Old 19-12-2005, 11:33 AM   #1
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
Default Noise From Air Con Fan
Hey guys,
The other day nice and hot, Climate control on, it switch to suck from inside automatically as it did i heard something suck into the fan. Now couldnt see anything on the floor that was sucked up but could have been a small bit of plastic or something. It sucked up made a nasty noise like when you stick paper in a fan. Now it has changed to a deeper noise like its really stuck in there or the fan is out of whack. Is there any easy way to get to the fan on an AU Fairmont without removeing the Entire dash????
Thanks Guys.
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2005, 04:06 PM   #2
Autocade
I have had a similar problem where leaves get sucked in from the external air intake
Pull down the glove box lid until it stops then on the right side (i think) there is a small plastic stopper
Gently (but firmly)pull in the edge of the glove compartment tray until it clears the stopper
It will then will fall down so you can access the fan duct hole
Stick your hand in or get someone with a small hand so you can spin the fan around(making sure you have the ignition switched off!)
Each time I have done this the leaves have dropped down so I was able to grab them and pull them out
I hope this helps you fix your problem
Autocade is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2005, 04:52 PM   #3
AnthonyQLD
Boss power
AnthonyQLD's Avatar
I have a leaf stuck in mine at the moment. thanks for the tips autocade
AnthonyQLD is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2005, 09:09 PM   #4
Baboon_AU
Baboon_AU's Avatar
autocade, i will remember this when it happens to my car, which it most probably will
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2005, 10:19 PM   #5
chief
FTF Club Moderator
chief's Avatar
Thanks Autocad, Have a similar problem and just had to leave it until the leaves feel down. Thanks for that.
Albert Einstein:
Fords in the Park 2010
Old 21-12-2005, 04:07 PM   #6
autickfordfairmont
Tickford Equiped
yeah pulled the glove box out and had a look around but couldnt get up in there or find anywhere to stick my hand, could be those extra Big Macs ive been eating lately. I will get someone with a smaller hand to have a crack for me. Thanks for the info.
Old 21-12-2005, 05:27 PM   #7
autickfordfairmont
Tickford Equiped
FIXED THE PROBLEM!!!!!
When i pulled it out before i didnt realise that the White flap actually opened up. :
Turned the car on and to re-circulate and it opened up, turned off, got the Fuel Receipt out (sucked up from inside) and all fixed. Slight problem when i turned it back on, there was a small grinding noise from up near the centre vents. Quickly flicked it off, but then it would only blow on the demister. Just put the flap up and down a couple more times and its working perfect, no noise, no problems. Thanks for the help. Very much appreciated.
Damn Gregories Manual said i had to pull the dash out : .
Thanks again.
Old 03-01-2006, 06:23 PM   #8
MonsoonBlue
Is the fan setup different in an AUII Futura? No problems pulling the glove box lid out of the way as Auotcade suggested (one tab on each side of the lid), but everything is boxed in and no fan in sight. Have had a leaf stuck in there for a month which is driving me up the wall.
MonsoonBlue is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2006, 01:34 PM   #9
autickfordfairmont
Tickford Equiped
Take the glove box out, Turn the car on and the air con. Turn it to recirculate, you should see the flap open up.
Switch it all off, manualy open and remove leaf.
Old 05-01-2006, 02:49 PM   #10
MonsoonBlue
: Thanks, that did the trick.
