Old 22-02-2006, 07:08 PM   #1
Nik
Default speedo gears for t5
i've been thinking about fitting some 3.9 diff gears and was wondering if you can get speedo gears for for a t5 simalar to the ones they use for the auto's.i don't want to go to the expense of fitting a chiptorque chip or edit to get the speedo corrected.
thanks,jake
Old 22-02-2006, 07:15 PM   #2
Stav
Smile
Stav's Avatar
Ive got the 3.73 diff ratio.Luckily I also have a navman which accurately tells me true speed.I have installed the black speedo cog and at 90 kmph my speedo still reads 100 kays. I am thinking about having it done professionally.
Old 22-02-2006, 07:16 PM   #3
svo347
AFF's 1st DM.......
svo347's Avatar
http://www.fordmods.com/forums/documents.php?doc=30
Has everything you need to get it damn close.
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
Old 23-02-2006, 09:58 PM   #4
SIKSIX
Its gone V
SIKSIX's Avatar
i like the "done professionally" part, where and how much$$...since its the sorta topic..
SIKSIX is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2006, 07:08 AM   #5
Nik
for daily driving ,the speedo being out wouldn't worry me .just when i go out to the track for a play the speed limiter will be shutting it down before i get to the end of the track.
svo347 checked that sight out but they don't have none for the au's
with the xr's running 3.45's did they change the speedo gears or was the speedo corrected by recalerbrating the computor?
Old 24-02-2006, 08:34 AM   #6
Stav
Smile
Stav's Avatar
Do you have a speed limiter? I know many people here talk about speed limiters but..my AU1 on 2 dynos hit a genuine 210 /220 kmph unedited untouched without stoping. Maybe yours too??
Old 24-02-2006, 10:42 PM   #7
Nik
no ,it's definately speed limited .i have tested it on more than one occasion.it shuts down at 4400rpm in 4 th gear. haven't tested it in 5th
