Old 05-05-2006, 02:21 PM   #1
5.6 litre
want more inches STROKEIT
Default AU XR8 Engine specs
hi just wondering what heads were on the 185kw xr8? and what are the differences between the series 185, 200, 220kw? sleep:
5.6 litre is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2006, 06:56 PM   #2
xd5.8l
xd5.8l's Avatar
220/250kw heads were the same.
200/185kw were just your standard run of the mill gt40's
The 220 heads got a port job, bigger STAINLESS STEEL valves. Milled for higher comp in 5L while left stock in 250kw to keep compression down.
xd5.8l is offline   Reply With Quote Multi-Quote with this Post
Old 05-05-2006, 07:58 PM   #3
5.6 litre
thanks what about the injectors are they all the same?
Old 05-05-2006, 10:58 PM   #4
xr8ute
Back on the road
xr8ute's Avatar
All AU V8's use GT40P heads (different to GT40), and as xd5.8l has said, the 220kw, and 250kw motors used modified GT40P's....
Most AU's ran 24lb/hr Bosch EV6 injectors (blue), although some very early AU's ran 19lb/hr Bosch EV6 injectors(orange). I beleive the 220/250kw motors ran a higher pressure fuel regulator.
Do a search for the difference between the 185/200/220 motors...it has been covered a million times already ;)
Old 06-05-2006, 08:02 AM   #5
5.6 litre
Thumbs up
:eclipsee_ thanks im new to these forums your help is appreciated
Old 06-05-2006, 02:26 PM   #6
12
Silhouette AU1 TS50.
12's Avatar
Not all AU V8's. Some of us lucky early T-Series owners got the SVO Y303 alloy heads. :
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947)
PIC'S OF MY
T1 TS50.
12 is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2006, 07:24 PM   #7
howesy
howesy's Avatar
Original 250KW specifications as published.
Cylinder Heads
These are the same heads as used in the 220KW engine with modified combustion chambers.Increased valve sizes and 1.7:1 ratio roller rockers.
Compression
9.6:1
220Kw 9.1:1
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2006, 07:57 PM   #8
xr8ute
Back on the road
xr8ute's Avatar
Does anyone know what valve sizes the modified heads used?
Old 08-05-2006, 05:45 PM   #9
howesy
howesy's Avatar
[QUOTE=xr8ute]Does anyone know what valve sizes the modified heads used?[/QUOTE
250KW T3 engine
inlet-: 49.3mm dia. and lift at valve was 11.99mm
opens 17 deg BTDC
close 79 deg ATDC
exhaust-: 39.4mm dia. and lift at valve was 12.00mm
opens 64 deg BBDC
close 22 deg ATDC
Old 08-05-2006, 07:43 PM   #10
xr8ute
Back on the road
xr8ute's Avatar
So that will be 1.94" inlet and 1.55" exhaust. Thanks Howesy
Old 08-05-2006, 10:45 PM   #11
5 FTR 5
Made the 300 :0)
5 FTR 5's Avatar
Cylinder Heads
Compression
9.6:1
220Kw 9.1:1
The compression on the 220 is 9:5:1
New Owner of a fiesta ST
5 FTR 5 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2006, 10:50 PM   #12
philstoj
philstoj's Avatar
I bet you will be surprised to see what sort of porting the 220/250 GT40p heads got, bugger all really.... I dont think the CNC machine broke a sweat..
Those heads only got a larger inlet valve, 1.94", the exhaust was a standard GT40P 1.54".
The Y303 heads are just an alloy version of the GT40 head, same valve size and all, nice weight saving though.
Old 08-05-2006, 10:56 PM   #13
5 FTR 5
Made the 300 :0)
5 FTR 5's Avatar
To true about the porting,I had a close look at mine when BPT where putting the upgrade cam in.The only CNC work is where the intake manifold connects with the head Bugger all done.
Old 09-05-2006, 07:10 AM   #14
xr8ute
Back on the road
xr8ute's Avatar
Stock exhaust valve for the GT40P head is actually 1.46" (1.54" is standard on the GT40).
