Old 17-10-2015, 01:18 PM   #1
sooty43
Default au1 auto shift problem
WhenI reverse out of the drive each morning and select drive, there is a hesitation for a second and then it bangs into gear. Is the auto on the way out or can it be adjusted to select smoothly?
sooty43 is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2015, 05:44 PM   #2
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Default Re: au1 auto shift problem
Possible that the idle is too high - the hesitation is relatively normal in the BTR but if it's not been serviced regularly then there are other possibilities such as line pressure, fluid level etc.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2015, 06:25 PM   #3
rmack
rmack's Avatar
Mine had a hesitation for 2years and finally lost reverse all together about 1 month ago.
Had the gearbox rebuilt and now the hesitation is gone.
Never had a problem going forward and was always smooth.
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2015, 10:55 AM   #4
sooty43
Thanks guys.
Its off to the auto guru tomorrow.Hope he can fix it. Its only done 350,000 kls.
Cheers RussellU
Old 18-10-2015, 11:10 AM   #5
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Originally Posted by sooty43 View Post
Thanks guys.
Cheers RussellU
That's a good innings, if you can get the transmission guru to cut open the old filter & inspect if / when he services the box, look to see if there's any clutch plate material in it. Good luck!
cheer's, Maka
Old 19-10-2015, 09:25 AM   #6
sooty43
That is exactly what it feels like maka. I will mention that to him. In the past he has mentioned that I am a smooth driver. Hope my FG/2ecolpi lasts as long. I have proved with my Fords going back 30 years that if you put a big cooler on the tranny as soon as you take delivery they will last a long time. People forget that heat is the killer of trannys.
By the way, got a good tan there mate!
Regards,...RussellU.
Old 19-10-2015, 09:39 AM   #7
Maka
Maka's Avatar
My missus is jealous of my hair ha ha....
Good luck when it goes in mate, hope its something simple like what russell w said previously.
Yep oil coolers are indispensable & on time transmission services with fresh transmission fluid are too.
cheer's, Maka
