Old 07-10-2005, 09:51 PM   #1
Bucknaked
Bucknaked's Avatar
Default New PC Help
Today I bought some new parts for a computer upgrade. The motherboard has SATA. On the board theres 1 IDE channel. Without trying to sound too much like a ********, does that mean I need SATA drives and my old ATA drives won't work?
Old 07-10-2005, 09:56 PM   #2
parawolf
beep beep
You should be able to use the 1 IDE channel which allows for two ATA devices (disk, dvd burner, etc). SATA is available if you want to use a SATA interfaced disk. With this set up you will be limited to 2 ATA devices.
Nothing to see here, move along, move along...
parawolf is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2005, 10:00 PM   #3
Bucknaked
Bucknaked's Avatar
So for now, i can get away with DVD drive and 1 hard drive on the same channel. Just mean's I need to fork out later for some SATA hard drives.
Thanks
Old 07-10-2005, 10:01 PM   #4
parawolf
beep beep
yup yup... or get a PCI IDE controller.... which might set you back about $40 for a non RAID one...
Old 07-10-2005, 10:56 PM   #5
ImpulseTaco
n00b
ImpulseTaco's Avatar
Just be sure you set one device (usually hard drive) to master and the other (usually CD) to slave. Theres jumpers on the back where the cable plugs in, and should be a diagram on the top label.
You will want to invest in a SATA hard drive eventually. They read/write MUCH faster than regular IDE drives do.
Jordon
'03 Tacoma 4x4
ImpulseTaco is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2005, 07:30 AM   #6
Bucknaked
Bucknaked's Avatar
Thanks guys for your help. I will go out to day and pick up PCI IDE controller.
Old 08-10-2005, 12:00 PM   #7
jonk
"So for now, i can get away with DVD drive and 1 hard drive on the same channel"
It's not a 'real good idea' (being polite) to share HDD channels around, even with other peripherals within the PC.
Otherwise, a HDD sharing with a DVD for instance, will clog the channel and slow down the sys' when using the DVD at the same time. Kind of defeats the purpose of the upgrade, doesn't it ...
jonk is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2005, 08:18 PM   #8
Bucknaked
Bucknaked's Avatar
Thanks for your suggestion. I spoke to the guy I bought the parts from and he thinkks theres a sata adapter that go onto the board and converts to IDE.
I'm now running both hard drives on 1 channel. I have my network up and running so I'm going to install my dvd drive and dvd burner into my other machine and install across the network. My plan is to buy a sata drive and use my existing ide 160 gb as a back up. Going to get one of those hard disk cases which plugs into your pc via USB. I can use it to back up my system.
Another question i have an its for anyone with an ASUS board. This is the board I have. P5GD1 Pro. Found my fan is running at low speeds. I'm trying to increase the speed, but can't find an option that allows me to do this. I am using probe which tells me cpu temp and fan speeds, but doesn't give me an option to increase it. i have a feeling that the standard fans issued with the cpu's can't have the fan speed changed manually.
I think I will invest in an after market cooler.
