Old 10-12-2012, 03:14 PM   #1
dan-
Default lw - key battery low??
when i hopped into my car the other day i had an error beep and a message flashed up on the screen in the gauge cluster saying 'warning - key battery low, change soon'
this seems pretty odd as my car is only 8mo/12,000km old.
has anyone else had the same message? does it pop up erroneously? if not, is the battery easy/cheap to replace?
dan- is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2013, 10:18 PM   #2
totallysour
Default Re: lw - key battery low??
Mine is 8mths old and has started not responding to every button press. Haven't had the message thiugh
totallysour is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 02:26 PM   #3
Russ
Russ's Avatar
Shouldn't need replacing yet I wouldn't have thought but it's a pretty simple process to replace, most use a CR 2032 -3V battery, which should be available in most auto spares places, electronic stores or the local chemist
Old 04-01-2013, 04:22 PM   #4
Foconatic
Foconatic's Avatar
They seem to be having the same issues in the States as well. Is your car keyless start / proximity entry system? They do drain battries quite quickly but 8 months seems too soon. My Titanium is a November 2011 build and I picked it up in Feb last year but the remote/s is/are fine.
FORD FOCUS Titanium Sedan with Sports Executive Pack in Midnight Sky GDI
Going somewhere isn't why you drive, driving is why you go
Foconatic is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 04:33 PM   #5
Kable72
Parts Interpreter
Kable72's Avatar
Be careful as they are prone to breaking when you change the battery.
BFMKII XR6 Turbo Sedan
6sp Manual Pedders Coilovers Short Throw Shifter
Kable72 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 09:12 PM   #6
Foconatic
Foconatic's Avatar
This might help:
http://www.focusfanatics.com/forum/s...=264796&page=3
