Old 20-12-2005, 10:40 PM   #1
stiddy
stiddy's Avatar
Default Gearbox Q..
hey all,
Just out of curiosity, will a T5 from an e-series go in and work fine in an AU?
I was told that they wouldnt, because the AU one is slightly longer than the E series.. or something to that effect, maybe different linkage length?
I have a feeling my gbox is having a slow and painful death, starting to make a funny whine, and goes all stiff when trying to shift.. sometimes wont slot into gear...
and yeah if im up for a new box would an e series one fit, or not?
mainly because i can get it exchanged for $565.. but they are e series boxes..
and are there any really differences in ratios?? or anything else i should know??
Old 20-12-2005, 11:05 PM   #2
Stav
Smile
Stav's Avatar
Get the same type of box.It has a unique ratio in it that gets it off the line harder than a au vct manual box ...If you dont ,you may lose some launching power.
Old 20-12-2005, 11:08 PM   #3
stiddy
stiddy's Avatar
well in that case where does exchanged for an AU box?
might have to ask FTG autosalvage..
Old 20-12-2005, 11:08 PM   #4
Racecraft
they call me Tibbo
Racecraft's Avatar
they are different.. i dont think the ratios are different until the BA xr6T box but it is a physical difference that makes the AU and Eseries incompatable
Old 20-12-2005, 11:13 PM   #5
Stav
Smile
Stav's Avatar
I know that the auxr6 hp did get a better first gear than any other of the au range.My 3.73 diff ratio in my auto cannot beat its first gear which is standard.
Old 20-12-2005, 11:13 PM   #6
Stav
Smile
Stav's Avatar
Make sure its out of an xr6 hp not vct or forte ..etc
Old 20-12-2005, 11:14 PM   #7
stiddy
stiddy's Avatar
Thanks Racecraft..
so now im on the the hunt for an AU box.. will and AU XR8 box bolt up?? or they different too...
Old 20-12-2005, 11:20 PM   #8
Racecraft
they call me Tibbo
Racecraft's Avatar
here you go, from the gbox guru himself :-
Originally Posted by wbt56
The extension housing is 2" longer. The non VCT cars have the same internals as an EL XR6. (high helix gearset). The VCT cars have a hybrid main case/cluster/first gear. It has a taller first gear, and a factory short shifter. No other changes, no stronger, complete box still interchangeable with others. Ben.
Old 20-12-2005, 11:28 PM   #9
stiddy
stiddy's Avatar
awsome, thanks guys..
Old 21-12-2005, 03:58 PM   #10
stiddy
stiddy's Avatar
ok, gave Malwood a call....
$2200 to have my T5 rebuilt into a Z spec T5, and also clutch diametre upgraded to a 10.5in plate.. works out $400 cheaper then having it rebuilt to a standard T5..
and its also the same box they use in the V8 brute utes..
But to go with this i NEED 3.9 diff gears to make it really work , either that or i get nearly 80-90km/h in 1st lol..
pricing seems alright.. i havent really got anything to compare it to..
lol so there is $3200 worth of gearbox and diff.. thats an expensive way to go about getting a few 10ths faster down the 1/4 LOL
Old 21-12-2005, 08:00 PM   #11
Racecraft
they call me Tibbo
Racecraft's Avatar
The Mal Wood jobbie you have been quoted is the exact spec box OED666 has in his ED, although he has 4.11's his ED Futura with an XR cam was good for 14.7's @ Willowbank.. Dropped from 16.4 with the auto and 3.08 single spinner
Old 21-12-2005, 08:35 PM   #12
xr8 007
xr8 007's Avatar
Sorry to hijack the thread but how common are AU automatic boxes to pop?? Just wondering cause i read in the owners manual and it says that they dont really need "servicing". (What THEEEEEEEEEE). In reality how often should they be serviced?
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2005, 08:41 PM   #13
Casper
Contributing Member
Casper's Avatar
No, it didnt. The XR6 HP manual gearbox is IDENTICAL in every way to every other AU manual I6 gearbox EXCEPT the VCT. It was the VCT that got the unique 1st gear. Forte and XR6 HP had a 3.35 first gear, VCT had a 3.05.
Oddly enough, there was even a ED XR6's had a 3.25 1st gear ratio (just to confuse it even more)
Older, wiser, poorer.
Old 21-12-2005, 08:48 PM   #14
Casper
Contributing Member
Casper's Avatar
By the book.. new fluid every 50,000kms. They usually need a full rebuild around 200,000kms but it can vary quite a bit between different cars and drivers.
Old 21-12-2005, 09:02 PM   #15
HLC
Audi S3
my auto box is shot. sometimes doesnt grab reverse straight away when doing like a 3 point turn, so i chuck it in reverse and give the gas a squirt, and like a fraction of a second later there is this big clunk as it like locks in and the wheels spin LOL kinda like D-slamming i guess, but in reverse!
Old 22-12-2005, 07:47 AM   #16
Mechan1k
Mechan1k's Avatar
Auto servicing depends on the type of driving you do.
My ute gets an auto service every 15,000-20,000km ... but i do heavy driving ... under load nad also towing ... gets driven everyday at least 150km per day.
An aftermarket oil cooler is a great investment for auto gearbox longevity too.
I have time where I take off on a COLD morning (just after i bought the ute) ... it would start in 1st gear in D ... then go to select 2nd ... but get nothing .. and just rev like it's in Neutral. The box needed warming up though ... and new fluid too.
I have done the odd R-slamming like HLC has mentioned ... on a very warm day and trying to do a 3-point turn ... it takes 2-3 seconds to select R after shifting quickly from D ... and I can vouch mucho smoke can be made this way too ... LOL.
My gearbox didn't like it very much though.
I am up to 140,000km now (bought it 6 months ago with 109,000km) ... and I am finding that there are little bits in the bottom on the gearbox pan everytime I change the fluid .. and the fluid is black/brown at 20,000km .... not a good sign at all.
I think my next autobox will be built stronger ... with a hi-stall ... and decent oil cooler installed.
My next option is a full flush of the current autobox and see if that makes things better ... I know the torque converter holds 2-3 litres of fluid that doesn't come out when the fluid is changed ... as old fluid is constantly being circulated around the auto all the time.
Old 22-12-2005, 09:20 PM   #17
rag top
rag top's Avatar
Tip if you get the auto rebuilt - Get a dipstick fitted (think an EF one fits) whilst it is out of the car. I had it done, now I can check fluid level and quality. Dealer servicing only looked at fluid level, didn't care the fluid was no longer red.
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
rag top is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 03:33 PM   #18
LG
LG's Avatar
I'll have my AUTO box up for sale soon, for anyone interested. NSW or VIC.
~80,000 kms, top condition. Will be available in NSW around march, and then i'll bring it back to VIC. $750
Old 23-12-2005, 04:35 PM   #19
Stav
Smile
Stav's Avatar
bibliography..max ellery ford 1998-2002
page 156 5 speed manual specifications.
4.0 vct 1st 3.05:1 2nd 1.99:1 3rd 1.29:1 4th 1.00:1 5th .72:1
4.0 hp 1st 3.35:1 2nd 1.93:1 3rd 1.29:1 4th 1.00:1 5th .73:1
5.0 1st 2.95:1 2nd 1.94:1 3rd 1.34:1 4th 1.00:1 5th .73:1
This is quoted from the book.
So which is quicker off the line?Hp..it has stiffer gearing for off the mark.
Old 23-12-2005, 04:44 PM   #20
Casper
Contributing Member
Casper's Avatar
The HP is the better geared of course... but its the same as a forte gearbox too. The 3.35 first gear is the standard first gear across the AU range.
The VCT (and the V8's) had the unique gearing, not the HP.
Should read "Just get the standard I6 gearbox, it has the best first gear for take-offs"
No, it got the Forte gearbox ratios. The VCT and V8 got the taller 1st gears.
Old 23-12-2005, 11:29 PM   #21
Stav
Smile
Stav's Avatar
My bad...this book doesnt refer to the other cars in the range in that section...it is only part of the picture..true.
Old 24-12-2005, 08:08 AM   #22
stiddy
stiddy's Avatar
well the Z spec T5, has the same ratios as the V8.. the reason the 3.9 diff gears is needed..
Old 24-12-2005, 12:57 PM   #23
OED666
OED666's Avatar
yea, the z spec boxes have a 2.94 first gear, and i think the normal t5 either has a 3.3, or 3.5... so 3.9's will get your car launching nicely.
You could also ask for a taller 5th gear. Mines 0.63, the normal is 0.68. With 3.9's i was doing 1950rpm at 100km/h, and with 4.11's its doing 2050rpm at 100km/h.
You will still get to around 165km/h in 4th on the limiter, and you will easily lose your licence.
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2005, 05:30 PM   #24
justa6
justa6
justa6's Avatar
I've got a z spec in mine with standard xr6 ute diff (3.45 i think) and there's no way it will get anywhere near 80-90km in first. Wish it did though, it would be like a v8supercar
justa6 is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2005, 10:53 PM   #25
RspecAU
BA GT-P Owner
RspecAU's Avatar
Fix it soon mate cause i had those symptons for about two month after giving it hard time at calder and then with no warning it smashed second gear off the cluster gear.
DAILY DRIVER/TRACK CAR
BUILD NUMBER 006
Old 27-12-2005, 03:48 AM   #26
stiddy
stiddy's Avatar
i like my 4th gear as it is.. pulls really strongly all the way to 190+km/h
3rd peaks out at aobut 150-155km/h (usually just touch the rev limiter as i cross the line) there is no speed limiter..
and im sitting on about 2200rpm on 110-115km/h
as is at the moment..
1st = 60km/h
2nd = 100km/h
3rd = 150km/h
4th = 190km/h
5th = pushing way over 200 clicks..
im crossing the line at 150km/h, the work from GnD will see me going (alot) faster.. and the last thing i need is to be changing to 5th before the end of the 1/4..
Old 27-12-2005, 06:08 PM   #27
Whoosha
AU DIE HARD
Whoosha's Avatar
have a simular problem with my xr 8 runs out in 3rd across line with 235 45 17 street tyers. I have pinched a set of kevs 255 50 16s for the AFF Drags . they stand nearly
55ml taller ,hopen that will do the trick ..... Best so far 14.08 @ 96.74 mph
hope to catch you there..........
Whoosha
Originally Posted by Riksta
Old 04-01-2006, 02:08 PM   #28
stiddy
stiddy's Avatar
ok, well its not my gearbox.. YET..
how do I know this.. because the diff let go last night..
ive never heard anything like it, big smashing, crunching, grinding and banging, with some god awful shuddering.. was intense, was about 2 streets from home..
and about 15 people came running to the end of their driveways to see what was going on..
now im up for a new diff, so its getting a new centre, lsd and 3.7 diff ratios....
after the diff gets done the car will get all buffed up and a clear coat over it, get the interior all steam cleaned shampooed and what not then and after that Im fairly sure its going up for sale..
