Old 28-03-2006, 09:33 PM   #1
S3SR
S3SR's Avatar
Default High series dash cluster
anyways im looking at installing this into my seriers III SR (forte) type and was wondering whether it will be a straight unplug and plug job or bit of tinkering... i wont do alot of tinkering otherwise my neighbours will call the cops as i swear and throw things alot........ twice now!
anyways any help and even installation pics would be appreciated
thanks
richie
S3SR is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2006, 09:51 PM   #2
Yum-Yum
My 1st set of Wings!!!
Yum-Yum's Avatar
G'day man,
you might want to PM Duffman, I think he's already been there and done that with his AU II Forte mate.
PROUD OWNER
NAROOMA BLUE
2002 AUIII XR6
:sm_headba
Yum-Yum is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2006, 09:55 PM   #3
Sleeperau
Highway Taxi
Default Cluster
thanks
richie
Hit the search button! There are threads on this. Duffman, Moya & LG are the people to speak to.
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2006, 10:42 PM   #4
ClassicAU
i have been trying to find pics, but i cant. what does a fairmont cluster have on it that a falcon doesnt?
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2006, 10:52 PM   #5
ClassicAU
i believe i have just answered my own question!
Forte
Fairmont Ghia
and if anyone finds the link to the post on installing it, could you please point me to it, cos i am also interested.
Old 29-03-2006, 11:00 PM   #6
Sleeperau
Highway Taxi
Default Tickford Version
[QUOTE=ClassicAU]i believe i have just answered my own question!
The tickford version for your series II is blue with tickford wings & the speedo goes to 240kmph.
Old 29-03-2006, 11:03 PM   #7
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
ahhhh, if only the plugs and stuff in ya car were as easy as the usb plugs on a pc huh , plug and play ..lol
:eclipsee_
Old 30-03-2006, 01:29 PM   #8
GK
Walking with God
GK's Avatar
Forte
Fairmont Ghia
Am I mistaken but is that a series 1 low dash, and a series 2 high dash?
GK
Old 30-03-2006, 01:33 PM   #9
S3SR
S3SR's Avatar
i know what to do, i gotta get the new cluster, loom or wire it myself (get a professional), change the kms reading to mine and thats it oh and some sensors might need changing or adding for the other dials
anyways something to do later i got assignments
thanks for the info guys
Old 30-03-2006, 01:41 PM   #10
ClassicAU
GK
i am pretty sure i got that from an add for a series 2 on carsales. that and mine looks exactly the same as that pic, and i have a series 2.
Old 30-03-2006, 01:41 PM   #11
chief
FTF Club Moderator
chief's Avatar
Having a Series III the odometer is stored in the ECU not in the cluster (like previous models). I will be putting one in my wagon for AU Falcon day. The change in speedo from 220 to 240km/h is calibrated in the cluster. There are a few wires you have to change. I have a wiring skematics that LG put up on how to do this mod. Now I just have to find it.
Albert Einstein:
Fords in the Park 2010
Old 30-03-2006, 03:11 PM   #12
LG
LG's Avatar
Facts
The speedo, is calculated by the Cluster.
The odometer is stored in the Cluster. More specifically the eprom.
What you can do:
Series I Cars cannot put in Series II Clusters
Series I Cars can put in High Series SI Clusters
Series II Cars can put in High Series SII/III Clusters
To Swap:
To put a high series cluster in a low series car. You need to do a few things:
- Change some pinouts in the plug
- Add a Oil Pressure Sender (*)
- Put the correct kms on (+)
- Install a Windscreen Washer Bottle with Sensor
Installing the Windscreen Washer Bottle, w/ Sensor is not neccessary, you will just get a low Washer level warning when you start up.
(*) Supposably, low series car's are meant to have an Oil Pressure Switch. This means it either tells the car, that it has pressure or not. An Oil Pressure Sender, is like a sensor, which is how the High Series Cluster's can have a guage. I found out that with my car, that it had an Oil Pressure Sender. My only guess is that AUIIIs got them. So you may need one you may not.
(+) If you are handy with electronics, you can swap the eproms over. The odometer/kms are programmed into the eprom. If you break the eprom, then your only option is to take the Cluster to VDO (or Ford maybe) to install a new eprom and program the eprom to the correct kms. Of course, you will need some proof, and they will charge you for it.
I have a few documents, of the pinouts, that need to be changed. Do a search and you might find them. Otherwise i'll post it up again.
All in all, it's a bit of hassle. If your not intermediate->advanced in electronics. I would pay someone to do it. It's well worth it. The feeling of the dash being much more sportier, and the colour. Not to mention the extra readouts, of Voltage, Oil Pressure, Gear Selection.
Old 30-03-2006, 03:41 PM   #13
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
Forte
Fairmont Ghia
My high series cluster in the fairmont has an extra LCD Screen under the speedo that displays the gear selected (May be different in Series II/III and manuals)
Fairmont
Tickford:
Forte:
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2006, 03:54 PM   #14
phildee
phildee's Avatar
Thats what my S2 Fairmont dash looks like.
My car came with a Oil pressure switch not a sender, the gauge sits in exactly the same spot as that picture always, woder if I added a sender if it would work properly?
phildee is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2006, 04:44 PM   #15
autickfordfairmont
Tickford Equiped
so in the bottom LCD it shows gear selection aswell.
Well there you go. Learn something new everyday.
Old 31-03-2006, 05:03 PM   #16
Mechan1k
Mechan1k's Avatar
LG ... top info there.
Yes the oil pressure sender is needed from Ford .... and it's a PITA to change as well ... as I have done one .... using jackstands and a creeper ... bastard of a job. Reason I replaced my oil pressure switch on the low series as it was leaking (actually spraying oil everywhere).
The high-series as a sender and is three prong from memory for the gauge to read more info ... the low series is a single pin switch for the dummy light on the dash.
Hope that helps.
Old 31-03-2006, 05:06 PM   #17
Mechan1k
Mechan1k's Avatar
Oh ... anyone out there was a SII low series cluster they don't want ... I need to test to see if my fuel gauge in the cluster is telling porkies or not.
Took my current one out to test ... and found there's only 2 plugs in the back of it ... no way of testing it ... dammit.
Also found it took me 30 minutes to figure out how to take the cluster out ... when in actual fact it's a 1 minute job to do it.
Oh ... just wondering ... I have a blank switch panel to the right of the steering coloumn on the ute .... I was wondering if it was foor boot release and fuel filler release??? Seeing as I have a ute ... I don't require them (has cabling already in the back of the panel though (might be my new fog light switch panel).
Old 31-03-2006, 05:36 PM   #18
howesy
howesy's Avatar
They only made two oil senders right across the range from the EF onwards. one for the switch and one for the guage setup. I checked the parts catalogue last week.
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2006, 09:12 PM   #19
howesy
howesy's Avatar
and the part number for the oil sender units accross the range to operate a guage is EF9D290A
Old 08-06-2006, 05:01 PM   #20
mattp
mattp's Avatar
I know this is an old thread, but maybe someone can help me anyway... If I want to replace my S1 Fairmont cluster with a S1 Tickford cluster, is it a straight swap and will everything work as normal (except obviously the odometer reading)? Any input would be appreciated! Cheers, Matt.
mattp is offline   Reply With Quote Multi-Quote with this Post
Old 08-06-2006, 05:13 PM   #21
LG
LG's Avatar
Hey matt. It should be a straight swap, and yes your right. The odo will be different. You will need to swap over your eproms. Or get a new one installed and get it reprogrammed.
What speed limit was on the AU1 XRs? If it was 220, then you should just be able to swap masks. Or if you want it for the Tickford Wings, get some custom White ones made up? But afaik, it should plug straight in!
Old 08-06-2006, 06:53 PM   #22
GK
Walking with God
GK's Avatar
Can you give me a blow by blow account of how to do it? 1 minute sounds too good to be true! LOL!
I'm seriously thinking of changing mine over to a Fairmont cluster and I want to be sure I'll be able to do it.
Sssssssshhhhhhhhhh though OK, no one tell the misses! LOL!
She'll notice the difference though when it's done!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 06-02-2007, 03:17 AM   #23
sharchar
Default help series 1 cluster swap for high series tickford
could you please send and post pin out changes for swapping clusters thankyou as unable to find pin out.
To Swap:
Cheers[/QUOTE]
sharchar is offline   Reply With Quote Multi-Quote with this Post
