Old 12-06-2006, 10:41 PM   #1
FTe342
FTe342's Avatar
Default Adjusting Headlights
How do I adjust the aim of the headlight (non XR)
Orange knob adjusts up/down but how do I move left/right?
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2006, 10:45 PM   #2
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
give'em a good kick left or right , that will move them ...lmao ... no no no , jokin , sorry i wouldn't have a clue with the standard au lights , xr lights i might of been able to help ya , someone here will know for sure though ..
:eclipsee_
Old 12-06-2006, 10:52 PM   #3
Orbit
Resident Nyctophobic!!
Orbit's Avatar
The best person to talk to is "the dok"
or http://www.theheadlighthospital.com.au
if you do a search on this site for the modified AU headlight thread, you will find his contact details.
There is also an adjustment diagram as well, i can't recall off the top of my head where it is though.
Hope that helps.
Orbit is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2006, 11:24 PM   #4
JC
JC's Avatar
I'm going off memory here, but I'm 90% sure my Forte lights had 2 adjusters. There should be another smaller dark grey/black knob that moves the reflector in or out (thus moving light left to right).
Ford Performance Club ACT
Old 13-06-2006, 09:51 AM   #5
str02
99 AU Futura
str02's Avatar
There is a phillips head screw adjustment for left and right buried down beside the light and accessed thru a hole for the screwdriver. Hole is in the body work, on the outside of the light and close to the front of the light, screwdriver goes in about 10-15 cm at about 20 degrees from vertical. If you get your head own low enough you can see the screw on the left side light, battery gets in the way on right. Let me know if you need a pic. From memory clockwise is adjust to right and a lot of turns need to make noticeable difference
I am not young enough to know everything
str02 is offline   Reply With Quote Multi-Quote with this Post
