Old 10-01-2013, 01:40 PM   #1
mattyshea
Default More fun from the auto?
I have a series 2 xr8 ute with the 4 speed auto.
Im finding it really boring as its shifting at around 2000rpm and I dont have a chance to hear the exhaust growl as it changes too soon.
Is there anyway I can program the gears to change at a higher rpm?
Im pretty sure I already have it on 'power' mode
mattyshea is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2013, 03:18 PM   #2
Sox
RIP...
Sox's Avatar
Default Re: More fun from the auto?
Nature of the beast.
Either shift manually or fit a manual gearbox.
Oval Everywhere...
Old 10-01-2013, 03:20 PM   #3
mattyshea
How much damage could occur from shifting it manually?
Old 10-01-2013, 04:58 PM   #4
Sox
RIP...
Sox's Avatar
No damage at all, it's perfectly fine to shift manual.
Oval Everywhere...
Old 10-01-2013, 07:57 PM   #5
robbyj
Rob
robbyj's Avatar
shift kit
edit: shifting at 2k? give it a real boot and it will hold out to 5+
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 10-01-2013, 08:50 PM   #6
EF302
Are you sure it's in power mode?
Mine shifts around 2500rpm in power unless I'm really light on the gas, and at around 2000rpm in economy. This is with the adaptive shift auto though.
EF302 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2013, 03:28 PM   #7
STINKY NINJA
Yep my au shifts wherever i want it to,it depends on throttle input maybe you just need to put your foot down a bit more.
I have an adaptive shift trans,has economy,adaptive and performance.With economy or adaptive it shifts early but holds the gear a little longer when in performance.But again it all depends on throttle input.
Maybe put some diff gears in it 3.9 or 4.11 seem to suit the auto well.
You can only really get a good feel of the exhaust note in first gear anyhow because most times you will be exceeding the speed limit by then...
STINKY NINJA is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2013, 03:55 PM   #8
mattyshea
Thanks guys,
Ill try reset the ecu and try put it in 'performance' mode again.
And yes, Maybe I do need to give the accelerater a bit more
Old 16-01-2013, 10:51 AM   #9
AU Mont
4.11 diff gears
will breathe new life into the way it drives.
the shorter gearing will encourage the auto to drop down more often with less load.
AU Mont is offline   Reply With Quote Multi-Quote with this Post
Old 21-01-2013, 10:45 PM   #10
2002au
Define definitive
2002au's Avatar
Just put it in neutral and rev like bam bam bam bam bam then select D for maximum respect.
BF F6 TYPHOON in NEO #718 ~ 356rwkw :
BF XR6 TURBO in SILHOUETTE
2002au is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2013, 01:34 AM   #11
robbyj
Rob
robbyj's Avatar
hahahah, then hear the gear box smash into gear.
