Old 22-05-2018, 06:01 PM   #1
Crazy Dazz
Talking Burning your Oil (instead of changing)
One of the sites I worked on, they converted the trucks to burn their oil.
ie such that the oil was continuously being replenished and never changed.
Obviously that works best in a diesel.
Could you implement that on a petrol engined car?
Would the engine management cope/ adapt?
How would you implement it?
Where would you take the oil feed from, bottom of sump or bottom of oil-filter?
How would it be injected? Presumably it would clog existing petrol injectors. Could it be rigged to spray into in the manifold at WOT?
And what would the effect be?
The advantage on the fleet was burning the oil inplace of diesel, but mostly to avoid the cost of changing and disposing of the oil.
Not sure, but I imagine the filters were still changed, as they would still have caught all the dirt and particulates.
Old 22-05-2018, 07:23 PM   #2
Itsme
Experienced Member
Itsme's Avatar
Default Re: Burning your Oil (instead of changing)
In my opinion sounds illegal and contravenes EPA laws.
Itsme is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2018, 07:48 PM   #3
XByoot
Yep, and the O2 sensors and Cat would be none too happy either.
XByoot is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2018, 07:52 PM   #4
That sounds strange but also the only petrol motor I can think of that burns oil by design is a 2 stroke petrol motor. And also diesel (I'm going to use that as my sort of example as its closer to oil then petrol) burns differently then petrol so there are big differences in how a diesel and petrol motor need to be constructed to get the most out of the different fuel. Compression ratios and fuel pressure being a factor but I'm not all over how stuff like that works. You probably could somehow inject a mix of sump into the manifold with petrol and the car would probably run but probably not as well as on petrol alone. And isn't 5L of engine oil more expensive then 5L of petrol?
Old 22-05-2018, 07:53 PM   #5
Venomous1
5.0 means business
Venomous1's Avatar
A pretty worn out engine would burn it's own oil but only to it's detriment.
Windsor V8 Enthusiast!
Turbo Barra Lover!
Venomous1 is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2018, 08:00 PM   #6
Shot rings or a cracked piston would also lose compression so that's a tad different to oil injection (yeah I know that's a 2 stroke boat or bike thing but it seems closer to the ops query then running a shot motor)
Old 22-05-2018, 08:06 PM   #7
BPXR6T
My old man was a firm beleiver in this. Not once in his entire life did he change the oil in his smokey old XA fairmont.
Old 22-05-2018, 08:30 PM   #8
SumoDog68
Some car companies are well ahead in this oil burning scenarios - direct injected engines especially.
SumoDog68 is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2018, 09:11 PM   #9
malazn mafia
Boss 335
malazn mafia's Avatar
Once saw somewhere on the interwebs a device (industrial heater?) that burns any sort of oil you give it, even waste engine oil, and it would put out some serious heat. Once toyed with the idea after experiencing a bill shock of $2k after moving into a new house
malazn mafia is offline   Reply With Quote Multi-Quote with this Post
Old 22-05-2018, 09:22 PM   #10
Seems like a lot of trouble to avoid changing the oil once in a while. The cost to change the oil is fairly small. Maybe they just want to keep the trucks moving 24/7? I’m with the OfficeManager; it sounds dodgy.
Old 22-05-2018, 10:02 PM   #11
Crazy Dazz
Have to change the oil frequently due to continuous operation in a dirty environment. Cost including Labour, downtime, and disposal is signifiant.
Plus, I think the diesels could burn it quite well, especially in minute concentration.
In theory, if properly tuned, even a petrol engine should be able to clean it up with a Cat, but in practice not sure how.
NB: On another site we got rid of all our waste oil, included reclaimed, in ANFO
Last edited by PG2; 22-05-2018 at 10:34 PM. Reason: No need for the comments. I'm starting to get sick of either deleting or editing your posts.
Old 23-05-2018, 06:42 AM   #12
Burnout
Falcon RTV - FG G6ET
Burnout's Avatar
In 1924, my old man went out to western NSW to work on a large sheep station as a Jackaroo.
The owner only brought Ford Model T's, he brought a new one every few years and gave his old one to the manager. The manager gave his old one to the overseer and the overseer gave his old one to the outstation boss.
In turn the outstation boss gave his old one to the Jackaroos.
In town on a Saturday night, they reckoned you could always here the Jackaroos coming to town form a pretty fair distance as the big ends were slapping pretty well by the time they got to drive it. You see, the Boss always said, it had oil in it when I brought it and I don't see why it doesn't have oil in it now.
BAII RTV - with Raptor V S/C.
RTV Power
FG G6ET 50th Anniversary in Sensation.
While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about.
“Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”.
Burnout is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2018, 07:35 AM   #13
OzJavelin
OzJavelin's Avatar
My Suzuki T500 burns all its oil ..
OzJavelin is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2018, 08:07 AM   #14
mike_nofx
mike_nofx's Avatar
I think a much better option is to have the old oil squirt into the rear tyres when stopped at lights so that you can safely burn it off during take off.
mike_nofx is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2018, 08:34 AM   #15
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Some trucks have two strokes (diesels) too.
cheers, Maka
Old 23-05-2018, 05:40 PM   #16
roKWiz
Cabover nut
roKWiz's Avatar
cheers, Maka
Yes my 2 stroke 6V53 Detroit, I guess if the injector rack sticks in the wide open position it would burn oil. (and everything else)
heritagestonemason.com/Fordlouisvillerestoration
In order that the labour of centuries past may not be in vain during the centuries to come...... D. Diderot 1752
roKWiz is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2018, 05:58 PM   #17
cheap
Wirlankarra yanama
cheap's Avatar
A small amount of two stroke oil per tank of diesel helps with the injectors. But purposely adding oil to the fuel with the intent of simply burning it away ... you do realise pistons have oil and compression rings to specifically stop oil and the combustion process from interacting.
cheap is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2018, 06:07 PM   #18
roKWiz
Cabover nut
roKWiz's Avatar
I use my used engine oil on the hardwood fence posts to stop termites and them drying out.
Three of my trucks use used filtered canola oil mixed with diesel to produce B50-B90 depending on the season.
Old 23-05-2018, 07:54 PM   #19
Kil4Collingwood
Kil4Collingwood's Avatar
My work ute, a 2002 VU commodore has burned it's oil off since new
Kil4Collingwood is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2018, 08:47 AM   #20
ebv8
ebv8's Avatar
mitsubishi have been doing this for years, been behind an early magna or pajero?
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2018, 11:07 AM   #21
Vesper Martini
Vesper Martini's Avatar
Not sure of the benefits, happy to be proven wrong but:
- If its using the engine oil you would need to continuously top up the engine oil, of risk running low.
- surely dirty engine oil in the fuel wouldn't be efficient, and would soon clog a fuel filter.
- oil filters would still need changing wouldn't they?
- having working in servicing trucks, there's a lot more checks & greasing that are done as part of the oil change -so it still needs a service.
- Cant be good for emissions almost certainly illegal.
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2018, 11:08 AM   #22
Vesper Martini
Craptivas & Cruzes are taking over where the Magnas left off
Old 24-05-2018, 06:34 PM   #23
ivorya
Mad Scientist!
ivorya's Avatar
Depends if you intend to drive on public or private land?
ivorya is offline   Reply With Quote Multi-Quote with this Post
Old 24-05-2018, 06:54 PM   #24
Crazy Dazz
  1. Yeah, not sure how it was done in practice, maybe a separate reservoir that fed clean oil in at the same rate. Keep in mind that using service trucks, its easy to top UP fluids and oils, as opposed to draining.
  2. I imagine it was taken from the clean side of the oil filters
  3. Oil Filters generally changed half as often, and could be extended by doubling up
  4. scheduled maintenance still required, but less often than oil change
  5. in a diesel engine, I doubt it would make significant difference to emissions. Petrol engine would be much harder I'd imagine
Old 24-05-2018, 07:13 PM   #25
Itsme
Experienced Member
Itsme's Avatar
If vehicle is registered EPA laws apply, if unregistered and public complaint EPA laws apply.
You should know when pollution is a problem all Government & local authorities will act against you.
Old 25-05-2018, 08:40 AM   #26
Junkyard-Dog
*barks incessantly
Junkyard-Dog's Avatar
Just stick to 2 strokes next time.
Junkyard-Dog is offline   Reply With Quote Multi-Quote with this Post
Old 25-05-2018, 06:47 PM   #27
ivorya
Mad Scientist!
ivorya's Avatar
I ask as Toyota are having major issues with their Hilux atm with the PDF clogging up. This due to the 5th injector in the wrong place being clogged.
Toyota's answer is to remove the PDF and EGR system.
This is happening now on all mine sites(Private land) as well as yodas driven in cities (public).
Old 25-05-2018, 07:32 PM   #28
Itsme
Experienced Member
Itsme's Avatar
Just because Toyota advises removal does not mean they are correct and in the end the owner of the vehicle/s is responsible for any breaches of EPA laws, I still stand by my previous post.
You must remember cars manufacturers must abide government rules regarding emission laws, any modifications to these are prohibited.
Old 26-05-2018, 08:26 AM   #29
ivorya
Mad Scientist!
ivorya's Avatar
According to the article/video review, they are allowed as they are on private land.
On public land however......
Old 27-05-2018, 12:54 AM   #30
Junkyard-Dog
*barks incessantly
They burn oil in Formula 1 as a power additive.
