Old 26-08-2007, 07:00 PM   #1
NC1183
NC1183's Avatar
Default Dome Light
Is it possible to wire the dome lights so that they have the ON - OFF - DOOR fuctionality.
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 26-08-2007, 07:43 PM   #2
JC
JC's Avatar
Which bit specifically are you after? Some Ex Police pack cars come with a switch that turns the lights off (my ex NSW police car had such a switch). Other than that, you can turn the light on by using the switch the forms part of the headlight switch, and the standard setting is for the light to come on when the doors open, but there is no default off function. Installing a standard rocker switch in the light assembly would give you an off option though.
Ford Performance Club ACT
Old 27-08-2007, 11:22 AM   #3
superroo
You can't stop the signal
superroo's Avatar
You can rewire the standard switch(the slider on the side) to do this but it will involve cutting of the switch loom, some rewiring and you will loose the high/low cluster light settings.
I'm sure it's possible because i just installed courtesy footwell lights (neons actually), that i can manually operate through the headlight switch slider. I did this because my cluster is LED's and the rest of the car's instrument lighting will be changed to LED's soon anyway, so the high/low light setting is of no use to me.
They way i have wired my lights is they will come on when ever the dome lamp comes on, and
Bottom position - Off - only come on when a door is open
Middle position - On - They are on but the dome light is not. they stay on regardless of ignition position. Dome light will come on when a door is opened
Top position - On and dome - This position works as normal
So it is possible. If you want a wiring diagram made i should be able to do, but what level (high/low) do you wanT the dash lights to be at?
Old 27-08-2007, 09:18 PM   #4
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
I put a small switch up above the seat belt in the creamy plastic part near the roof, I cut into the dome light wire to turn it off, turn it on and it works as normal. Turn it off and it won't come on at all even with doors open.
Sorry cant remember the wire colors now.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 27-08-2007, 09:32 PM   #5
Mechan1k
Mechan1k's Avatar
I realised the other day it'd be nice to have an OFF switch for it ... especially when the door ajar switch in the actuator fails ... and the interior light stays on ... or worse still flickers while driving at 5am to work in the morning.
I really was not in the mood for a disco at 5am.
At least pulling the CRT Lamp fuse didn't immobilise the ute .... I just didn't have interior lights for a day or so ... thank god.
I think the driver's door actuator shorts out in heavy rain for some reason ... and thinks the door is open.
