Old 10-01-2006, 06:07 PM   #1
harwoodj
Default How to fix rattle in centre air vent?
My centre LHS air vent has started to rattle. My AU2 has 104,000km and this pain in the neck problem has just started. If I press on the vent with my hand it will stop. Is this a common problem and are the vents easy to remove?
JH
Old 10-01-2006, 08:15 PM   #2
HLC
Audi S3
just bang it a few times. that usually fixes most rattles :| *shrug*
Old 10-01-2006, 08:53 PM   #3
duaned
duaned's Avatar
Unfortunatley the AU Falcon just seems to be plagued with rattles, I have one coming from somewhere down low near the front passenger's door/footwell. It is an annoying crack sound when going over a sharp bump or hard accelaration from rest. Anyone had this issue? :
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 08:54 PM   #4
galaxy xr8
Giddy up.
galaxy xr8's Avatar
The good ol AU air vent rattle, mine's been doing this for a while but it's the centre vent's.
Old 10-01-2006, 09:27 PM   #5
08XR8
Mine rattles too but only the centre two when the aircon is running
08XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2006, 09:31 PM   #6
cArSiK
Same here , standard AU feature im afraid....
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 13-01-2006, 08:04 PM   #7
The Soothsayer
Default Re:
Greetings fellow AU kinko's,
My AUII developed this problem after the facia around the radio/vents was replaced under warranty.....
....it is a naasty problem, especially (as previously mentioned) when the AC is blowing on you in the middle of summer.....
What I did to fix it was to get a can of Wynn's SILICONE LUBE spray and carefully sprayed it (using little pipe attachment) into where the actual vent rotates in the dash.....
Be frugal in application and everything will remain neat and tidy (no bits of dust and crud sticking on the vent if the lube is plastered everywhere....
Just out of interest, when you take a car back for warranty work to fix squeaks and rattles, this is what the dealer mules do, nothing technical like pulling apart dashboards, they just gum up the problem with Silicone lube...
I did mine some time ago and the problem went straight away and hasn't come back.
Soothsayer
Old 14-01-2006, 01:52 PM   #8
notty1978
NOTTY
notty1978's Avatar
just put a bit of paper or cardboard in the side
all fixed
notty1978 is offline   Reply With Quote Multi-Quote with this Post
Old 14-01-2006, 04:36 PM   #9
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
I used a bit of Blue tack and I don't move them around much. Stopped the noise.
I like the sound of Soothsayer's fix.
Uncle Ken
Old 15-01-2006, 12:21 PM   #10
DJM83
Barra Turbo > V8
DJM83's Avatar
yeah i have the same problem wen a/c is on i just tilted vent up put a tiny bit of blue tack under then tiled it back down again it stopped and u can still adjust the air flow aswell
-2011 XR6 Turbo Ute - Lux Pack - M6
DJM83 is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2006, 11:24 PM   #11
GK
Walking with God
GK's Avatar
Soothsayer
I have 2 Au's, both with these rattles. I also have a can of CRC silicone spray in the shed!!!!
Thanks for the advice, I'll give it a go tomorrow.
GK
Old 16-01-2006, 11:54 PM   #12
cArSiK
why do AU dashes make all sorts of noises in extreem heat / extreem cold? Hate to think what our cars will sound like in 10 years.........
Old 17-01-2006, 12:08 AM   #13
max^power
Formerly au^ute
max^power's Avatar
some of us may not be able to hear by then!
max^power is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2006, 08:57 AM   #14
Mechan1k
Mechan1k's Avatar
I just turn the stereo up ... then other things rattle .
Old 18-01-2006, 06:30 AM   #15
romaniac
holla at cha boy
romaniac's Avatar
mine started getting a hissing noise coming out of the left passenger side vent just recently. I dont know what the problem is, and its not the stereo cos i turned it off and it still does it. I found that when i accelerate above 2000rpm it goes away.
romaniac is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2006, 08:29 AM   #16
cArSiK
it will be a vaccume leak
Old 18-01-2006, 11:43 AM   #17
romaniac
holla at cha boy
romaniac's Avatar
and how do i fix that? lol
Old 18-01-2006, 11:51 AM   #18
EA2BA
PM me if you want
EA2BA's Avatar
with the car ideling look behind the glovebox for the noise, then seal the offending little plastic pipe. (might make your car idle smoother too)
Old 18-01-2006, 01:03 PM   #19
AnthonyQLD
Boss power
AnthonyQLD's Avatar
e I wish it would of been an optional feature
AnthonyQLD is offline   Reply With Quote Multi-Quote with this Post
