Old 10-10-2005, 03:22 PM   #1
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Default Excel users... help me
I'm going to try my best to explain what I wanna do In Excel to sort something out...
I have a list of numbers, some are repeated more than twice. I want a formula that counts the numbers and the number that comes up the most I want to display in a different cell, and not how many times it comes up.
I couldn't find anything in Excel that could help. If someone does, let me know, I'm blind.
Carless
Old 10-10-2005, 03:27 PM   #2
Danny
GT4.
Danny's Avatar
No excel Users here. Try the Hyundai Forums :
Sorry, Im pretty shockin at Excel too
Old 10-10-2005, 03:30 PM   #3
TheSneakiness
Adapt or perish...
You know, that's pretty clever. Would've never thought of that.
Carless
Old 10-10-2005, 03:30 PM   #4
EA2BA
PM me if you want
EA2BA's Avatar
well first you have to unique the list, then use that to count the numbers, then use a formula base on the outcome to show only those numbers, more then likely a macro i think is what you need, if it is to be repeated many times.
my username AThotmail.com on MSN if you want some help.
Old 10-10-2005, 03:31 PM   #5
TheSneakiness
Adapt or perish...
Hang on, I found something that may work...
Carless
Old 10-10-2005, 03:31 PM   #6
neb
hibernating
neb's Avatar
easy one.... =MODE
neb is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2005, 03:32 PM   #7
TheSneakiness
Adapt or perish...
Originally Posted by neb
easy one.... =MODE
Yeah, found it eventually. :
Carless
Old 10-10-2005, 03:33 PM   #8
FPV329
Workin' for the BOSS
FPV329's Avatar
Do a google search, I needed a calender to save a lot of typing and a quick search got me a beauty!
Ford Racing Alloy Blocked Custom Built 5.4L Harrop/Eaton Blown Boss BA XR
FPV329 is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2005, 03:36 PM   #9
BlackLS
Perhaps the =Count fucntion?
This sounds like a statistical problem.
in any cell press = then, up the top, next to the tick, cross, and fx; there should be a pull down box, click on "more functions."
Edit - forget about me...
Old 10-10-2005, 03:51 PM   #10
TheSneakiness
Adapt or perish...
New one for y'all...
I want to get values between two numbers, and display how many times a number between the two numbers comes up.
Carless
Old 10-10-2005, 03:54 PM   #11
EA2BA
PM me if you want
EA2BA's Avatar
so you have 10 and 200 you want a count how many numbers are between 10 and 200 in a random list of numbers ?
Old 10-10-2005, 03:55 PM   #12
TheSneakiness
Adapt or perish...
This is my example...
I have a list of shed widths. I want to see how many widths come up between two numbers (9 and 10). So 9.01, 9.02 comes in between those two numbers.
Carless
Old 10-10-2005, 03:57 PM   #13
EA2BA
PM me if you want
EA2BA's Avatar
well i usually just run a colum besdie to mark the cells with an "X" that meet the criteria I want then count the "X"'s if it is a quick thing.
Old 10-10-2005, 04:00 PM   #14
TheSneakiness
Adapt or perish...
Make it sound so easy. I'm trying to be a smart-****.
Carless
Old 10-10-2005, 04:09 PM   #15
EA2BA
PM me if you want
EA2BA's Avatar
=IF(A2>=9,IF(A2<=10,"X",""),"")
then run a count =COUNTIF(B2:B8,"X")
Old 10-10-2005, 04:12 PM   #16
TheSneakiness
Adapt or perish...
I'll try that then. Thanks.
EDIT - Some reason I can't get it to count properly. I'll just keep trying different things.
Carless
Old 10-10-2005, 04:42 PM   #17
DOC
DOC's Avatar
hI Bud, i work on excel for a living ( in my spare time ) PM me you email address and ill send you an email for you to attach it to and send to me, and ill sort it 2 seconds for you and even get it to sing happy birthday if you want
cheers
Pete
try this ( adjust range to suit )
. =COUNTIF(D824,">9")-COUNTIF(D824,">10")
the faces should be a semi colan ( : )
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 10-10-2005, 06:08 PM   #18
FGX-351
Supercharged Mang-mobile
FGX-351's Avatar
press f5 or f4(cant remember which one) then under reference type in caps X97:L97, then press enter or click ok...ect then when ur back in the spreadsheet after that press tab once i think it will come up m97, then push ctrl, alt, shift and click on the wizard bar graph icon at the top right at the same time, then a hidden version of flight simulator will open up, left click is forward, right click is backward and steering is with the mouse....enjoy
09/00 VX HSV XU6 Build #0001 of 0171
http://fordforums.com.au/showthread....09#post5571209
-- Best E/T: |14.982 @92.12mph | R/T:0.013 | 60' 2.213| 330: 6.283 | 1/8: 9.624 @ 73.17mph | 1000: 12.529 | 25Deg, N/A Hum, 1010mb | Willowbank Raceway 7/12/16
Tickford EL Falcon XR6 RIP
-- Factory Manual
-- Best E/T: |14.991 @ 92.71mph | R/T: 0.607 | 60': 2.215 | 660': 9.665 |13Deg, 86%H, 1024mb, 184RA @ Willowbank Raceway
FGX-351 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2005, 08:42 AM   #19
TheSneakiness
Adapt or perish...
cheers
Pete
OK, thanks Pete. If this works, I'll have to buy something off you.
EDIT - Well, well, well. It worked. Order coming Pete.
Carless
Old 11-10-2005, 11:38 AM   #20
DOC
DOC's Avatar
AU11_SE_UTE, Just read this, my help was not in intention of getting an order, the help was without obligation and you should only order if thats what you want to do, not because of any help.
Glad it worked for you and if you need any further help ( without obligation ) please ask.
Pete
Old 11-10-2005, 01:46 PM   #21
TheSneakiness
Adapt or perish...
Pete
Nah, nah, nah. I need to get some cleaning products anyway Pete. Gotta have the car looking good for Indy.
Carless
