Old 27-08-2007, 02:07 PM   #1
AUIIISR
AUIIISR's Avatar
Default Changing Batteries in AU
My old battery final packed it in, ive got a new one sitting here just want to know off anyone is there anything that needs to be done when I do change over Re. Radio and ECU
AUIIISR is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2007, 02:32 PM   #2
private9
www.TUFFCARPARTS.com
private9's Avatar
ECU takes a few minutes at least to reset after you disconnect the battery, so if you're quick you won't have to do the ECU learning procedure.
I can't remember if the radio code resets as soon as you disconnect the battery. It's quick to do though, so just make sure you actually have the code handy!
Old 27-08-2007, 02:41 PM   #3
AUIIISR
AUIIISR's Avatar
Well itll be dead, it was flat as a tack last night when i went start it and only just put the new one in it, radio code I have no probs there
Old 27-08-2007, 03:38 PM   #4
whiskers
gone fishing
whiskers's Avatar
you will need to have the radio code handy to get it working.
whiskers is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2007, 07:08 PM   #5
SirHenry
Falcon Unbelievable!
Be careful of the base idle upon reset if yours is anything like mine it can be extremely stubborn. (Mine eventually needed to be hooked up to Ford)
SirHenry is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2007, 08:22 PM   #6
hilly1981
I did mine recently and had it disconnected probably for around 4-5mins in total.
All I had was my head unit reset (no biggie as expected), and when I switched the ignition on it just said 'base'.
I then started her up and she was all good.
1998 AU Falcon Forte (Galaxy Blue, Sedan, 2.5" Lukey cat-back sports exhaust - single muffler, 17" ROH Wheels, 235/45/17 tyres, Low Suspension, Rear Spoiler, XR6T Intake Snorkel, K&N Panel Filter)
hilly1981 is offline   Reply With Quote Multi-Quote with this Post
Old 29-08-2007, 05:58 PM   #7
TMB490
20's are cool
TMB490's Avatar
if you dont have the radio code and dont want the ecu to forget everything judt go down to supercheap or any of those places and buy a memory minder there only around 3 dollars with a 'battery included!!'
TMB490 is offline   Reply With Quote Multi-Quote with this Post
