Old 18-07-2014, 01:49 AM   #1
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default WS Fiesta - vibration through wheel right turn
Hey guys, driving my WS Fiesta I'm noticing I got vibration through the steering wheel on my WS Fiesta when the wheel is turned right, but none on the left?
Its odd, anyone have any clues?
Thanks guys.
Old 18-07-2014, 07:01 AM   #2
raceteam
Default Re: WS Fiesta - vibration through wheel right turn
Flat spot or damage to the left front tyre, or front left wheel bearing?
raceteam is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2014, 12:11 PM   #3
Franco Cozzo
Thailand Specials
How could I check damage to the wheel bearing? Just the normal wheel test?
Old 18-07-2014, 12:38 PM   #4
raceteam
Raise that corner of the car, and move the wheel with your hands to check for play in the bearing.
Old 18-07-2014, 08:05 PM   #5
Pursya
Maybe even a drive shaft.
Sounds like the symptoms of my old Eunos 500. And the solution was new drive shaft.
Pursya is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2014, 06:36 AM   #6
raceteam
When you turn right, weight transfers to the left side of the car, so anything on the left side that has to work a bit harder could be at fault - common ones are wheel/tyre related, but you may need to keep looking past those...
Old 19-07-2014, 03:57 PM   #7
Franco Cozzo
Thailand Specials
What I'll do is check tyre pressures, get the wheels balanced and a wheel alignment done, if its still doing it I'll investigate further.
I'm hoping for simple fix lol.
Old 21-07-2014, 01:11 PM   #8
Swoopdown
Swoopdown's Avatar
Have a look at control/wishbone and bushings as well maybe
Swoopdown is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2014, 12:31 PM   #9
NSMZ
Possible Buckled Alloy too?
Try putting the spare on and see if you can replicate the issue...
NSMZ is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2014, 01:58 PM   #10
Franco Cozzo
Thailand Specials
Its got steelies on it, never got alloys because of this problem.
Old 01-08-2014, 04:11 PM   #11
xr8territory
xr8territory's Avatar
I had a vibration going through my rear left tyre. It turned out that the shock absorber was worn and it had scolloped the tyre. A $28 check and Pedders will find the problem for you.
Fords I own or have owned:
XW UTE, XW FAIRMONT, XT GT, XT Fairmont, EF XR8, XH XR8 UTE, XH XR8 UTE, AU UTE, Renault Scenic, XF UTE, BA XR8 UTE, TERRITORY, Chrysler Voyager, WS FIESTA ZETEC,TERRITORY TITANIUM, BA UTE, Nissan Pathfinder, AU Falcon Forte, BA XR8 UTE.
xr8territory is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2014, 05:04 PM   #12
NSMZ
agreed for the Wheels Check.
Always worth it.
Not to mention, you Tyre coudl also have a egg in the side wall from a pot hole.
Or your stockie has become unbalanced.
Old 02-08-2014, 09:01 AM   #13
mrmavx
Molten Orange Maniac
mrmavx's Avatar
If you dont have any joy with the wheel balance/alignment i would be looking at the posibility of a worn outer( inner will show up all the time) cv joint that only has play when on lock
Mrmavx
mrmavx is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2014, 09:23 PM   #14
Pursya
Are Pedders still in business?
http://forums.whirlpool.net.au/archive/602911
Be very careful.
