Old 02-01-2006, 09:50 PM   #1
francisjones
Default fan problems au fairlane
both thermo fans are only working intermittently. have checked all fusable links and relays, all seem ok. start the car up and one or two fans kick in when they should, but after a few minutes they both stop. you can stop the vehicle and start it again, and they may or may not come on, there appears to be no ryhme or reason to it. doesn't matter if the climate control is turned on or off, doesn't matter if it's a warm day or not, load doesn't seem to affect it, and neither do driving conditions. this one is driving me mad. any help please?
Old 17-01-2006, 11:59 PM   #2
Davo3460
if it,s not getting hot why worry mate
Davo3460 is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2006, 12:02 AM   #3
LUXO_8
windsor user
they arent suposed to go all the time
they were working perfectly fine.......
Old 18-01-2006, 02:16 PM   #4
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
If your really concerned and want them going, just bypass the thrmo sensor and hard wire the fans in, but be warned, they aren't the quietest.
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2006, 03:28 PM   #5
Mechan1k
Mechan1k's Avatar
That's what I thought as well ... aren't they switched on when it reached a certain temperature ... and off again, etc.
Old 18-01-2006, 03:35 PM   #6
richo77
richo77's Avatar
Is there a simple way to test if the fans are working? I dont have a voltmeter.. I've never heard the fans come on since i've had my car..
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 18-01-2006, 04:00 PM   #7
EA2BA
PM me if you want
EA2BA's Avatar
when you start the car they are supposed to kick on then back off, its a self test and proves they work, if they never come on and the temp stays normal dont worry, if you put the a/c on at least one fan should kick in if they are working correctly however.
Old 18-01-2006, 04:23 PM   #8
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
If you wanna test that the temp sensor is working fine (and if you havent noticed your car overheating) you can idle you car for about 10-15mins (if its cold idle for longer).
That should heat the engine enough to kick over the fans.
Old 19-01-2006, 10:53 PM   #9
zoomzoom
there is a coupleof test to do
put the a.c on full speed and the fans should come on
like prevuios report if the car is not over heating dont worry
zoomzoom is offline   Reply With Quote Multi-Quote with this Post
