Old 02-02-2018, 05:46 PM   #1
eddy220t3
Default Series 1 v8 Fairmont xr8 220 conversion
Hey all
Not sure if posting this in the right place but in putting a 220 xr8 motor and box into a series 1 v8 Fairmont. (An building a te50 replica ish thing) my main question is will the Fairmont ecu run the 220 to all its potential? Because in guessing the xr8 wbu being a series 2 won't want to work with smartlock system?
Anyone been down this road?
Cheers for any help
Eddy
eddy220t3 is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2018, 06:40 PM   #2
Edxr6
Default Re: Series 1 v8 Fairmont xr8 220 conversion
Eddy,
You would need the ECU from the XR8 220 to run at it's full potential. I never had done the conversion, however I own an XR8 220, and I can't imagine this motor running on a Fairmont ECU given what Tickford has done to these motors. I would suggest a ECU from an XR8 220 or a custom ECU, which would be an expensive upgrade.
Good luck Eddy
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2018, 06:43 PM   #3
eddy220t3
Yea I was thinking that. I have the way out of the 220 but it's a series 2 not series 1 like the Fairmont so being out of a smart shield system instead of smart lock don't know if it would pair up
Old 02-02-2018, 06:49 PM   #4
Sox
RIP...
Sox's Avatar
They run quite ok with the stocker ECU.
Oval Everywhere...
Old 03-02-2018, 03:08 PM   #5
undertow
Technical Contributor: For members who share their technical expertise. - Issue reason: AU Aux input HOW TO.
As said it will run fine on the fairmont ECU but down a bit of power and torque. The 175/185kw tunes are set up for 91ron fuel and have less spark advance.
Once it's up and running you can look into a J3 chip or quarterhorse for tuning. Getting the S2/3 ecu to work in the S1 will be a headache as there are differences in the BCMs and instrument clusters.
undertow is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2018, 03:14 PM   #6
eddy220t3
Yea that makes sense, in thinking I'll just get a j3 for it then it should run ideal. Thanks for the advice
Old 03-02-2018, 03:52 PM   #7
Tickford.
🚫⏰4️⃣🐃💩
Tickford.'s Avatar
Do not use the series 2/3 ECU in your series 1. Just drop in the 220 and custom tune to suite.
Tickford. is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2018, 04:51 PM   #8
diceman01
When I enquired about a J3 for my VCT AU I was told the A/C won’t work. I’m not sure if it’s the same for the V8 something to keep in mind. If you want to run a S2/S3 ECU in a S1 it can be done if you swap the dash from a Series 1.5 and also use a steering column from a smartshield AU.
Sent from my iPhone using Tapatalk
AU 1 Wagon Liquid Silver, Fairlane seats/dash with XR6 Front & Wheels with future VCT conversion
AU 1 Fairmont Ghia Sedan Galaxy Blue with future Windsor conversion
VS SS Manual Panther Mica
VZ Monaro CV8 Phantom Black
diceman01 is offline   Reply With Quote Multi-Quote with this Post
Old 03-02-2018, 09:38 PM   #9
undertow
The A/C issues are a known problem with the TI Performance J3 chips in AUs (they're fine in E series though). Moates J3 chips or the Moates Quarterhorse work fine in AUs with one small caveat (PM me if you want to know). I have a Moates J3 in mine.
Interesting about the clusters... I've often wanted a real oil pressure gauge like the series 1 had, do you know if the series 1.5 clusters have real oil pressure or dummy gauges like the S2/3?
Old 04-02-2018, 08:47 AM   #10
diceman01
Yes all Series 1/1.5 clusters have real oil pressure gauges
Old 04-02-2018, 04:37 PM   #11
BOTTLEDUP
Change the 220's valve springs before you fit the engine, they're a known weakness.
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
