Old 05-12-2005, 04:48 PM   #1
hambo_12
Default Spark plug / leads
Im Going to order spark plugs and leads from JMM, but thought I'd ask first what people prefer, is there a better alternative to JMM supplied ones, and is there really much difference from what ford supplied it with?
Old 05-12-2005, 05:03 PM   #2
cArSiK
Hey mate
Ive recently done plugs / leads on my VCT . I used NGK-R (ZGR6B-11) plugs and Bosch Spiral wound leads (B6228I). Realy cant comment on JMM leads / plugs but my combo works well and came in under $65.
James
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2005, 05:12 PM   #3
hambo_12
Originally Posted by cArSiK
Hey mate
James
Hey James,
Sounds good, much cheaper than JMM, plus I could probably get them local. Where would you normally get them from?
Reece.
Old 05-12-2005, 05:28 PM   #4
cArSiK
I got mine from my local AutoOne but any parts store will be able to supply them...
As for fitting , make sure the engine is cool , take out the intake snorkel and get your hand in that way....it was quite easy actually , took 20 minutes...
James
Old 05-12-2005, 05:54 PM   #5
hambo_12
Any real differences between aftermarket plugs / leads?
Old 05-12-2005, 07:19 PM   #6
Casper
Contributing Member
Casper's Avatar
talk to useless.. he's played with more sparkplugs then I've changed in every car I've ever owned.
I have the JMM plugs.. they seem to work well I must admit.
Older, wiser, poorer.
Old 05-12-2005, 07:21 PM   #7
hambo_12
Cool, ill send a PM now...
Old 05-12-2005, 08:24 PM   #8
HLC
Audi S3
dont send a PM hahahaha i wanna see what the differences are hahahahahaah
Old 06-12-2005, 05:40 AM   #9
hambo_12
Well, just to let you know, Useless recommended ngk spark plugs and topgun leads, so I might give them a go...
Old 06-12-2005, 07:02 AM   #10
Stav
Smile
Stav's Avatar
Ngk zg as state above seem to be quite good. I found the topgun leads made my car less missy.What youll notice with the zg series is that they are longer than the normal au vehicles ,so go deeper into cylinder.
Old 06-12-2005, 08:51 AM   #11
hambo_12
Heres the email I recieved:
AU-2 XR6 to Feb. 2000 takes kit number TG6160
AU2- XR6 March 2000 on takes kit number TG6175
Both of these kits are also available in our " MAX" series which is suitable for all gas conversions and is made from a high temperature silicone cable, rated 300 degrees C plus. ( black only).
Also Available in " Pro Series" either 8.8mm spiral wire or 10mm spiral wire. Double insulated, high temperature silicone cable rated at 250 degrees C plus. Suitable for both race track or on street applications. Available in red, blue, black or yellow.
What do you make of it, do I go the 'max' series or 'pro' series? Differences??
Old 16-12-2005, 11:18 PM   #12
au yes u
1st post g,day all freaks. Has anyone used the platinum plugs off e bay, ac delco for $55 a set or this intake mod chip4, the same guy has a fuel saver which ionises the fuel as it goes past the box attached to the fuel line. Snake oil, dare i mention peter brock and black box or does this work
au yes u is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2005, 08:59 PM   #13
HLC
Audi S3
nice user name :
ionises fuel? peter brock and the polariser rings a bell yes : i dunno anything about the plugs though.
Old 16-01-2006, 01:15 PM   #14
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
So useless, can these be put into a standard AU 6 ok or will they cause problems. I have been told that the only difference between Standard 6 NGK replacements and NGK XR6 replacements is the temperature rating???
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2006, 07:11 PM   #15
buickman
buickman
buickman's Avatar
The longer tipped 1's would run hotter. I cannot see it could harm in the short term if moving parts don't touch. But if your doing high speed h/way distances regulary chances are you might run to lean & burn a valve.
Old 16-01-2006, 07:15 PM   #16
LG
LG's Avatar
Apparantely the 4L 6 guys, are getting great results with the BA MKII XR6T plugs from Ford.
They use the NGK Denso plug.
Old 16-01-2006, 07:32 PM   #17
snortingboost
XF Ghia. All snorted out
Guy's, the best thing to be using is the standard plug fwhich ford recomends and for the leads a set from queensland ignition leads will be the best. Those longer tipped plugs your talking about were meant for the EA-ED only and will only cause problems if used in an AU. Trust me i work for ford and i've seen what happens. The only time you play around with plugs is when you double the engines output ie turbocharging and usually you down grade the heat range by one number. In any case ford has spent countless man hours developing the correct plug for that engine. Trust me.
snortingboost is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2006, 07:38 PM   #18
Casper
Contributing Member
Casper's Avatar
Would that be the same countless manhours they spent developing brake rotors that warp at an insane rate, 4x4 height forte suspension that rides like the QE2 on a rough sea and an exhaust manifold that rates up there with a piece of pipe with 7 holes in it?
Ford run to a budget just like every car manufacturer.
As for the "long tipped" sparks causing problems... I have autolites, I've seen exactly how far they sit in the head (checked it at JMM on their bench on a bare head) and have 40,000kms of problem free driving to say they are fine. 40,000kms... hell, thats more the some BA's have gone with 3 engines straight from Ford...trust me.
Old 16-01-2006, 08:27 PM   #19
mattsAU1
mattsAU1's Avatar
Hey mate
James
Roger that, got the same gear in my AU1 and they work like a charm
mattsAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2006, 08:34 PM   #20
stiddy
stiddy's Avatar
Nicely said, well put. :
I have NGK Iridium plugs from memory, with standard leads (for now), have done 50,000k's on them with no dramas so far. the engine seemed to idle a little different after the plugs went in, thats about the only difference I noticed.
Next i'll try some Denso ones or Autolites, and definately get some new 10mm leads.
Old 16-01-2006, 09:47 PM   #21
Whoosha
AU DIE HARD
Whoosha's Avatar
[QUOTE=stiddy]Nicely said, well put. :
Yep what he said 2 sets of rotors X 70.000ks :sm_headba
Originally Posted by Riksta
Old 16-01-2006, 09:47 PM   #22
SVR73
Mr Polish
Just about to remove standard leads with Eagle eliminator 9mm spiral's
I used a set of these in the forte. Seemed to start better and run well and no more radio troubles
Plugs- I have pretty much stuck to bosch super 4 or platinum but am thinking about splitfire's
Since the engine is stock (for now), probably no point spending the dough on autolite's or JMM's
Detailology colour fx detail studio and R&D Lab
SA's leader in auto detailing and paint treatments
SVR73 is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2006, 09:56 PM   #23
EBFalcs
get plugs with pure copper cores, thay make an awesome spark. but beware they cause alot of interference and can even stop your cars computer from functioning, they'r mainly used on inboard speed boats i think
EBFalcs is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2006, 01:19 AM   #24
Sleeperau
Highway Taxi
Thumbs up BA MK ii XR6 Turbo plugs
The denso irridiums work well. They idle well & are good at revs BUT I would like to try the autolites which seem great value for money & my old mechanic has been using them for years & swears by them, besides some knowledgeable individuals have rated them including JMM. Overall I am very happy with the Denso plugs.
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
Old 19-01-2006, 05:52 PM   #25
Stav
Smile
Stav's Avatar
Gee guys ...time locked up and I missed this thread.
The zg series plugs are longer than standard au ones. I can say what I experienced.As far as iridiums go,on my car the denso ones made my car go quicker. The ngk iridium plugs made my car go very slow.So I threw them straight in the bin .yes I know 100 odd dollars they cost so dont buy the crap.
On the flipside ,I recently bought some more denso iridiums and the car was misfiring.So I have come to the conclusion that spark plug manufacturers have no real quality controls in place so that I can say one plug is better than the other.Spark plug manufacturers need to stop skimping and doing there job properly to provide more consistent quality.
On the other hand,ive heard no complaints about autolite jim mock plugs ,so they might be worth a go.
If you have a good set in you car now my advice is keep them until you find something that makes your car quicker.
Old 20-01-2006, 01:38 PM   #26
autickfordfairmont
Tickford Equiped
So can i run the ZG series in a Standard AU 6 without any problems???
Old 20-01-2006, 08:14 PM   #27
Baboon_AU
Baboon_AU's Avatar
i just did a service today consisting of new plugs, oil and filter with a general inspection of everything else.
i purchased NGK long life iridium spark plugs (because i run an EGAS LPG setup) for around $20 each, so it cost $120 for all 6 but i soon found out that it was well worth it after seeing the condition of the plugs i pulled out.. i am very happy with my choice.
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 01:41 PM   #28
autickfordfairmont
Tickford Equiped
Old 29-01-2006, 02:08 PM   #29
boodek
Ferret
Without spending stacks of money, what then is a suitable and economical combination of plugs and leads for an AU3 which does family car duty?
boodek is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2006, 02:14 PM   #30
jonbays
TL40 Wagon?
I have been happy with denso iridiums, NGK iridiums and top gun leads. The JMM Autolite 985 also work well surprisingly.
