Hi Guys, Thanks for having a look at my thread. I removed the Throttle body to clean it opened it right up to give it a good old clean. Refitted it sparkling clean, when I started her up it came up with ESP SYSTEM FAULT and was running rough as a badgers ****. I'm wondering if I've damaged the Thottle Body? any advice would be greatly appreciated. Cheers.
First check all connections are in the correct place and tight
Scan for codes copy clear then rescan |
These are electronic (ie not cable operated) ?? If you've opened the throttle body butterfly by hand, then you're likely to cause damage..
if you are really lucky it may just need to relearn the calibration. plenty of videos on Utube to help you.
