Old 14-04-2014, 12:14 AM   #1
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Default Losing water from overflow slowly?
Is it normal to lose water level in the overflow tank over time?
TDCI Focus with 75,000km on the clock, my coolant level is just a bit under the minimum indicator.
I haven't noticed any leaks inside the car at all, though the other night there was some water in the footwell on the floor mat, but my passenger stepped in a puddle accidentally before she got into the car so I'm guessing its from that.
Old 24-04-2014, 08:08 AM   #2
josem
Default Re: Losing water from overflow slowly?
Generally you should not be loosing any coolant at all because it is a sealed system. It is a sign that you have a leak. Sometimes the leak is not visible from the top if you just pop the hood up. I have a leak on my focus just after 20,000 kms and I only noticed it when I was changing the oil myself and I was under the car. The red/pink coolant was very visible under the was pump and some of the pulleys from underneath the car but not visible if viewed from the top of the engine.
josem is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2014, 07:26 PM   #3
simon varley
Technical Contributor: For members who share their technical expertise. - Issue reason: Bringing sanity to the Everest threads.
If I remember right, the cap seals on o-rings. There have been cases where the bottle distorts and the opening is no longer round so the o-rings don't seal properly. If you can't see any obvious residue from a leak you could consider this.
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2014, 11:58 AM   #4
Franco Cozzo
Thailand Specials
At the moment its half way between empty and the minimum mark on the overflow bottle.
Old 30-09-2014, 05:18 PM   #5
fbvisitor
Just wondering how this turned out.
Was it the heater core leaking or something else?
Cheers.
fbvisitor is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2014, 11:08 PM   #6
Franco Cozzo
Thailand Specials
Hasn't turned out to be anything just yet, nothing obvious is leaking but its still very slowly losing coolant.
Old 07-10-2014, 04:58 PM   #7
oemdenied
radiator is one of the common leak points on the Focus mk2 - end caps.
Have the system pressure tested.
Last 2 we did were both XR5s @ 60k service.
Advertising removed.
oemdenied is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2014, 06:10 PM   #8
dirty hands
Over Thinker
dirty hands's Avatar
thats low kms to have this sort of problem
very strange ....
petrol and diesel engines available .. nice car
this artical . writer must not like ford focus ..
http://www.whatcar.com/car-news/comm...oblems/1201320
all used an oil cooled turbo if fitted I see
if it had a water cooled turbo fitted - I would be looking at the turbo internals
My car goes Brumm Brumm
Old 08-10-2014, 12:47 AM   #9
Franco Cozzo
Thailand Specials
I've pressure tested system, it very slowly loses some pressure, as in over an hour period, very slowly.
Old 08-10-2014, 11:45 AM   #10
oemdenied
very strange ....
I cant think of any Turbo vehicle built in the last 10 years that doesn't have an oil line to it for lubrication? or any that isn't water cooled?
Pressurise the system and inspect all hose connections and the radiator end tanks fully whilst under pressure. If no visible leak is found, pressure test the cap. If that all checks out I would start looking at an internal leak such as head gasket. Never seen a turbo leak coolant internally only at the sealing washers which will give you an external weep/drip during pressure testing.
Old 08-10-2014, 12:35 PM   #11
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Bugger... that will be hard to find.
Perhaps it's losing pressure from the actual testing unit? Set it up again, and if the pressure slowly drops again spray soapy water around the fittings and see if it bubbles up.
___________________________
Old 08-10-2014, 02:39 PM   #12
marg99
The other less desirable choice is leaking at the water pump Is the pump external or inside the timing chain cover in which case you will need to look at the small drain hole at the bottom of the cover under the pulley to see if there is coolant stains down there
