Old 08-05-2006, 09:19 PM   #1
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Default The 6 Stroke Engine
http://www.autoweek.com/apps/pbcs.dl...THISWEEKSISSUE
Kinda kool - I hope that it catches on...
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2006, 09:56 PM   #2
chevypower
chevypower's Avatar
It doesn't say anything about how it works - so i can only speculate, yes 6 stroke would be less polutive than 4 stroke, yes it would use less fuel, but i am not sure about it being more efficient. You would burn less fuel because you get 1 power stroke every 6 strokes. So less power and torque too?
chevypower is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2006, 10:06 PM   #3
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
It does explain it. The 5th and 6th strokes are used for injecting water to cool the chamber and therefore being able to raise compression. But to have the 5th and 6th strokes, you would have to increase RPM to not loose power...
Old 08-05-2006, 10:11 PM   #4
Wokkas
Very interesting. Although this is not the first engine to be called a "6 stroke"!
The first was designed at the turn of the century, and had in effect two intake strokes (one drew in fresh air, with no fuel, to remove all traces of exhaust gass, then expelled it, then had another intake stroke).
The second was this: http://www.jack-brabham-engines.com/products.htm
Certainly something different.
Wokkas is offline   Reply With Quote Multi-Quote with this Post
