8 Sprint engine.
I believe the ELGT picked up a revised head and camshaft, EECV and ceramic coated Extractors
Bar the difference in gt40 tubular and explorer manifolds.
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 15-06-2006, 07:24 PM   #3
cedric
i have heard rummors of hp motors in ebgts aswell but i think there just that.
cedric is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2006, 03:51 PM   #4
DJM83
Barra Turbo > V8
DJM83's Avatar
rumours
-2011 XR6 Turbo Ute - Lux Pack - M6
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2006, 04:21 PM   #5
fnm17
fnm17's Avatar
Yep I had a guy saying he had a red EB GT with a HP engine it, apparently he said there were 5 done for vehicles that were going to be test driven by the Journo's. Is this another Urban Legend ???? Myth Busters time LOL !!!
fnm17 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2006, 04:30 PM   #6
LUXO_8
windsor user
i think there are more EB GT "P" versions than there are not...
every seccond owner you talk to claims theres to be one of the P ones
a bloke that worked over the road from my work had one and he claimed the P versions were a 347 stroker, and yep, his was "one of 5 built"
Old 16-06-2006, 08:11 PM   #7
Bossxr8
Peter Car
Bossxr8's Avatar
I thought the sprint had a different inlet manifold to EB GT, hence they were rated at 192kw while the GT was supposedly 200.
Old 16-06-2006, 08:28 PM   #8
svo347
AFF's 1st DM.......
svo347's Avatar
as i said Bar the GT40 tubular manifold and the Explorer manifold.
13.21 @107.7mph
Old 16-06-2006, 10:23 PM   #9
Bossxr8
Peter Car
Bossxr8's Avatar
You went of on a tangent about the EL which threw me off. Makes sense now.
Old 17-06-2006, 09:01 AM   #10
YOOT
YOOT's Avatar
Don't they both make around 192kw, its just that the GT was over rated. Hence the whole conspiracy surrounding that model.
YOOT is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2006, 12:55 PM   #11
ltd
Force Fed Fords
ltd's Avatar
redbook.com.au has the EBGT at 200kw and 420nm of torque, and the ED XR8 Sprint at 192kw and 388nm of torque. What both actually put out is anyones guess. I mean, can you imagine the task then of hitting that exact mark of 200kw and not say 198 or 203kw? Not bloody likely. As others have said probably a ramped up number to look good on a brochure, and prob some subtle differences to the motor.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2006, 02:17 PM   #12
YOOT
YOOT's Avatar
I think it was more black and white than that, there was an actual cover up or something. I've read about it a few times in the popular magazines. Hence why the EL GT with the same out put but different engine components and heavier, was quicker down the strip (not by much!).
Also I think most of the EB GTs read low onthe dyno for a 200kw motor, and they were all consistent with the low result. The sprint read the same number and was quoted with a lower output.
