Old 28-05-2014, 09:01 PM   #1
Crazy Dazz
Default Where is Odometer reading stored?
I'm looking at an XR8 that has been tarted up a bit.
It's had a GT's instrument cluster fitted, including the odometer display. So, is it showing the car's mileage OR the donor car's mileage?
Old 28-05-2014, 09:11 PM   #2
Top_Ghia
Technical Contributor: For members who share their technical expertise. - Issue reason: has been consistently providing good technical advice etc. to AFF members, by having the vast technical knowledge he has with the various Ford products. A valuable AFF member
Cluster.
I put a new cluster in my old banged up BA wagon. It looks pretty rough for 28,000km ;)
Top_Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2014, 09:14 PM   #3
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default Re: Where is Odometer reading stored?
In an AU you can just chuck another cluster in there and it will show the donor cars mileage, pretty silly you think they would store it in the ECU or BCM to stop that happening.
Old 28-05-2014, 09:19 PM   #4
Pub247
Resident F1 Troll
Pub247's Avatar
what happens when you need to replace ecu or bcm?
In a lot of car you can take the screen and chip out and swap them not to sure on whether you can do it to fords
Pub247 is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2014, 10:40 PM   #5
Franco Cozzo
Thailand Specials
I guess so.
ECU or a BCM isn't a common thing to replace though, except on E series Falcons because the solder joints crack and go dry, the BCM on those is a bad design, single layer circuit board with tonnes of crap soldered onto it. I've helped repair a few of those things.
Only certain parts of them go dry, last one was the car kept imobilising itself every now and again, it was the part of the circuit which controls smart lock, if you punched the **** out of the steering column/dash while trying to start it, it would start.
Resolder the whole board will fix it, not worth getting one from a wrecker because it will most likely have the same problem.
I've not run into problems with an E series ECU before though, its always BCM.
Old 29-05-2014, 01:29 AM   #6
zilo
BANNED
zilo's Avatar
In a Mitsubishi, for which I have the dealer ecu tool, I can see it stored in 3 places.
The instrument cluster ( a CAN bus device), in the BCM and in the engine ECU.
In SA cab drivers were trying to "extend" their warranties a few years ago and got caught out...LOL
zilo is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2014, 01:32 AM   #7
Franco Cozzo
Thailand Specials
The Honda's I was working on in 2010 had to have new odometers set by the dealer scan tool, and it would disable the old one so it couldn't be used.
So interesting on the 380, what year is it?
Old 29-05-2014, 04:07 AM   #8
xxx000
years ago a mate bought a brand new Falcon wagon, think it was an XE or similar model.
he had a hidden switch installed to stop the odometer working and drove the car pretty hard and did lots of real kms on it.
the car was regularly back at the dealer getting work including a new gearbox fitted under warranty. Eventually the car was quarantined by the dealer as they suspected what he'd done.
They found the hidden switch which was behind a dashboard blanking plug and that was the end of his warranty
xxx000 is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2014, 07:27 AM   #9
Trump
bitch lasagne
Trump's Avatar
Silly bugger should have removed the switch before giving it to the dealer
Any different from a normal XE? I swear our one when I was a kid was at the dealer at least a dozen times for warranty issues. Which is quite bad seeing ad they only had 12 months warranty or 20,000km. Old man hated that car hahahahah
Scaled Business Solutions
For Your Small Business IT Needs
Trump is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2014, 10:23 AM   #10
zilo
BANNED
zilo's Avatar
Originally Posted by big damo View Post
the honda's i was working on in 2010 had to have new odometers set by the dealer scan tool, and it would disable the old one so it couldn't be used.
2008...
Old 29-05-2014, 11:41 AM   #11
Road_Warrior
Pity the fool
Road_Warrior's Avatar
LOL haven't heard of that field service fix before.
Fords I own or have owned:
1970 XW Falcon GT replica | 1970 XW Falcon | 1971 XY Fairmont | 1973 ZG Fairlane | 1986 XF Falcon panel van | 1987 XFII Falcon S-Pack | 1988 XF Falcon GLS ute | 1993 EBII Fairmont V8 | 1996 XG Falcon ute | 2000 AU Falcon wagon | 2004 BA Falcon XT | 2012 SZ Territory Titanium AWD
Proud to buy Australian and support Ford Australia through thick and thin
Road_Warrior is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2014, 12:17 PM   #12
V8 Ghia Mike
Blue blooded Ford guy!
V8 Ghia Mike's Avatar
Mine is doing it occasionally, but only needs a light tap under the dash when turning the key.
Mike
09 FG G6E Turbo
Ego grey, Cashmere leather, factory 19" wheels, Monroe GT/King SSLs, stock Barra, still goes hard...
94 EF Fairmont Ghia 5.0- XR8 in a tuxedo...
Bordeaux purple, Tickford kit, 2.5+ inch drop, EL Ghia chrome, leather, Pioneer sound, C&C, electric everything, 18" BA XR8's, ABS, LSD, GT40P's, Crane cam, ChipTorque ECU, XR8 snorkel, lots of woodgrain, chrome and interior lights.
V8 Ghia Mike is offline   Reply With Quote Multi-Quote with this Post
Old 29-05-2014, 01:33 PM   #13
Franco Cozzo
Thailand Specials
Haha thats the EF/EL BCM fault diagnosis method, if the car turns over but wont start, but it will when you beat the **** out of the dash/steering column then dry solder joins on the BCM.
Old 29-05-2014, 04:57 PM   #14
Crazy Dazz
Originally Posted by Top_Ghia View Post
Cluster.
That's a bit of a worry, so I have no way of telling the real mileage of the underlying car. Pass
Not sure WHY people think sticking random FPV bits on an XR8 is "cool"?
Old 29-05-2014, 05:45 PM   #15
GASWAGON
My XR6 wagon does this but i was thinking it was a dodgy relay inside the BCM.
A good hit under the l/h side of steer column works every time.
GASWAGON is offline   Reply With Quote Multi-Quote with this Post
