Old 23-12-2014, 01:14 AM   #1
Smokin Whale
Smoke tires, not guns
Default P0135 O2 Sensor Heater Circuit error? Focus LS 2006
Hey guys,
Having some minor dramas with my Focus. Getting an O2 Sensor error according to my ODBII tool. The full error is:
Error Code: P0135
O2 Sensor Heater Circuit (Bank 1 Sensor 1)
Sounds like a sensor has played up and the CEL has come on. Cleared the code but came back shortly after. Mechanic said it's somewhere in the exhaust system. Car still runs fine but I think it might be running a little rich - fuel consumption could be better.
Just wondering if anyone knows what part I need to replace this or if there could be some electrical issue causing this that needs addressing. I quickly checked the fuse box and didn't see any issues. If anyone could give some guidance that would be awesome
Smokin Whale is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2014, 09:08 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Default Re: P0135 O2 Sensor Heater Circuit error? Focus LS 2006
Possible causes:
Mechanical: Low battery voltage
Sensor: Contaminated or damaged HEGO Sensor.
Wiring: Wiring open circuit or short circuit.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2014, 11:30 AM   #3
Smokin Whale
Originally Posted by russellw View Post
Possible causes:
Russ
Battery is 12.05v, seems OK. Looks like sensor may have just failed. Car has 126k KMs so probably time to replace. I don't think it's a wiring issue, although I wouldn't know where or what to test. It just happened randomly one day, nothing has been damaged.
Old 25-12-2014, 09:44 AM   #4
DZFord
DZFord's Avatar
I had the same error, mine failed at 110k KMs or so. I took the opportunity to replace both O2 sensors (Bosch).
The issue is that these sensors have a heater in them, to bring them up to operating temperature more quickly. When this heater / heater wire fails, it throws an error code. The 02 sensor still works, but just takes too long to get up to temperature.
The pre-cat / upstream sensor part number is: 0 258 006 573 (this is your one)
The downstream sensor part numbner is: 0 258 006 569
I think I picked one up from my mate who works at Bosch and the other through ebay as they didn't have stock.
Old 26-12-2014, 11:45 AM   #5
Smokin Whale
Dude, thank you so much. I'll get it sorted. I had thermostat issues for quite some time so it wouldn't surprise me if this would have been related. Is it relatively easy to swap out?
Old 26-12-2014, 12:25 PM   #6
DZFord
DZFord's Avatar
They are easy to swap out, but one of my 02 sensors was pretty jammed up and refused to budge for a while. The new sensors came with anti-sieze on the threads thankfully, and I would have added some one there if they didn't.
The job is made a lot easier with an oxygen sensor socket, which is like a normal socket but with a side cut-out, which gives room for the sensor wires. Just search oxygen sensor socket on ebay.
The thermostat issue may be something separate actually. These commonly fail as well. I used this guide to change mine over: http://fordforums.com.au/showthread....ght=thermostat
Old 29-12-2014, 02:39 AM   #7
Smokin Whale
Appreciate the response. On a side note, I'm guessing my local stealership would be the best place to get this part?
Ordered myself the technical manual for this car, will hopefully get my hands dirty on it soon. Already got the thermostat done, was causing too much fuel consumption and I had no time so I took it into my local mechanic. Made a huge difference to the car. Pretty pleased I didn't attempt that one, would have been a bit tricky for me.
Old 29-12-2014, 08:53 AM   #8
marg99
getting the Oxy sensor out without the modified socket is very hard, be line ball cost effective to buy the socket and do it yourself verses paying a local mechanic.
marg99 is online now   Reply With Quote Multi-Quote with this Post
Old 30-12-2014, 10:15 PM   #9
Smokin Whale
Probably bang on there, I'm guessing a standard 22mm oxy sensor socket would be the way to go then. I'll order one online, only $16 or so.
Which type of socket is best? Standard socket or Offset? Or doesn't matter?
Offset:
http://www.ebay.com.au/itm/NEW-Compa...item43d45d3362
Standard:
http://www.ebay.com.au/itm/Sealey-Ox...item51c84d60d7
Old 30-12-2014, 11:58 PM   #10
DZFord
DZFord's Avatar
I used the 22mm standard socket
Old 11-02-2015, 05:41 PM   #11
Smokin Whale
Hey guys, thought I'd update this thread. I got a PDF technical manual off ebay, then realised it was totally unnecessary since it was such an easy job. Ended up getting the sensor for $125 from Repco (was $147 at the dealer) along with an O2 sensor socket for an extra $14 or so. Job done in less than 10 minutes, all I had to do was remove the engine cover (make sure the car is cold), disconnect the O2 sensor wire on the right hand side, then use your socket to remove the sensor from the back of the exhaust manifold. Swap the new sensor back in, clear the ODB2 codes, and bob's your uncle. Not hard at all.
