Old 23-04-2013, 08:39 PM   #1
raised by monkeys
raised by monkeys's Avatar
Default PBR upgrade brakes on AU
Hi,
Do the PBR C5 calipers require a bracket for fitment, or are they direct fit?
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
FG MkII G6E Turbo built by Heinrichs Performance and Tuning
BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning
"Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger
raised by monkeys is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2013, 11:24 AM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Default Re: PBR upgrade brakes on AU
It is dependant on rotor size as the bigger the rotor the further up the stub the
calliper needs to be
Originally Posted by Riksta
Old 24-04-2013, 11:58 AM   #3
raised by monkeys
Cheers whoosha. Itll be DBA4000 series which are 330mm discs.
I did ring RBS and they said the calipers will bolt up, however, wouldnt be first time ive been given the wrong info from the those who should know better lol.
cheers
Shaun
Current
Previous
Old 24-04-2013, 05:45 PM   #4
FOCUSonTHIS
FOCUSonTHIS's Avatar
I put the 330mm on my car with a C4 calliper and that needs a bracket for it.
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 24-04-2013, 08:31 PM   #5
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Shaun, just to ensure you are aware, DBA4000 is a style of disk that does not determine the size of the rotor. My DBA4000s are 355mm.
I am pretty sure that Matt from RBS will not give you a bum steer. He would not deliberately misinform you.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2013, 09:05 AM   #6
raised by monkeys
Unsure if I follow. Do you mean the number series is just allocated and the size of the disc has no relation?
Anyways, I had organised to buy a set that were being sold by RBS, but from a private seller who'd bought them but not put them on his car but it didn't go ahead. I was a bit annoyed considering I had given the seller my details and told them I would transfer money to their account the following afternoon, they sold them on me.
Anyways, so im back in the market for a brake upgrade. The budget is more inline with the C5 upgrade or tickford twin piston set. There's a couple of tickford ones on ebay atm that im looking at and a pair at a ford wreckers in Adelaide.
cheers
Shaun
Current
Previous
Old 25-04-2013, 10:44 AM   #7
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Easiest way to describe it Shaun is DBA4000 Series is a model such as AU. Within that model, there are many different variances. Effecively, DBA4000 is a style of rotor, that you can buy for almost any car, so obviously come in many different sizes.
Good luck with your hunt. From memory, my mate Ray is running 330mm disks and calipers from a BF XR6T - I believe they just bolted straight up.
Hope that helps.
Stu
2002 AU II LTD
Old 25-04-2013, 06:37 PM   #8
b2tf
not here much anymore
b2tf's Avatar
Shaun dont waste your time or money going aftermarket, get some BF brakes off an XR8 or XR6T and they will bolt straight up. I know because I did it to the old ute - no extra parts required - calipers, hoses, rotors and thats it.
Spend the extra coin on some good slotted rotors and decent pads and enjoy.
2024 F150 XLT
Old 25-04-2013, 07:26 PM   #9
arronm
BA/F6 BF/F6 SSV/R TTG
arronm's Avatar
As long has you have AU2 on , and you arnt going to the track, grap a set of BF FG turbo front brakes (322 x 28mm) or even better BA FPV blue brakes (c5 caliper) 325mm x 32mm all bolt straight on.
BA BF FPV starter button repairs. PM me.
Nizpro equipped and Tuned by the BEST in the west
Xtreme Ford Tuning
479RwKw Fuel limited, more pumps and power too come.
F6#0507 & #0639 Pro racer and Tech expert
NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below.
https://youtu.be/oa4IfguGQ-A
arronm is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2013, 07:31 PM   #10
arronm
arronm's Avatar
Try these. Possibly ask him how much thickness left on the front rotors. They start at 32mm and MIN is 30mm. Rears are solid and the same as most BA BF 303mm
http://www.ebay.com.au/itm/BA-Falcon...#ht_500wt_1414
Xtreme Ford Tuning
Old 27-04-2013, 03:36 PM   #11
raised by monkeys
they're the ones I was meant to buy from the seller as per above.
cheers
Shaun
Current
Previous
Old 28-04-2013, 01:21 PM   #12
madmelon
I've got the BA FPV C5 fronts with 325x32 and BF XR8 Ventilated 330mm single pistons on the rear of my AUIII XR8. A bit of stuffing around to get brake lines right and the 3mm caliper spacers on the back but they work really well at the track with good pads in them.
madmelon is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2013, 02:05 PM   #13
arronm
arronm's Avatar
The listing is back up. These are 10 times better than the 322mm turbo brakes.
Xtreme Ford Tuning
Old 28-04-2013, 03:08 PM   #14
FGII-XR6
FGII-XR6's Avatar
this looks like a good investment http://www.ebay.com.au/itm/281097812...84.m1423.l2649 just BYO standard BA callipers ( $20 each from the wreckers) and away you go so about $360 for a 322 mm setup that looks factory
[SIGPIC][/SIGPIC]
Rides:
Old 30-04-2013, 10:40 AM   #15
prn31
prn31's Avatar
Those Tickford C4 brakes for sale on ebay at that Adelaide wrecker look like a good buy. They come with the upright as well so you don’t have to worry about getting those difficult-to-find brackets either.
That is the route that I took when I upgraded the brakes on my AUIII Fairmont V8 wagon. They are a big improvement over standard and I had no clearance issues with my Tickford 17 inch wheels either.
prn31 is offline   Reply With Quote Multi-Quote with this Post
