Old 19-01-2006, 09:16 PM   #1
max^power
Formerly au^ute
max^power's Avatar
Default Urgent AU Tune
Hi, apologies if this is in the wrong bit.
I Urgently need my XR6 Ute tuned, it's an AU1 and runs poorly. Can anyone recommend a shop near me (frankston, vic) that can dyno tune the ute before heathcote?
BTW: I'm not interested in an EDIT yet. Cant afford it!
max^power is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2006, 09:21 PM   #2
Casper
Contributing Member
Casper's Avatar
You cant actually "tune" the AU's. The ECU is "Self tuning" so without some sort of chip/edit theres very little that can be done.
Have you reset the ecu yet?
Older, wiser, poorer.
Old 19-01-2006, 09:25 PM   #3
max^power
Formerly au^ute
max^power's Avatar
i don't think so. Ok, well where could i get a quote for the edit? it's a real dog and im not happy with the delays.
Old 19-01-2006, 09:38 PM   #4
Samantha
The edit probably won't help if there is something wrong with engine, elec etc. What does running poorly mean exactly?
Samantha is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2006, 09:47 PM   #5
Casper
Contributing Member
Casper's Avatar
disconnect the battery for an hour, then reconnect and go through the ecu setting process on aufalcon... then make a decision.
Old 19-01-2006, 09:49 PM   #6
Mark351
Built Ford Tough
Mark351's Avatar
...and if it's still rough, take it to a Ford deaerl, or someone who can read the fault codes from the eCU. You might have a faulty sensor, etc that the computer has diagnosed as a problem.
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread
'55 F100, just a roller at the moment, new project
Silver MY12 Volkswagen Amarok
Mark351 is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2006, 10:09 PM   #7
max^power
Formerly au^ute
max^power's Avatar
1) crap fuel economy - 350k per tank is not good enough after intake mods. used to get 500.
2) real slow take off, slower than i recall it being.
i suppose it's ok, mainly worried about the fuel economy and the slooow take off.
will try to reset the ECU and see what happens.
Thanks Casper, Samantha and DeathXR
Old 19-01-2006, 11:32 PM   #8
Casper
Contributing Member
Casper's Avatar
sounds oh so familier... do what DeathXR said, get the faults read asap... I'm betting MAP sensor is fried.
Old 19-01-2006, 11:35 PM   #9
max^power
Formerly au^ute
max^power's Avatar
alright, you guys have been right before, ill book it in to make sure i get ut fixed
Old 20-01-2006, 05:15 PM   #10
GK
Walking with God
GK's Avatar
Please let us know what was wrong, and what was done to fix it, and the costs involved. Also please tell us who fixed it!
Hope it all gets sorted for you soon.
GK
Old 20-01-2006, 05:21 PM   #11
rodderz
rodderz's Avatar
Being self tuning, it will be most likely a component that has failed
You could also check any leads, throttle body, wires or sensors as casper said for any obvious damage, may save a bit of time and $$ at the workshop.
rodderz is offline   Reply With Quote Multi-Quote with this Post
Old 20-01-2006, 06:18 PM   #12
max^power
Formerly au^ute
max^power's Avatar
I'll post the solution, when i get one!
Old 20-01-2006, 09:07 PM   #13
GK
Walking with God
GK's Avatar
What exactly does the MAP sensor do, what would be the signs (other than these blasted codes that Ford need to find!) that it is failed, where is it located, how much would it cost to replace?
GK
Old 20-01-2006, 09:20 PM   #14
Casper
Contributing Member
Casper's Avatar
it measures the air coming into the engine and adjusts the fuel accordingly. If its dead you will be running very rich on the default maps in the ECU and have loss of power and heaps of fuel usage.
MAP sensor is a little over $100 I think. Bugger to fit though
Old 20-01-2006, 10:07 PM   #15
ratter
ratter's Avatar
Map sensor measures manifold vacuum, the harder you accelerate the less vacuum so it senses this and the computer knows to increase injector duration. A faulty map sensor can cause the motor to run too rich or too lean, depending on what signal (if any) it is giving out.
Most good workshops have scan tools that can read the codes, you do not really have to go back to just a dealer.
Not all problems will show as a trouble code.
Pit Lane Performance
Old 20-01-2006, 10:12 PM   #16
GK
Walking with God
GK's Avatar
Ok thanks,
This is different from the oxygen sensor right? The oxygen sensor measures gases leaving the engine right?
GK
P.S This is my 300th post! Alright!
Old 20-01-2006, 10:43 PM   #17
ratter
ratter's Avatar
The O2 sensor is basically a voltage generator, but it creates a voltage according to how much O2 is present in the exhaust gases, the leaner the mixture the less voltage it produces, but it is not foolproof, a lean missfire could sometimes show as a too rich (high voltage) due to unburnt fuel going through the exhaust.
Old 21-01-2006, 09:37 AM   #18
TCK-098
TCK-098's Avatar
Just a quick question so when i got my chip done the first tme and the car rang simular to au ^ute then got charged $300 to get the thing back to where it was before i had the chip done would that mean that my map sensor is fooked too or is it the fact that people cant tune cars right.
sorry to jump onto threat just curious.
18 T6 Multivan
03 Ba Xr turbo 300rwkw
TCK-098 is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2006, 09:47 AM   #19
Casper
Contributing Member
Casper's Avatar
What sort of chip is it?
Oh, and its almost impossible to have the factory ECU running better then a Chipped ECU unless the tune was so horridly bad as to be undrivable. If the chip tune was worse than factory then the tune in it was a shocker.
Old 21-01-2006, 10:18 AM   #20
TCK-098
TCK-098's Avatar
Shane the chip is a chiptorque unit i had the car back there on thursday but as usaul the car feels like its pulling harder but come to the freaking dyno and it should be showing at least 140 not 135.
Oh and BA Xr6's are getting further behind my rear bumber so i think it might have done something to the tune.
18 T6 Multivan
Old 21-01-2006, 11:46 AM   #21
Casper
Contributing Member
Casper's Avatar
Just ignore the dyno numbers... they are both pointless and irrelevant. What you run today will not be what you run tomorrow.. what you run on one dyno will not be the same as you run on another dyno 10 minutes later. If you want an indication of power they are fine.. do a run, do the mod or add the chip, do another run. Compare the lines (ignore the numbers). Run 2 should be better. look for odd flatspots or dips.. try and fix. Thats the end of the use of a dyno.
If you want to know what it can really do in the real world.... take it to the track.
Old 21-01-2006, 08:42 PM   #22
max^power
Formerly au^ute
max^power's Avatar
i only want a dyno so i can see how fooked the engine is hahahah
Old 21-01-2006, 09:20 PM   #23
ratter
ratter's Avatar
If you just want a dyno read out
In Frankston you could try
APS
LRH
Ultratune
Chevs (carrum downs)
Auto gas connection (Carrum downs)
Theres probably more, but the above list all have dyno's although none have the soft ware to adjust your computer
Old 21-01-2006, 09:30 PM   #24
max^power
Formerly au^ute
max^power's Avatar
Thanks ratter, ill get the error codes first, then ill consider the dyno. Any idea on cost?
Old 21-01-2006, 09:32 PM   #25
ratter
ratter's Avatar
I'm guessing a computer scan will cost you $30-40, but if you want diagnostics on top of that it would be more.
A dyno run may set you back $60 for a few power runs
Old 21-01-2006, 11:06 PM   #26
max^power
Formerly au^ute
max^power's Avatar
Thanks mate. ill book it in asap.
